May 14, 2019 20:17:29 GMT
First job was to sort the washer jets / air intake grille and ensure that the arrangement did not interfere with opening / closing of the bonnet Hence the bonnet could now be removed Then the lift masked up but in a way that it could still be operated to rise & fall Also masked the rear axle & suspension up I then spent quite some time going over each panel / area and gave them all a very through clean with panel wipe (this is one of the stages that many people miss - although your final top coat may adhere to the primer - the primer will not adhere to the panels should they be any contaminant trace on the said panels) - I also found two very minor areas that I was not happy with on the roof - so these got sorted at the same time Here's the first stage primer all ready to go Unfortunately I ran out of workshop time today to get it applied - but its all good to go very first thing in the morning The Corsair however is very good company at present with this fine Sprite that I have just fitted a hood to
May 14, 2019 20:34:30 GMT
People the length and breadth of the country dying with anticipation .....
AHHHHHHHHHH.......sooo close! I thought, "Are we really going to see this car becoming one color???"...then...my hopes were dashed...but uplifted at the same time..."Maybe tomorrow, then!"
good stuff.
JP
Hi Chris Great job as ever and like more people curious to the end result. I see you are using a scale. Last week, i got an friendly instruction from the guy at the paint supplier (as i am unexperienced in that area) and he said that i should not use a scale but do volume mixing of the 2 K paint as there is a big difference in the density mass per color. For instance 1 liter of white paint is much heavier then 1 liter of black paint so he advised me do volume mixing instead of weight mixing. I am pretty sure you are aware of this but i was surprised
Keep up the good work and thanks again for showing it as there is a fair bit of work involved in that
Peter
Darkspeed
Club RR Member Number: 39
I do love an egg crate grille For mixing Weight v Volume I go with what the manufacturer recommends on the TDS - Kent advise by weight.
SPELLBOUND
Still just saying rude words of amazement inside my mouth, smiling and shaking my head at all of this Chris.
Hi Chris Great job as ever and like more people curious to the end result. I see you are using a scale. Last week, i got an friendly instruction from the guy at the paint supplier (as i am unexperienced in that area) and he said that i should not use a scale but do volume mixing of the 2 K paint as there is a big difference in the density mass per color. For instance 1 liter of white paint is much heavier then 1 liter of black paint so he advised me do volume mixing instead of weight mixing. I am pretty sure you are aware of this but i was surprised Keep up the good work and thanks again for showing it as there is a fair bit of work involved in that Peter Peter - Its all down to the what the product / paint manufacture recommends - has 'Darkspeed' states much of the Kent products are by weight not volume - sometimes its other way around - then again on certain paints / products it changes again - so for example on a standard 2 pack paint you mix the paint & hardener at 2 to 1 ratio - still 2 pack but if its a satin finish you mix at 1 to 1 ratio (otherwise you wont cure the matting base effectively and the paint finish stays shiny) - and on matt finishes you mix at a 1 to 2 ratio for the same reason
May 15, 2019 20:02:18 GMT
So - on with the primer - this is a 2 pack polyester - very high in solids - You need a large fluid tip & needle in the spray gun to apply this product - min 1.8mm - I have a dedicated polyester gun that is a 2.5mm set up Its the first time that I have used the lift with a car on it for painting - and it makes the task so much easier Engine bay & boot load areas first Then the rest of the bodyshell Along with some of the smaller painted parts & the underside of the boot lid So far so good Once the polyester started to cure it could be guide coated For ease I just use matt black aerosols for guide coating Then the shell / lift could be relocated and parked to allow more workshop space Some of the smaller parts completed With the workshop space freed up I could then do the next set of panels for the car Bonnet, boot & the two offside doors just the right weather for this process too not too hot but essentially not too cold either All went according to plan And the offside doors That just leaves the 2 nearside doors and a handful of minor / small parts to put into polyester - due to the size of my workshop I can only process so much at any one time - it has to be undertaken methodically too with a thought out process - its pointless having loose panels in final paint if you have nowhere safe to store them - from experience the best place is fitted back on the car / bodyshell - so that needs to be painted first More tomorrow
Last Edit: May 15, 2019 20:07:17 GMT by Deleted
May 15, 2019 20:27:19 GMT
i think if i were pete i would have a little "moment"...and definitely a large celebratory vintage port!!
May 15, 2019 20:33:28 GMT
Do you know how many people with project-cars currently in paint shops would be thrilled to be able to watch the progress!
I notice that the product you use is Direct To Metal. Worth noting for those following along that feature is not a given with all of the polyester high build primers.
Last Edit: May 15, 2019 20:38:18 GMT by bjornagn
May 15, 2019 20:37:04 GMT
i think if i were pete i would have a little "moment"...and definitely a large celebratory vintage port!! I have had mine already - in fact I might go back have another
May 15, 2019 20:39:29 GMT
bah humbug... stock is out!:-(
well deserved though chris... looking great in one colour.
Last Edit: May 15, 2019 20:44:40 GMT by strikey
jyd
May 15, 2019 21:02:25 GMT
Just a quick question to satisfy my curiosity?
why don't you use an etch/wash primer first?
May 15, 2019 21:08:21 GMT
Will polyester primer absorb moisture if not quickly over painted?
vulgalour
Club RR Member Number: 146
May 15, 2019 22:59:52 GMT
Blimey. That's progress.
tristanh
Routinely bewildered
May 15, 2019 23:06:54 GMT
You're fairly getting out the primer with a 2.5mm tip! Is it "thick" compared to say typical 2k Base coat?
Fantastic Chris! It looks amazing!
Just a quick question to satisfy my curiosity? why don't you use an etch/wash primer first? Firstly - The polyester product that I use deletes the requirements for using etching primers - more to the point several polyester primer products physically react with etching primers - this one included - the use of etching primers would have been a given several years ago but has paint / coating product & material advances area made some previously utilised stages of primer application are no longer required - Secondly - providing that you are both thorough & diligent in your preparation - ensuring that a good well keyed substrate base is achieved and that the panels are free from all contaminates then you have eliminated the requirement for etching primers anyway on steel panels - alloy panels are a little more difficult but not much - providing that your preparation is correct from the outset
Last Edit: May 16, 2019 8:00:27 GMT by Deleted
Will polyester primer absorb moisture if not quickly over painted? Not at all - its a 2 pack product - hence its fully sealed and will not absorb moisture - what you refer to is a single pack solvent drying primers that will absorb moisture
You're fairly getting out the primer with a 2.5mm tip! Is it "thick" compared to say typical 2k Base coat? Very much so - its a very dense product and goes on quite thickly - after a quick rub over with the DA sander it then gets blocked back by hand - you can thin the product in order to apply it in lighter coats - but my preferred method is to apply 2 x moderately heavy / unthinned coats and then work it back from that point - its pretty pointless applying it lightly has it will then fail to do the job that you are applying it for in the first place
Last Edit: May 16, 2019 8:01:44 GMT by Deleted
