scotto
Bye the way if you need the depress tool just let me know. Thanks, appreciate it! Also really appreciate the link to the shifter, i think i may copy! One of a handful of cars that could tempt me away from my single marque ethos. Love the work (except for the appalling wire-locking ) and the 'ruined' look is exactly what I'd go for - although the engine would be much newer appalling is a little harsh sticking with the M10 engine is a no brainer for me, it's an important part of bmw's history and has been used in F3, F2 and F1 applications, interesting read below: f30.bimmerpost.com/forums/showthread.php?t=1350137That's stunning, love it. Thanks! Brilliant work and a fantastic looking car Looking forward to updates Bookmarkex Thank you, appreciate it!
bmstew
Great Car- Love This. Looks much better than my ratty 2002
BMStew 73 BMW 2002 90 BMW E30 325i Cabby 96 BMW E36 328i Cabby
Lovely car, bookmarked!
96 Peugeot 405 Executive DTurbo Estate 89 Mazda Eunos Roadster 88 Citroen BX 16RS Previously Owned: 93 Subaru MV96 Disco 300TDI 72 LR SIII 109" Prima96 Xantia Activa 92 AX GTI 97 ZX Temptation 88 205 XS
faker
novanut
Wow!
Stunning!
That is all..
Great build. Will be keeping an eye on this for sure.
Bookmarked.
Corr that looks lovely! Could turn it upside down and eat your dinner off that! Really nice car that. Friend of mine 'ruined' a 2002 as well... A little more extremely than you have, so don't feel bad in the slightest. Supercharged Honda S2000 lump with a sequential box propels his along at an alarming pace as it spits flames and other good stuff haha Check out [CAR CRAZED FOOL] if you want to see more of it
scotto
Great Car- Love This. Looks much better than my ratty 2002 Thanks, i really like yours, the back story is great too! So far mine doesnt have much of a one! Wow! Stunning! That is all.. Great build. Will be keeping an eye on this for sure. Thanks guys, appreciate the positivity on this forum so far! Corr that looks lovely! Could turn it upside down and eat your dinner off that! Really nice car that. Friend of mine 'ruined' a 2002 as well... A little more extremely than you have, so don't feel bad in the slightest. Supercharged Honda S2000 lump with a sequential box propels his along at an alarming pace as it spits flames and other good stuff haha Check out [CAR CRAZED FOOL] if you want to see more of it Haha thankyou and that looks like Elliotts at least he's got the pristine concourse turbo as his original one. I'm going for a halfway house between the two for mine and i'm living off bread and butter to achieve that nevermind a second one, maybe someday!
Loving this. Top work
Mk2 Golf 16V resto
It is indeed Elliott's I'm looking forward to seeing yours progress, it's looking super clean so far!
scotto
Oct 23, 2017 10:30:47 GMT
scotto
Oct 23, 2017 10:31:35 GMT
Next up has been getting the gearbox ready for its rebuild, this has been a long road but its ready to go back together now, hopefully this will happen in the coming weeks! As I’ve mentioned before, my dream 2002 in my head has always had a dogleg 5 speed so hopefully this one will work out for me! I’ve basically ended up cleaning everything as much as I can, from the state it was in internally it’s resulted in a complete u-turn. I’ve swapped all the old gears out for ‘as new’ condition ones as well as all new baulk rings. You can see from the pics below these were all well over due. This box will end up as nearly new condition, other than 5th gear which has a little pitting but there are no input shafts/5th gears available anywhere for them. Old and new: Dead baulk ring: All done: Scrap gears and rings: Main case: From the clutch end: All together: Reinforced release bearing lever all Ed China’d: These also got the treatment and new seals fitted. The headwork has been going well and its nearly finished. First off it was soda blasted and guides removed: Valves cleaned up: The seat surface on the valves will be redone when the 3 angle seats are ground. Then the port modifications took place: You can see in the picture below the port before/ after and the way the guide has been changed: The guides are also the later style with the smaller stem seals. The advantage of these is that when running dual valve springs theres no risk of the inner spring catching. My current cam choice doesn’t need dual valve springs but its good to know for later down the line. I’ll be running Schrick single springs for now. I needed to work out the piston intruder volume so the combustion chambers could be done: Further to this the head should be finished this week and I can get it built back up. I'm beyond excited for this part. I’ve wanted a head done by the guy who owns the competition engine builders where I’ve assisted for 14 years (half my life!) for nearly all of those 14 years so I’m really chuffed its finally happening. The other great development, which I’ve mentioned above, is that the Jenvey Throttle bodies have arrived. I’ve also wanted a set of these for as long as I can remember too! Bare bodies with trumpets and manifold: Parts: Alloy fuel rail: Cut down and chamfered: Fitted: Underslung linkage installed: Awesomely neat FPR: And that’s about it for now, I’ve got more bits on the way or at least ordered so can crack on, still loads to do but I’m confident for a spring start! Thanks for reading, Scott.
Oct 23, 2017 11:06:19 GMT
Excellent.
jamesd1972
Club RR Member Number: 40
BMW 2002 - The Tii (ish)jamesd1972
@jamesd1972
Club Retro Rides Member 40
Oct 23, 2017 11:48:44 GMT
Living on baked beans and pot noodles is clearly paying off! Nice work. James
BMW 2002 - The Tii (ish)peteh1969
@peteh1969
Club Retro Rides Member 107
Oct 23, 2017 12:05:53 GMT
This may sound a silly question as you have an alloy head but are the valve seats ok to run with unleaded fuel or were they changed when the new seat angles cut?
I'm not familiar with alloy heads which why I asked.
Love the build thread.
scotto
Oct 23, 2017 12:21:53 GMT
Living on baked beans and pot noodles is clearly paying off! Nice work. James Thanks James, it's paying off for the car but not my waistline! This may sound a silly question as you have an alloy head but are the valve seats ok to run with unleaded fuel or were they changed when the new seat angles cut? I'm not familiar with alloy heads which why I asked. Love the build thread. Thanks Pete, not a silly question at all. These engines had hard seats from factory so are fine with unleaded fuel. The place i help out at does plenty of unleaded seat conversions though! The 3 angle machining work still needs to be done to the seats, ill post more pics when its done.
Oct 23, 2017 20:14:48 GMT
Epic build.. in for more updates.
BMW 2002 - The Tii (ish)ChasR
@chasr
Club Retro Rides Member 170
Oct 23, 2017 20:38:46 GMT
This build is superb. At this rate it should be a right stormer of a car!
jamesd1972
@jamesd1972
Forgot to ask what power do you think thiis engine will make 150ish ? Looking too good to drive !
Oct 24, 2017 19:27:32 GMT
Very nice. I live by JFI
