ivangt6
Club RR Member Number: 132
Range Rover Classicivangt6
@ivangt6
Club Retro Rides Member 132
Dec 29, 2017 22:51:26 GMT
I has ze Range Rover Collecting tomorrow providing all goes well with the dodgy trailer company I'm using. I should say at this point it is cheap. Which means it needs work. And plenty of it. Good bits - it runs, drives, stops - all looks straight and original - new boot floor Bad bits - No MOT - needs welding to footwells, front of RH sill and rear of LH sill - electric seats don't move due to switch (MOT req) - washers don't work - lots of trim missing & rear seats not bolted down - no headlining - rotten upper tailgate Plan at the minute is to Give it a service and do what is needed to pass an MOT and then sell the Discovery. This can only go well....
Last Edit: Dec 16, 2018 15:09:13 GMT by ivangt6
1979 Mini 1000 1972 Triumph GT6 2007 VW Golf GTi 1979 VW T25 Leisuredrive 1988 Range Rover Vogue SE
Dec 29, 2017 23:42:46 GMT
From my experience there is likely to be a lot more rust when you start digging! took me the best part of a year in the end (mine is year older and much of the rot hidden with filler)
Now its done I love it though.
ivangt6
@ivangt6
From my experience there is likely to be a lot more rust when you start digging! took me the best part of a year in the end (mine is year older and much of the rot hidden with filler) Now its done I love it though. It's had some work previously. Rear crossmember and boot floor, rear arches and some work to the battery tray. It will probably need neatening up in these areas but all in all it looks a lot better than my disco did before I started that. I'm more worried about the flapper type EFI which I've heard isn't the most reliable/a pain in the a*se
Carlosfandango.
Now with added Suffix B Range Rover classic - another bucket list car acquired.
Love it. Looking forward to more pics & progress. One of these is definitely on the wish list.
CFD
1966 Fiat 1500 fast road/race conversion 1967 Porsche 912 1968 Fiat 124 Spider 1973 Range Rover Suffix B 1993 Series one Discovery 200TDI 1997 Jaguar XJ6 3.2 sport 2001 P38 Range Rover 2.5 TD Brace of Triumph bikes
Bookmarked, as you'd probably expect.
I have a 1970s one. (Running a Nissan engine) Models before early 80s were bolted together but yours will be a welded one unfortunately. I did have a 1993 vogue once, dreadful engine but didn't half drive nice apart from the engine, whose camshafts are made out of butter.
I'm more worried about the flapper type EFI which I've heard isn't the most reliable/a pain in the a*se If it plays up then whack Megasquirt on it Love the Gru intro, made me chuckle
düdo
wide as house
Dec 30, 2017 11:11:47 GMT
ivangt6 allegedly said on another thread Time to get professional help, either that or get a couple of Corgis and make like the Queen. It is the preferred ride of the Windsors is it not?
Dec 30, 2017 17:54:13 GMT
I'm more worried about the flapper type EFI which I've heard isn't the most reliable/a pain in the a*se If it plays up then whack Megasquirt on it Love the Gru intro, made me chuckle Mine has the same, megasquirt etc not so easy on these as they have the balasted injectors, best option is SUs or the later injection system.
Dec 30, 2017 18:07:45 GMT
Everyone loves an old Rangie. I have some ambition to have another.
I have a 1970s one. (Running a Nissan engine) Models before early 80s were bolted together but yours will be a welded one unfortunately. I did have a 1993 vogue once, dreadful engine but didn't half drive nice apart from the engine, whose camshafts are made out of butter. Which part was bolted or welded?
g40jon
If you get stuck for parts, a mate of mine has one which is being broken for spares. lots of trim available and body panels. He is keeping the running gear for a project. I've been ebaying some parts for him, but still have loads of smaller trim bits sat in my garage. All will be priced to sell!
