squonk
Dec 26, 2020 15:24:39 GMT
Sandro
This is something I might just try out. The inside of my garage roof is constantly damp and a bit drippy at times. If this sorted it, that would be pretty amazing! Thanks!!
IG: @burnthismk2
You shouldn't be getting problems like that with condensation in your loft, I would investigate the cause as well as trying to dry it out
squonk
Correct. Shortly after discovering the problem (found when I discovered the moisture had destroyed some vintage HiFi equipment) I started to clear the loft so that I could investigate further. So far I have found some damage to the roof felt (repair tape is on order) and the cold water tank had no lagging or a cover on it (cover now fitted). It was after I found the issues that I bought the dehumidifier to help dry things out. It will be staying up there for the time being until repairs are complete and everything is dried out. I have also installed a remote temperature and humidity sensor that communicates to an app on my phone so that I can monitor how close to the dew point it is up there. As I type this it is 7.38°C and 75%RH giving a dew point of 3.24°C. Little chance of moisture forming at those conditions so the dehumidifier is doing its job.
