fad
Sept 14, 2017 11:06:56 GMT
So I brew cider. Have had some roaring success, some utter failure, but not killed anyone yet. Grizz's foraging thread made me think "Hmm, I'll go pick blackberries" and came back with 2kg or so. Decided to make blackberry wine . Aiming for about 6-7% with it, so nothing too lethal. The last batch of cider I made was a honey and ginger, and also a caramel apple. They were both WELL North of 14%... This is the ginger in primary (only did a small 15 litre batch of each) After racking and secondary fermentation (was a fizzy batch) Don't worry I don't bottle into pop bottles, that there is my "canary", handy so you can "feel" how carbonated it is by the pressure in the bottle and you can see how your cider is doing really clearly. This is the batch after secondary and pasteurisation to prevent further fermentation in the bottles: Ginger (which was a pale golden clear when it was ready to drink) This is a mix of still and sparkling caramel apple, which was still cloudy and toffee coloured when it was ready to drink, even after months of maturing (I used unfiltered, raw squeezed juice for it. Tasted amazing!!) Donated most of that the the summer BBQ at the uni. It went down rather well, despite the strength of it. Next time I will be aiming for roughly half the strength, both were just too drinkable and smooth for the strength of them, especially the caramel apple!
Last Edit: Sept 14, 2017 11:08:57 GMT by fad
Sept 14, 2017 11:58:55 GMT
Is there any skill you haven't mastered‽
fad
Sept 14, 2017 12:06:25 GMT
Is there any skill you haven't mastered‽ Financial management Pleasing women Remembering birthdays Weirdly, I can't for the life of me mix mortar properly either... LOL
Sept 17, 2017 8:07:29 GMT
Hmm, cider. Don't notice how full you're getting until you go to move and can't.
fad
Sept 19, 2017 12:45:23 GMT
Had a blow out last night. Cider absolutely everywhere. The only thing I can think of is the airlock blocked with some raspberry and then blew through. Ah well! Fingers crossed it won't happen again, the missus was NOT happy about the clean washing in the utility room! LOL!
Sept 20, 2017 7:06:49 GMT
Would you mind to share your recipes?
All I have done so far is a (very) sparkling hard cider from our apples that everyone considers too sour to eat. Needed a healthy dose of sugar to come out at ~10%, but the aroma is great. And I think I overdid the sugar shot for carbonisation a bit, champagne has significantly less fizz ;-)
´39 Triumph T100 bobber ´70 Zündapp R50 ´71 VW 181RS ´76 VW Passat Variant i ´08 JEEP Commander 5.7 Hemi ´15 Mercedes E300T BlueTec
fad
Sept 20, 2017 9:09:34 GMT
Hahaha! Sounds good though!
Well, recipes.
Blackberry wine (VERY easy!).
You will need: blackberries (loads of them) Sugar Water Wine yeast Yeast nutrient A fermenter (a bucket with a cloth over it will do in a pinch, but a fermenter with an airlock will give better results) Something to "rack" it into (demijohns are ideal, but you can use wine bottles, whatever. just make sure the glass is clear so that you can see your brew) A tube to siphon Some muslin cloth Ideally a hydrometer, but not essential
BEFORE YOU START!!! Everything you do, every bit of kit you are gonna use, must be utterly spotless and sterile. This is for your own good, you don't want to breed the wrong kind of microbes! But don't worry, it will be very, VERY obvious when you have an infected brew but if in doubt, PM me! Use sterilising powder on everything, have an epic washing up session (wear rubber gloves), and rinse rinse rinse and rinse some more.
