Nov 22, 2017 17:42:18 GMT
Edit : see below for strip & rebuild guide Hi, The brake fluid on my Hunter has been needing regular top-ups for a while now, with no obvious signs of leaking at the wheels or pipework. Yesteday I peered into the remote servo and found it was awash with - presumably - the missing brake fluid. I've never needed to work on servo before so any advice is welcome, I guess the obvious options are : find a good used one (can anyone help?) DIY repair of mine (parts + hassle, I think I've found a "major rebuild" kit for under £30 ) send mine away for repair ( £££ ) buy new or recon unit ( ££££+ ) This writeup gives some great advice and background info, DIY looks do'able (if I can get the parts) but splitting the old unit won't be easy www.buckeyetriumphs.org/technical/Brakes/Servo/Servo.htmAll suggestions / ideas welcome ! Not the best photo but this shows the servo at the top right
Last Edit: Dec 2, 2017 15:25:12 GMT by nomad
Nov 22, 2017 18:20:39 GMT
I did a few on MGB's and Rovers and its really not that difficult looking at what you did to buildings, sheds ect. On the site you refereed to, you see a tool (the thick plate with handlebars) what they fit to the threads of the brake servo housing to split the 2 halves. It is wise to make such a tool otherwise, you pull out the threaded peices out of the housing. With such a tool splitting is not really difficult. The rest is not too difficult too
Peter
Nov 22, 2017 18:27:19 GMT
If it's the Girling version servo try Northwest Classic for the parts if you want info on how to rebuild it message me and I will send you my number easier to talk you through it that right it all down.
I reconditioned the servo on my Mk3 sceptre not hard to do just complex.
Nov 22, 2017 19:05:41 GMT
It's not the servo that's the the problem...... the missing brake fluid is caused by the seals on the master cylinder failing and allowing it to leak into the servo.
Nick
What Nick said. It's happened to me a few times in the past.
A new master cylinder should see you on your way and with improved braking.
It's not the servo that's the the problem...... the missing brake fluid is caused by the seals on the master cylinder failing and allowing it to leak into the servo. ^ Top answer - I opened the servo and found about a pint of brake fluid inside We have progress, and most of it is good I bought a servo rebuild kit from Eb@y seller Greenwood, exactly what I needed apart from the large seal which is the wrong size. Not a problem but for info - Hunter Estate Lockheed servos are larger than Lockheed 7" servos Spot the difference Photos - showing helpful sizes - from the Eb@y advert (credit to Greenwood for the images) img.retro-rides.org/i/v/nomad/4d2dcb77022a.jpgimg.retro-rides.org/i/v/nomad/dc56316e48e6.jpgimg.retro-rides.org/i/v/nomad/d4e696ae1d6e.jpg
Remove the servo - very simple, just 1/2" bolts (3 inside the car, 1 on the bulkhead clamp), then disconnect both brake pipes. Undo the bolt holding the clamping ring to split the servo, Note. Most other servos "twist" together and are difficult to split ! img.retro-rides.org/i/v/nomad/33e3d5a31cff.jpgRemove the large rubber diaphragm, you can then remove the forked "key" that holds the large plastic disk onto the shaft. Tip : turn the unit so the key is at the bottom of the disk, press the large disk to compress the spring. Remove the 3 bolts holding the master cylinder onto the servo casing. Pull the shaft out of the cylindr (it may be stuck - use short sharp tugs) Check the cylinder bore carefully, if worn/pitted/scored consider finding a different servo !Old seals alongside the rebuilt shaft (note both rubber seals have "lips" and need to be fitted the right way around ) Closeup showing the "hidden" pin that holds everything together img.retro-rides.org/i/v/nomad/409b80605cd5.jpgLube the cylinder with new brake fluid and fit the rebuilt shaft. Fit 3 bolts (with locking plates) holding cylinder to the servo casing Fit the large spring / large black disk, and fit the key to hold it all together. - work the assembly a frew times to check it moves freely. Fit the large rubber seal then clamp both halves of the servo together. New bits before re-assembly img.retro-rides.org/i/v/nomad/19708401d47b.jpgDone, ready to refit
Last Edit: Dec 2, 2017 15:27:21 GMT by nomad