If it plays up then whack Megasquirt on it Love the Gru intro, made me chuckle Mine has the same, megasquirt etc not so easy on these as they have the balasted injectors, best option is SUs or the later injection system. Not true! I ran a conplete flapper top end on my defender when I first went EFI from SU's, you have two options: Run with the resistor box which makes the injectors effectively high impedance Run without the resistor box using PWM. I did the first, then after a couple of years swapped to a later hotwire type manifold so I could use newer style injectors with better spray pattern and atomisation. Anyways, this is all getting ahead of ourselves, I am sure the flapper will be ok. If it's not then troubleshooting manuals are here: forums.lr4x4.com/topic/16466-35-v8-flapper-system-diagnostic-manual/
ivangt6
@ivangt6
Mine has the same, megasquirt etc not so easy on these as they have the balasted injectors, best option is SUs or the later injection system. Not true! I ran a conplete flapper top end on my defender when I first went EFI from SU's, you have two options: Run with the resistor box which makes the injectors effectively high impedance Run without the resistor box using PWM. I did the first, then after a couple of years swapped to a later hotwire type manifold so I could use newer style injectors with better spray pattern and atomisation. Anyways, this is all getting ahead of ourselves, I am sure the flapper will be ok. If it's not then troubleshooting manuals are here: forums.lr4x4.com/topic/16466-35-v8-flapper-system-diagnostic-manual/The bloke I bought it from has a few Hotwire assembly's lying about so that could be an option. I have heard that a 14cux ecu is pretty much a straight swap but that could well be not true. All went well with the pickup yesterday. Well after I'd moved it forward on the trailer. I made the mistake of having it loaded too far back on the trailer at first. It was trying to jackknife at about 30! Nearly pood myself. Moved it to the front of the trailer and it was a completely different animal Pics to follow or it didn't happen
Last Edit: Dec 31, 2017 9:38:58 GMT by ivangt6
ivangt6
@ivangt6
If you get stuck for parts, a mate of mine has one which is being broken for spares. lots of trim available and body panels. He is keeping the running gear for a project. I've been ebaying some parts for him, but still have loads of smaller trim bits sat in my garage. All will be priced to sell! Cheers! That could well be very useful as it's missing a fair bit of the interior
ivangt6
@ivangt6
Dec 31, 2017 10:00:50 GMT
Dec 31, 2017 11:07:02 GMT
Mine has the same, megasquirt etc not so easy on these as they have the balasted injectors, best option is SUs or the later injection system. Not true! I ran a conplete flapper top end on my defender when I first went EFI from SU's, you have two options: Run with the resistor box which makes the injectors effectively high impedance Run without the resistor box using PWM. I did the first, then after a couple of years swapped to a later hotwire type manifold so I could use newer style injectors with better spray pattern and atomisation. Anyways, this is all getting ahead of ourselves, I am sure the flapper will be ok. If it's not then troubleshooting manuals are here: forums.lr4x4.com/topic/16466-35-v8-flapper-system-diagnostic-manual/I didn't say it couldn't be done but why on earth would you go to all that effort with 30 year old injectors with replacements virtually unobtainable or at best criplingly expensive, if you start with a hotwire system injectors are widely available at a reasonable cost. As you say the flapper is not that bad, there are a lot of reports of failed ecu's but a certain amount of the comment around this seems to be from those wanting to sell you reman ecu's. The real problem is parts, there being virtually no new stock and much of it being common with more expesive brands so very expensive. On mine some of the wiring is also begining to crack and had to be replaced, they also rarely completely fail (usually mixture drifts off) so you always get home. Kevin.
düdo
wide as house
Dec 31, 2017 11:11:37 GMT
That's a nice ensemble the Discovery and RR. Also a very spacious hanger you've got - could fit a few more classics in there and perhaps a proper Spitfire? A flying one.
Dec 31, 2017 11:12:46 GMT
I have a 1970s one. (Running a Nissan engine) Models before early 80s were bolted together but yours will be a welded one unfortunately. I did have a 1993 vogue once, dreadful engine but didn't half drive nice apart from the engine, whose camshafts are made out of butter. Which part was bolted or welded? The main components of the shell. Early ones bolted together, but they later switched to welding them together to improve tolerances, panel gaps etc as they were gearing up for an assault on the American market.
Dec 31, 2017 11:14:30 GMT
Which part was bolted or welded? The main components of the shell. Early ones bolted together, but they later switched to welding them together to improve tolerances, panel gaps etc as they were gearing up for an assault on the American market. Never realized that. I know a guy who builds Disco 2’s with classic RR chassis for the vintage tax here. Hmmm
