Well, the headliner fix worked for about 5 seconds! Seemed like a good idea at the time!
I've just ordered some clear twist pins. Not the prettiest of jobs but it'll stop the headlining lining people's heads for now...
Marc
Thanks to my sons buying completely the wrong pins (multicoloured ones) I've got a rainbow effect going on with my headliner.
Haha - I'm hoping these will look inconspicuous enough. Did you manage to get the headliner taut and smooth? Any tips?
2001 Jaguar XJR ChasR
@chasr
Club Retro Rides Member 170
Oct 11, 2017 17:53:36 GMT
I'm glad you enjoyed my tales. It's good to know my misery can cheer others up . FWIW I do hope your glue was specific for car or at least from AS-Trim. I've been there before with the M3 and the Carina. In short, everything else failed . I best update the Carina thread on that.
Marc
Oct 11, 2017 18:37:01 GMT
Haha - I'm hoping these will look inconspicuous enough. Did you manage to get the headliner taut and smooth? Any tips? It's not too bad now. I think the main thing is to make sure it's taut as you go along or you end up with lumpy bit and having to start again. Good luck dude.
Oct 11, 2017 20:52:56 GMT
Well, I had a go.. looks better than it did and it's up at least. Not exactly the look I was going for, but it'll do.
@chasr
Credit where it is due it looks OK in the photos, and alot better than what it was. At least it will do until you or someone else wants to throw in another headliner .
Oct 12, 2017 11:33:49 GMT
Jag meets Chesterfield sofa - just adds to that "Gentlemen's Club" feel of an old Jaaaag!
Marc
Oct 12, 2017 11:40:08 GMT
Looks loads better than the full on Liberace look I've got going on in mine courtesy of the kids.
Oct 12, 2017 18:34:29 GMT
Cheers guys, i think I'd imagined it looking smooth and perfect after my needle-can mod... but when that failed this was my back up! It's funny; my mate commented that it gave it a chesterfield look, and completed the 'gentleman's club feel'! 😂
Oct 13, 2017 12:06:55 GMT
Why are headlings soooo difficult?
That looks really.
Oct 19, 2017 19:08:15 GMT
Well, what can i say? It's not going well. I gave it to a garage to look at alternator 'battery not charging' message, even though it is actually charging.. told them there's a cold miss I'd like looking at, too.
3 days later, after no contact (bearing in mind it had to be booked in a fortnight in advance) i call up to enquire as to the progress.
"Yeah, so it's what you said it was, needs a better quality alternator"
##I did tell you that, what's been happening for 3 days?... i think to myself.##
"Right, how much?"
"£350 all in"
"Wow. How's the missfire when cold?"
"Oh, it's got a missfire?"
## are you kidding? ##
"Right, whatever, i have literally no time to do the alternator again, just do it and forget the miss"
"Ok, it wont be until the end of next week"
"I'm coming to collect it, don't touch it again"
ian65
Oct 19, 2017 19:38:45 GMT
whereabouts are you based?
Oct 19, 2017 20:04:09 GMT
The Wirral, Merseyside.
I'm just going to buy a better alternator and fit it myself next week. Then i need to determine what the cold miss is. And one day i might drive it 😑
ian65
Oct 19, 2017 20:10:56 GMT
oh ok, shame you're not in the Midlands... I used to use a local Jag specialist who's spot on and has all the Jag diagnostic software... plus he doesn't rip you off... a sound bloke. is the miss throwing up any error codes?
Last Edit: Oct 19, 2017 20:13:25 GMT by ian65
zeberdee
Club RR Member Number: 2
2001 Jaguar XJR zeberdee
@zeberdee
Club Retro Rides Member 2
Oct 19, 2017 20:40:00 GMT
Re the miss fire , do you know when it last had plugs ? Used to change them earlier than the service schedule recommended on Range Rovers (same engine) when ran on lpg . Mostly seemed cure a slight miss .
I don't know when it last had plugs, but the miss only happens when cold, and i forgot to say that it only seems to be on idle and low revs. When it's warm it runs much better, too. There's an intermittent noise that accompanies the poor running which has me paranoid about tensioners, but it's had steel secondaries fitted and the primaries are supposed to be fine on a 2001 model.
ian65
Oct 20, 2017 17:52:15 GMT
mine made a noise from the supercharger for years with no ill effect, even after I'd had the timing chains and tensioners done.
Oct 20, 2017 20:23:03 GMT
mine made a noise from the supercharger for years with no ill effect, even after I'd had the timing chains and tensioners done. Well that's one of the first encouraging things I've heard since i bought it! Wish i knew what the cold miss is though... Picked it up from the cowboys this evening - had another awesome drive in it. I love the seating position, the noise, the power. It's an absolute beast. I just need to determine what this cold miss is, remedy it and then drive the hell out of it.
ian65
they're complex animals to diagnose... you can probably fix it yourself once you know what the problem / duff part is but to diagnose the fault the easiest way ( and probably cheapest in the long run) is to take it to a Jag specialist with the proper Jag software or autoenginuity to find the fault for you... you can then take it from there.It'll only take them 10 mins to scan the car. Have you tried a cheapo ebay OBDII code reader?, this is the one I bought...I used to keep it in the boot! www.ebay.co.uk/itm/Jaguar-Car-Fault-Code-Reader-U480-Engine-Diagnostic-OBD2-OBDII-ELM327-SCANNER-/142535595326?hash=item212fc8953e:g:1KEAAOSwIgpZ3VEmcheap as chips and amazingly it pulled out a surprisingly high number of codes out of my XJR.. you only have to go over a bump in these cars for the engine management light to come on... one of these cheapo code readers will reset the EML... maybe worth a go. It comes with a list of generic fault codes but you can download the Jaguar specific codes anywhere off the net. Obviously, it won't pull out as many codes as the proper Jag gear a specialist has and it won't pull codes out of abs or airbag modules but it's worth a go for a misfire, plus it's a dead handy thing for a XJR owner to have ... in fact, they should come as standard in the toolkit as they are the thing you'll use the most.
Last Edit: Oct 21, 2017 6:37:04 GMT by ian65
