Jan 26, 2019 11:23:57 GMT
Got it - something else that attracts workshop dust and that you fall over in about a months time - then blame everybody else for puting it there in the first place Not far wrong π Its a pretty mundane thing,but it should see me spending more time in the garage....
Jan 26, 2019 11:24:22 GMT
Jan 26, 2019 11:46:54 GMT
Ah, of course...
Jan 26, 2019 14:29:27 GMT
Something you wouldn't need in Manila π
Jan 26, 2019 14:35:22 GMT
Bracket screwed to the wall Heater set up and ready to go. Drilled a 28mm hole through the wall for the exhaust. Was a Christmas present from Mrs Bravo. A Chinese knock off of an Eberspacher diesel heater as used in sleeper cabs and camper vans. Really chucks out the heat. Works with a heat exchanger so doesn't fill the garage with water vapour. Exceptionally good value for money at about Β£135 and costs about 1/3 of what electricity does to heat the garage. Johnny Bravo is happy and content in a warm garage.....π
v8ian
Jan 26, 2019 14:39:49 GMT
I thought it was warmer outside today, Now I know, why, you must be heating my road too,
eternaloptimist
Jan 26, 2019 14:59:18 GMT
Interesting - how bigβs the garage and how many kw is the heater? I might swap my condensation forming gas fired space heater for one of these.
Jan 26, 2019 15:13:15 GMT
Bracket screwed to the wall Heater set up and ready to go. Drilled a 28mm hole through the wall for the exhaust. Was a Christmas present from Mrs Bravo. A Chinese knock off of an Eberspacher diesel heater as used in sleeper cabs and camper vans. Really chucks out the heat. Works with a heat exchanger so doesn't fill the garage with water vapour. Exceptionally good value for money at about Β£135 and costs about 1/3 of what electricity does to heat the garage. Johnny Bravo is happy and content in a warm garage.....π And there we go the forever ingenious Mr Bravo (although he's not that ingenious has a proper ingenious type of garage dweller would have a cooper pipe core wound around that exhaust has an heat exchanger linked back to a water filled wall hung radiator further down the workshop) But I could well be barking up the wrong flue pipe (I often am) if that exhaust does not get warm enough for a heat exchanger to become effective
Jan 26, 2019 15:32:47 GMT
One step ahead of you there Chrisπ Have the radiator already but need to change a couple of things outside the garage before I can reroute the exhaust how I want it. Little Tig project for Little big Bravo with the heat exchanger.....
Jan 26, 2019 15:34:27 GMT
Interesting - how bigβs the garage and how many kw is the heater? I might swap my condensation forming gas fired space heater for one of these. 5kw on full tilt. Garage is double,side by side garage,roughly 5,5m x5,5m
Jan 26, 2019 15:37:21 GMT
I thought it was warmer outside today, Now I know, why, you must be heating my road too, Yep. So thoughtful of me π Just got the new third gear set for the Panther back from the gearcutters. Had the dehumidifier running since yesterday. Wacked the heat right up as I wanted to spray the gears and shafts with storage wax / rust preventative until I need them. π
Jan 26, 2019 15:40:38 GMT
New third gear cluster and mainshaft for the Panther gearbox rebuild. Johnny Bravo stuff tomorrow π
Jan 26, 2019 16:20:04 GMT
One step ahead of you there Chrisπ Have the radiator already but need to change a couple of things outside the garage before I can reroute the exhaust how I want it. Little Tig project for Little big Bravo with the heat exchanger..... But isn't it good when great minds think alike (says GN has he trips up over the alloy frame thing that's gathering dust in the workshop)
Jan 26, 2019 16:36:59 GMT
Those heaters are good value. I'm very tempted with one.
Jan 28, 2019 23:48:14 GMT
Am very interested in one of those heaters, do you have a link you can post & any idea of how hot the flue getts? I ask as my garage is timber frame construction with celotex insulated walls clad with cementatious panels external and ply/ plasterboard internally.
Jan 29, 2019 12:28:55 GMT
New third gear cluster and mainshaft for the Panther gearbox rebuild. Johnny Bravo stuff tomorrow π Good beer choice. The gear in the background seems to match the Panther's original weakness!
Jan 29, 2019 13:25:32 GMT
New third gear cluster and mainshaft for the Panther gearbox rebuild. Johnny Bravo stuff tomorrow π Good beer choice. The gear in the background seems to match the Panther's original weakness! Nope. That's what happens if you give your old toys to the MOD to play with...they shoot ten shades of Shyte out of it ππ
Last Edit: Jan 29, 2019 13:26:13 GMT by Deleted
Jan 29, 2019 13:28:33 GMT
Am very interested in one of those heaters, do you have a link you can post & any idea of how hot the flue getts? I ask as my garage is timber frame construction with celotex insulated walls clad with cementatious panels external and ply/ plasterboard internally. The exhaust gets hot enough to burn your hand on. You can get fittings designed to go through boat cabins that are double insulated for want of a better description. Have a look on EBay, type in Planar Heater.
Jan 29, 2019 13:30:39 GMT
Jan 29, 2019 14:22:31 GMT
banggood same heater: www.banggood.com/12V-5KW-Diesel-Air-Heater-4-Holes-All-In-1-LCD-Thermostat-for-Trailer-Truck-Car-p-1368620.html?rmmds=search&cur_warehouse=CNI looked at those heaters recently after doubleboost on youtube reviewed one for his machine shop. One thing to note though, I'd treat their power / fuel figures with a large pinch of salt. They claim that it uses at max 0.24 litre of fuel per hour, and given that diesel has an energy density of around 38MJ per litre, or about 10.5 kW per litre, I make it only 2.5 kW per 0.24 litre of fuel. Unless they are doing some magic to get twice the energy out of the fuel than it contains it's either only 2500w, or it uses 0.5 litres of fuel per hour
