tee
Sept 22, 2017 20:35:44 GMT
So had someone coming down to pick it up and lo and behold I can't find the keys, they may be in the car but unlikely, it's a single old skool basic key like a Yale one.
How do I go about getting in to the car and making a new key?!!
Thanks in advance
T
squonk
Sept 23, 2017 19:11:39 GMT
The usual solution is to break a window (normally the cheapest/easiest to replace) but on an older Yank motor that may not be a good idea!!
Is the boot locked? Can you open it and undo the back of the rear seat from within the boot.
Then of course there is the bent wire coat hanger trick.
Or if the locks are worn you could just try a selection of keys and hope that you can find one that will open it.
Once in there, if you remove one of the lock barrels a locksmith should be able to cut a key for it.
barty
Sept 23, 2017 19:45:50 GMT
Might be worth phoning a mobile locksmith I'm sure they have dealt with this many times ( ask for a price first) let us know how you get on
Aug 28, 2020 12:29:23 GMT
Aug 28, 2020 13:48:30 GMT
Old yank...coat hanger will work to get you in for sure.
Sept 8, 2020 16:38:18 GMT
Old yank...coat hanger will work to get you in for sure. Are you replying to the mobile locksmith post shared above ?
Sept 8, 2020 16:45:45 GMT
The plastic strapping you get around parcels etc will get you in.
Rich
Club RR Member Number: 160
Sept 8, 2020 17:12:14 GMT
The plastic strapping you get around parcels etc will get you in. This thread is old and was bumped by an advert. I should imagine the OP has dealt with his lock issue by now.
Sept 8, 2020 18:23:12 GMT
oops my bad
Sept 8, 2020 18:41:38 GMT
I guess he had found them by now then!
