Morris fgk30 1967glenanderson
@glenanderson
Club Retro Rides Member 64
Apr 11, 2018 20:58:26 GMT
This is the baby version of what’s underneath mine. 30cwt vs 100cwt for the Noddy.
Good luck with it. Seeing the state of that cab makes me glad I’ve not got a metal one on mine!
retrolegends
Winging it.....Since 1971.
Club RR Member Number: 94
Morris fgk30 1967retrolegends
@retrolegends
Club Retro Rides Member 94
Apr 12, 2018 17:59:33 GMT
Great progress, can't be easy with the lousy weather we've had lately, nice patio too. 😆
1974 Hillman Avenger 1500DL1992 Volvo 240SE1975 Datsun Cherry 100a flying custard1965 Hillman SuperMinx Rock N Roller1974 Austin Allegrat Mk1 1.3SDL1980 Austin Allegro Mk3 1.3L1982 Austin Allegro Mk3 on banded steels2003 Saab 9-3 Convertible 220bhp TurboNutter1966 Morris Minor 1000 (Doris) 2019 Abarth 595C Turismo (not retro but awesome fun) www.facebook.com/DatsunCherry100a
Apr 12, 2018 18:01:09 GMT
great work so far, bookmarked this
as you were fishing for welding advice, looking at the couple of pictures. when the weld looks like meteor strike (hollow in middle) and sandy texture its a lack of gas, regulator needs to go up allot. outdoor welding needs quite a bit of extra, if you are doing it right you will not see more than 5 or 6 minutes continuous welding on a halfords style disposable bottle
Last Edit: Apr 12, 2018 18:07:06 GMT by darrenh
Rich
Club RR Member Number: 160
Morris fgk30 1967Rich
@foxmcintyre
Club Retro Rides Member 160
Apr 12, 2018 22:28:38 GMT
if you are doing it right you will not see more than 5 or 6 minutes continuous welding on a halfords style disposable bottle Wut? I get hours out of mine without shielding issues. I think you are doing something wrong there mukka. I built my entire tray back landrover (cab closure, and box section bed) on probably 2 bottles, more than 12 minutes welding in all that I can assure you 😂
Apr 13, 2018 18:17:38 GMT
Wut? I get hours out of mine without shielding issues. I think you are doing something wrong there mukka. I built my entire tray back landrover (cab closure, and box section bed) on probably 2 bottles, more than 12 minutes welding in all that I can assure you 😂 liquid size of bottle, multiplied by internal pressure in psi, divided by atmospheric pressure, divided by litres per minute of regulator. (outdoors you are looking at about 8-10 l/min based on argon/c02 mix) "continuous welding" = if you sellotaped the trigger down and left it going. hope this helps, mukka
Last Edit: Apr 13, 2018 18:20:03 GMT by darrenh
Apr 13, 2018 18:35:36 GMT
Rich
@foxmcintyre
Apr 13, 2018 20:05:12 GMT
Wut? I get hours out of mine without shielding issues. I think you are doing something wrong there mukka. I built my entire tray back landrover (cab closure, and box section bed) on probably 2 bottles, more than 12 minutes welding in all that I can assure you 😂 liquid size of bottle, multiplied by internal pressure in psi, divided by atmospheric pressure, divided by litres per minute of regulator. (outdoors you are looking at about 8-10 l/min based on argon/c02 mix) "continuous welding" = if you sellotaped the trigger down and left it going. hope this helps, mukka I'm still fairly sure I get more than that out of a bottle but I'm sure your maths is spot on. I don't use Argon/co2 mix though, just co2, what difference that would make I don't know, I don't get on with argon on my Mig. I like the little bottles. Keeps the whole shebang easily transportable, I often run mine to and from work in my boot.
Apr 13, 2018 20:19:54 GMT
I've now got the 10 lt bottle and the supplier reckons that you get 8 hours continues welding as Darren said with being out side the gas needs to be turned higher but most of the welds I'm going to be doing is no more then a few seconds at a time been told this way you get less distortion and I don't burn threw as much.
Rich
@foxmcintyre
Apr 13, 2018 20:25:42 GMT
Awesome. Should help you speed along with the epic job you are doing. Some great work going into this and an awesome save too, that cab is very far gone but top work bringing it back to life!
Apr 14, 2018 17:09:22 GMT
Started on the quarter window strip that comes from the roof down/front to side panel Got it cut out and tryed to make the new one but it turned out to be a disaster so gived up as a bad job and will try again tomorrow. Few pictures.[img src="http://img.retro-rides.org/i/v/bobfg30/6e8d4fe8db5b.jpg[/I'm img.retro-rides.org/i/v/bobfg30/f7e91414c60f.jpg"]
Apr 14, 2018 17:11:47 GMT
Apr 25, 2018 19:44:24 GMT
Not had a lot of spare time to work on the truck over the last week or so but did manage to get the peace for the side Windows done engine removed and started up on the floor sounded sweet. And just removed the wheel arch and floor panel
Apr 25, 2018 19:58:36 GMT
Apr 25, 2018 20:00:48 GMT
Apr 25, 2018 20:03:42 GMT
Forgot to take photos of the peace for the Windows will post them next time
Apr 26, 2018 17:41:54 GMT
I don't have much to add, just that I love it. Super-satisfying seeing fresh metal let in Keep it up.
vulgalour
Club RR Member Number: 146
Morris fgk30 1967vulgalour
@vulgalour
Club Retro Rides Member 146
Apr 26, 2018 18:54:22 GMT
At first that inner wheel arch looked a really peculiar shape. Then you realise it's the function that dictates its form, maximising the amount of cabin floor while keeping the truck at the height it is on the tall wheels, the bowtie shape allowing the wheels to turn fully. It's quite clever, really.
Incredible progress being made on this too with some very difficult shapes being constructed with what almost seems like considerable ease.
Apr 30, 2018 16:16:44 GMT
Apr 30, 2018 19:50:31 GMT
looking good
Picked another sheet of metal up this afternoon and started cutting floor panels out some odd shapes to these old trucks started putting grooves in one of the panels but going to need some dressing over need to try and make some thing solid to fit around the groove to acked as a dolly or if any one got any ideas much appreciated
