Jan 19, 2018 20:10:42 GMT
What a bargain
I'd avoid the princess calipers, sod all piston area, a modern sliding caliper would be way better,
loads of cheap and more effective 4 pots on ebay. princes pistons are 38mm x2 , e38 beemer are 44 and 40 on each size, which adds up to the same as the boggo sliding calipers on an e39 5 series.
micha1
Jan 20, 2018 10:13:49 GMT
even scimi chassis are well constructed from big gauge steel i would first split body from chaiss b4 investing any money in that car....that picture form underneath does not look very promising. for the brakes i would use some modern hi-spec ones...usually princess calipers can be sold for quite googd money...so your hi-spec upgrade would repay a bit www.scimitarweb.co.uk/sgwrs/viewtopic.php?t=8055&start=15
Last Edit: Jan 20, 2018 10:21:00 GMT by micha1
PhoenixCapri
West Midlands
Club RR Member Number: 91
Jan 20, 2018 10:20:25 GMT
Cheers guys, some good feedback. Still not fully thought through the galvanising, but will almost certainly get it blasted as have a place that does stuff so cheap it'd almost cost more in wire wheels for the angle grinder (plus it's so nice just to hand something over and get it back all clean just needing some paint). Caliper wise, thinking Princess because I have them lying around plus they always have really nice pedal feel and worked great for 8 years on my old Escort track car. But the sliding 5 series bits I will keep in mind as a back up as they might help with other clearance things In other news I got up to 6 bolts/hour yesterday, just the rear bumper beam area to take to bit now. Also examined the Pinin axle, and let's just say it's not what I was told it was (i.e. it's an open diff...) You win some you lose some - might just use the stock axle now and invent a disc brake setup. Will help the budget, plus the only wheels I can find I like in 5x114.3 are way too expensive for this built. Anyone else struggle with flux in projects? I just can't seem to get a fix on exactly what I'm going to do with this one yet...
£1k builds: Eagle Jeep bit.ly/33uoUCE Estelle bit.ly/3rXATC8 Superminx bit.ly/3H6tDZe
£2k builds: Chevette bit.ly/3sNPqQ4 Gazelle
Other Builds Toledo bit.ly/3oYFGkO Capri Mk1 bit.ly/3rVTtdQ Capri Mk2 bit.ly/3uWLijx Escort Mk2 bit.ly/359HUXL E-type bit.ly/3sSqbMD CRX bit.ly/3I2gYrt
Jan 20, 2018 19:51:03 GMT
Body drop it then do a Liberty-Walk makeover
PhoenixCapri
West Midlands
Jan 26, 2018 21:21:06 GMT
Body drop it then do a Liberty-Walk makeover Kind of worried how well I think that would work! Certainly be different!
Jan 26, 2018 22:35:09 GMT
Or throw the Scimitat body away and fit a fibreglass Hotrod body??
79cord
Thought he would give it a single headlight treatment like Capri...wagon.😊
Last Edit: Jan 27, 2018 3:55:50 GMT by 79cord
PhoenixCapri
West Midlands
Thought he would give it a single headlight treatment like Capri...wagon.😊 I may have some lights that I'm considering, but single rounds would be far too obvious
