Sept 15, 2017 9:33:29 GMT
I have welded an exhaust cat onto a standard decat pipe as it needed one for the MOT, and the fit meant the join wouldn't seal corrected on the cat unions. Everything is fine now, but my welds have tiny holes that's are blowing slightly. Is there any way of sealing the welds from the inside? Exhaust paste is always wibblepoo as moisture just makes is soft again. Is there anything else I could try, at least to get it through the looming retest? I know I could weld it properly but that's not what I'm asking.
Sept 15, 2017 14:15:28 GMT
Not sure about inside but I've used a bit of chemical metal on pinholes before, worked a treat.
Last Edit: Sept 15, 2017 14:28:53 GMT by astranaut
Sept 15, 2017 15:03:59 GMT
more weld.
anything else is temporary and will hinder any subsequent proper repair.
fad
Sept 15, 2017 18:51:10 GMT
Second vote for moooaaarrr weeellldz. Bigger the blob, better the job, right?
Seriously just crank up that heat and seal her up. Nothing else will hold.
Sept 15, 2017 19:35:57 GMT
Expanding foam will seal if from the inside
fad
Sept 15, 2017 20:07:42 GMT
Expanding foam will seal if from the inside Good for tracking down the car if someone nicks it too! Just follow the trail lol
Sept 16, 2017 9:27:49 GMT
Exhaust paste then an alloy tin can over the top of it to stop the paste blowing away, secure with a jubilee clip or 2. You could use chemical metal in place of paste, not sure how it handles heat though.
I used Loctite Flange Gasket stuff and it's set inside nicely and doesn't blow. I was reading moisture cures it.
fad
Fnar fnar! You used the words "flange", "blow", "(lock)tight", "inside", and "moisture" in the same post.
mk2cossie
Club RR Member Number: 77
Fnar fnar! You used the words "flange", "blow", "(lock)tight", "inside", and "moisture" in the same post. And "stuff"
taurus
I had to do a temporary bodge when our daughter's exhaust fell of one dark wet night and all I had to hand was standard Isopon body filler. I stuck it back together with that and told her to bring it back next week and I'd weld it up.
Nine months later the Isopon is still holding it together. I never realised it would take the heat to be honest but it's still rock solid.
My friend also said body filler! My exhaust was banging on the underside today so checked it over and the flange gasket stuff was set rock hard, (ooer) and looks tidy as well.
Last Edit: Oct 5, 2017 23:07:29 GMT by DavidB
Oct 12, 2017 14:24:49 GMT
I had to do a temporary bodge when our daughter's exhaust fell of one dark wet night and all I had to hand was standard Isopon body filler. I stuck it back together with that and told her to bring it back next week and I'd weld it up. Nine months later the Isopon is still holding it together. I never realised it would take the heat to be honest but it's still rock solid. +1 This worked for the standard exhaust on my Fiesta when it rusted through, it held up for the MOT and didn't blow at all for months after.
F503 FRM - MK2 Ford Fiesta - (Mo Filla, No Thrilla)
T527 LCJ - S2 Peugeot 106 - (Donor car for an AX GTI - scrapped) CA57 GWP - MK6 Fiesta Zetec S - (Daily derv go-kart)
