Darkspeed
Club RR Member Number: 39
1995 Ginetta G27 4.5 V8 Darkspeed
@darkspeed
Club Retro Rides Member 39
Jan 21, 2020 21:47:07 GMT
Some work took place on the G27 project this weekend Whist messing around with the B type V8 on another thread. Not a great deal - granted - but progress was made and buttons were pressed to order up some Gaz Gold coil overs to enable the final brackets to be designed. These all Black anodised ones look very cool but I have no idea what will arrive colour wise but its been a while since any significant spending was done on this. Also been looking at tyres for this one as well - projects costs this year are looking to escalate - feck. Hmmmm need to raise some funds But I did find loads of cool stuff in all the boxes for this car - that made me smile.
Darkspeed
@darkspeed
Jan 26, 2020 19:42:07 GMT
Shocks have arrived and I can now measure the mounting eyes and get on with the CAD work for the brackets. Quite happy with the quality but the proof or the pudding is in the eating and it will be a good while before any tasting gets done - each pair comes with a dyno sheet - used AVO Spax and Protech in the past and never had any issues with them apart from corrosion on the steel bodied ones but that's just housekeeping.
Darkspeed
@darkspeed
Quick CAD job this morning whilst watching storm Ciara try and rip all the covers off of the cars and do its best to defoliate the evergreens. Drawing for the shocker brackets - 4 off required - also need to order up some reducer bushes so that's another job on the list for today If the roof looks like it will stay on the garage I may well venture out and manufacture the brackets later.
Darkspeed
@darkspeed
V8 - this could well get me in trouble if playing in my head on a summer evening in the G27 - One of those tunes that would have me melting the rubber from the tyres.
Last Edit: Feb 9, 2020 17:02:01 GMT by Darkspeed
Darkspeed
@darkspeed
Feb 15, 2020 19:07:27 GMT
In the garage today making brackets - after a bit of a tidy up - within the first few tracks of the random on the phone we had one of my favourite garage tracks. Material - 40mm x 3mm Bright mild steel A bit of marking out later. And shortly after some time with hacksaw, pillar drill and files we have. Which fitted to the cross tube diameter thus And we keep on going Until we have all four completed
Last Edit: Feb 16, 2020 7:12:26 GMT by Darkspeed
1995 Ginetta G27 4.5 V8 stealthstylz
@stealthstylz
Club Retro Rides Member 174
Feb 23, 2020 19:18:46 GMT
That should stiffen the block up a bit. None of the aftermarket ones I've ever fitted are much different to the pre braced version, usually 16 gauge steel and a few pressings/louvres to add rigidity. They're obviously universal fit (to one type of engine) though so need a bit of flex to make up for differences in castings.
Darkspeed
@darkspeed
Feb 23, 2020 19:47:55 GMT
That should stiffen the block up a bit. None of the aftermarket ones I've ever fitted are much different to the pre braced version, usually 16 gauge steel and a few pressings/louvres to add rigidity. They're obviously universal fit (to one type of engine) though so need a bit of flex to make up for differences in castings. As it only bolts in with 1/4 UNC its probably not capable of adding that much. Block is about as stiff as it gets being one of the rarer cross-bolt small journal types so more material in the block than the cross-bolt large journal blocks. The sump has a fair bit of extra steel for baffles and trap doors etc. that's also a bit stiffer than normal. I suppose it all adds up and as I am going to be spinning this one a bit higher than usual it needs all the help it can get. The usual RV8 folded types are better than the stock SD1 tray type but do not offer a whole lot as they do not run close enough to the crank for long enough - about 10 degrees if that. This type runs close to the crank for at least 180 degrees and is reported to help gain a few extra horses at the top end.
1995 Ginetta G27 4.5 V8 peteh1969
@peteh1969
Club Retro Rides Member 107
Feb 23, 2020 20:11:40 GMT
Nice work as all ways.
Will you be adding baffles to the Sump as well?
Darkspeed
@darkspeed
Feb 23, 2020 21:29:41 GMT
Nice work as all ways. Will you be adding baffles to the Sump as well? Mentioned above - Sump is baffled and has trap doors. Covered that bit of work over in the Strato's thread before I split the threads up - forum.retro-rides.org/post/2334336It worked well enough before but I have a couple more mods that I want to do to it. Oh curse word - July 2017 !!!!
Last Edit: Feb 23, 2020 21:31:15 GMT by Darkspeed
I just read this whole thread for the first time; I've been following your other ones. All fascinating and educational. Tough to believe just how small this car is though. It's a cliche, but looks like you'll wear it more than get in and sit down. And you certainly won't relax! Very cool and I much appreciate the time and effort you put into your updates. John
Darkspeed
@darkspeed
Feb 24, 2020 10:20:38 GMT
Thanks John - your comments are appreciated and I'm pleased to read that you enjoy the posts. Just had a flick back through myself, as its not that bad only being 9 pages at present, to remind myself just how little I did on this car due to all the G15 and G21 stuff last year.
It is a very small car, all the cars I have are pretty small even the 6 foot wide Stratos!
Last Edit: Feb 24, 2020 22:02:30 GMT by Darkspeed
Darkspeed
@darkspeed
Mar 21, 2020 19:35:49 GMT
Tyres arrived - I have gone for Toyo TR1's for the time being - well away from actually taking any of the tread off but need them for the set-up of the car. Fronts 195/50/15's - really quite cheap - offset by the 225/50/15 rears that are not near as cheap. The calculations of the speeds with these slightly oversize tyres makes for an interesting read. - Well it does if you are me. Better make sure that the brakes are up to the task.
trimtechniques
Porsche 928 4.7 ltrs of German grunt. Mazda MX-5 MK1 Dakar. VW T4 camper
Mar 21, 2020 20:45:49 GMT
What a great read your threads are. I love the work on the Stratos thread. But this Ginetta is an equally interesting car! Absolutely great work.. I just don't know how you make the time to get it all done!
Darkspeed
@darkspeed
Mar 22, 2020 21:32:15 GMT
What a great read your threads are. I love the work on the Stratos thread. But this Ginetta is an equally interesting car! Absolutely great work.. I just don't know how you make the time to get it all done! Cheers, feedback is always appreciated - The time question gets asked quite a lot - simply. I enjoy it and find it pretty therapeutic so whatever time I can find and spare it's what I will do.
Darkspeed
@darkspeed
May 16, 2020 22:05:16 GMT
Can't make much in the way of progress on this at the moment as its 50 miles away - but..... I have ordered up enough alloy for the floors on this one whilst I was buying in all the materials for the other projects. Hopefully when things ease a bit more I will either collect the wheels or get them dropped off as part of a delivery collection day so I can get the tyres on the wheels.
Darkspeed
@darkspeed
Wheels and tyres are now together and will be going off to be fitted on Saturday with a bit of luck which also means they will then take up a lot less space.
I really must sit down and read through all your threads. There's always dead interesting things, like the sump baffling and windage tray. I've baffled the sump of the Spitfire, but I don't think I've done a great job of the design really. Needs to box in the sump a bit better really, rather than be open around the edges. Great food for thought
Darkspeed
@darkspeed
Jun 13, 2020 20:23:19 GMT
I really must sit down and read through all your threads. There's always dead interesting things, like the sump baffling and windage tray. I've baffled the sump of the Spitfire, but I don't think I've done a great job of the design really. Needs to box in the sump a bit better really, rather than be open around the edges. Great food for thought Cheers - Just give yourself plenty of time Not much of an update on this one - Wheels and tyres are now together.
