I leave the bent seal cut a little long like on the left side of the picture. That allows them to crush down and form the seal. I’ve never soaked the gaskets first (not saying it’s wrong) At the gasket joints I use a small amount of Permatex gray. I’ve never had a leak. The centrifugal filter works quite well if it’s cleaned regularly.
flashelmer
I'm a Fiat man!
Feb 12, 2018 13:40:36 GMT
So, oil sump time!
After listening to above mentioned advice I complemented it by some googling and then set to work. I soaked the square bits in oil, pressed them in place, and cut them 2-3 mm above the sump flange. I then dressed the ends of the flat bits to fit the flange and fastend them by adding a thin smear of Loctite flange paste.
Another thin smear of flange paste was added to the block and the oil sump was screwed in place using Allen screws. Here the first drawback of a winged sump became obvious. Access to the screws was not easy... However. The Swedish cinnamon roll method was used to fasten the screws and it turned out quite nicely.
The next drawback of a winged sump became obvious when I tried to put the exhaust back. The wing on the sump wouldn't let the exhaust box slide in place on the collectors. And I didn't want to loosen the manifold from the head (in retrospect it would have been easier and quicker though...). I resorted to brute force! A two ton ratchet spanner, a three ton trolley jack, a crow bar and a selection of strong words and VIOLA!
The third, and final, drawback of the winged sump was that the flywheel cover did not fit. That was easily rectified with my angle grinder though :-)
My previous two 850s were both missing the protective covers underneath the engine compartment. Om this car they were in place and covered in half an inch of underseal. I gave them a good clean, saved a few kilograms, covered them in a thin layer of new underseal, and screwed them in place.
And the result: A lower rear end with shiny sump, straight fitting exhaust and bottom engine covers. OH YEAH!
Last Edit: Mar 14, 2018 15:40:20 GMT by flashelmer
Feb 12, 2018 15:43:43 GMT
That is a very cool little car. I too have a soft spot for wee Italian cars. Drove the wheel nuts off an 903cc 127 shortly after getting my license. Became adept at changing head gaskets in no time.
Feb 12, 2018 16:24:58 GMT
You probably know this but those covers are to make sure the hot air exiting through the radiator does not get sucked back in by the fan. Glad you installed them here. I’m surprised your previous cars didn’t overheat, must be the mild Swedish climate.
Beware of the positive camber you get by using this kind of plate. I am still planning to weld extensions on the hubs. that way you 2,5cm lowering.
tristanh
Routinely bewildered
Apr 10, 2018 19:47:52 GMT
I love this car, and those rims. Nice arch work
Apr 10, 2018 22:04:02 GMT
I love this car, and those rims. Nice arch work I agree, a great car indeed
Apr 11, 2018 13:32:26 GMT
Arches look great
thebaron
Over the river, heading out of town
Apr 18, 2018 16:16:39 GMT
I continue to love all of the tweaks you are doing to this.
Keep up the excellent work.
flashelmer
I'm a Fiat man!
Apr 23, 2018 18:31:13 GMT
I continue to love all of the tweaks you are doing to this. Keep up the excellent work. Thanks a lot! I do it My Way
nice "roadkill" solution on the gastank..haha
Paul vanderheyden once told me the hole in the lowering tabs should be 25mm lower and 3mm more to the inside. this should give -1,5 camber.
How did you make the replica instrument panel? nice work. An original is like made of gold and not to be found..
flashelmer
I'm a Fiat man!
May 30, 2018 17:58:58 GMT
nice "roadkill" solution on the gastank..haha Paul vanderheyden once told me the hole in the lowering tabs should be 25mm lower and 3mm more to the inside. this should give -1,5 camber. How did you make the replica instrument panel? nice work. An original is like made of gold and not to be found.. It has turned out a bit more RoadKill than I expected it to. Fouling wheels, bodged fuel supply and no working instruments... Speaking of Roadkill - My favorite quote is "No amount of Duct Tape can fix this!"
I bought the replica instruments from a bloke in Italy who makes them. I can send his contact details to those who want them.
Clement
ambitious but rubbish
I only just noticed this while looking for Giulia stuff - lovely 850 Enjoying the warm summer much?