1) 2-3kg blackberries fora 5 litre yield. You can use frozen supermarket ones but you don't really have an excuse, since they are EVERYWHERE this time of year, go out picking in the hedgerows! Wear rubber gloves (you'll thank me later). When picking, if the blackberry doesn't come away nice and easy, leave it. For info, a Celebrations / Heros / Roses tin when full holds about 2kg. 2) Freeze them 3) Take them out of the freezer, stick them in a very large bowl (or a pan if you have a jam pan), and tip boiling water over them until they are just covered, measure how much water you chucked in (if they are in a pan, stick them on the heat for a bit to get them boiling then take it off the heat, if in the bowl don't worry too much). 4) Mash the berries with a spud masher (don't use a blender unless you like fruit mud) 5) Chuck a crushed camden tablet in and give it a stir, cover and leave to cool 6) Throw the lot into a fermenter (you can use a big bucket with a cloth over it, I use fermentation vessels with air locks, depending on what I am brewing. I brewed this in my glass one with a heavy loose fitting glass lid with a rubber seal to allow it to burp - Wilko's do a 25 litre fermenter with a tap that is a bargain and perfect for this) 7) Make up the mixture to about 6 litres for every 2.5kg blackberries, give or take. Depends how strong a blackberry taste you want. 8) If you have a hydrometer, add sugar until you have a starting gravity of about 1.07-1.08. If you don't have a hydromter, you want about 1.4kg sugar for every 6 litres of liquid for a brew that will come out at around 7-8% if you don't let it ferment too far! Be VERY careful though, you don't need much sugar to make crazy strong brews that sail North of 20% with wine yeast. MIX IT VERY VERY WELL! (top tip: Add a little boiling water to the sugar to make a solution and add that to your brew, it's easier to mix then!) 8a) If you wanna be sexy, add honey instead of sugar. I use a 50/50 mix of brown and white sugar to add some depth of flavour. 9) Add wine yeast and yeast nutrient (you don't HAVE to add nutrient, but believe me, you want to!! Have you ever smelled a rhino fart? Well, thats what it will smell like if the yeast doesn't have the right nutrients. Your choice...) 10) Leave it somewhere room temperature, you don't need it anywhere temperature controlled, but the warmer it is, the faster it brews. 11) If you have a hydrometer, test it every day until you reach the desired gravity (using the starting gravity and the current gravity you can calculate your ABV). If you don't, but you have used an air lock, wait until it stops bubbling. If you are using a fermentation bucket, it's guess work, have a taste, and when it tastes "right", you're done. 12) Siphon from your primary fermenter into your demijohn or wine bottles, using the muslin cloth as a filter. You can tip it from your bucket if you like, but you will make a mess and it's a bit of a pain. Leave the sludge and mess in the bottom, you are just after the liquid, so allow a litre of wastage 13) Stick a cork / top on the bottles / demijohn and stick it in the fridge (this is called cold crashing). If you want, add wine finings (Wilkos have it) to help it fall clear. 14) You will notice after a few days a nice layer of sediment in the bottom. You can either leave it in the fridge, and drink it as is as a "young" wine, pouring carefully to avoid the sediment (it will taste a bit yeasty if you get sediment in your glass), OR...
EXTRA STEPS (PLEASE READ ALL BEFORE DOING ANY OF IT!)
15) You can rack it again with a siphon into another clean bottle to leave the sediment behind if you want to let it age and mature. Just siphon carefully and avoid sucking up the sediment. If you are going to do this, you then need to pasturise if you aren't going to keep it in the fridge otherwise it may ferment further in the bottle, which can create bottle bombs... 16) To pasturise, get a big pan of water, heat it to about 85 degrees C, take it off the heat, pop the bottle in with the lids on, cover with a cloth and leave for 10-15 mins. Repeat for each bottle. 17) Leave it to mature somewhere cool.
IF YOU WANT FIZZY WINE
18) If you want it sparkling, then you DON'T want to pasturise. After you have taken it out of the fridge and re-racked to get rid of the sediment, instead we are going to add a small amount of sugar. This is difficult to get "right" first time. But you want about a teaspoon and a half for every 500ml liquid, assuming you have a completely dry, fermented out wine. If you don't, then you need to know how much sugar is left from your primary fermentation and this needs a hydrometer and some maffs. But we're not gonna do this, cos it's home brew, so we're gonna just give it a go. 19) Pour the sugar into the bottle, but you MUST use bottles that can handle pressure. Champagne bottles with proper corks, or PET bottles, clean fizzy drinks bottles, are all good for this. Give it a shake, leave it somewhere warm, and wait for a few weeks. The longer you wait, the better it will be. If you used plastic bottles, this will be useful for checking the pressure since you can squeeze and feel it. 20) If you have plastic bottles, once they are hard like unopened fizzy drinks bottles, stick them in the fridge to keep it from brewing further (doing this will give you a sweeter, less fizzy brew. If you leave it to ferment dry, you will have a dry, more fizzy brew. It's a bit of an art knowing when to stop the fermentation).
Anyway, that's the easiest brew. It's free, fairly quick, tastey, free, easy, free, fun, free, and, er, free. (apart from the sugar!).
If you want to alter the flavours, you can try: Adding a couple of good handfuls of raisins to the primary fermenter at the start of brew for the tannins in the skin Adding some malic acid (powder form) to add bite and sourness Adding wine tannins for more depth of flavour Adding apple juice to make more of a cider than a wine Adding more sugar for a stonger brew A mix of berries for a more summery drink (save till next year, it'll be lovely by then)
Brewing is a bit of an art, you get a feel for what works and what doesn't. What flavours work for you, and what don't. Most of it hinges on what you have available at the time, and knowing what will go with what. ]
Just follow the golden rules:
Sterilise EVERYTHING - be scrupulous with your cleaning Don't use ANY ingredients with preservatives in them Don't try to ferment artificial sweeteners Give it love and care and pay attention to it Sample your brews in moderation if you haven't calculated your ABV accurately with the correct equipment - home brew can be frighteningly strong. Avoid drinking sediments as best you can, unless your stomach is accustomed to it (it's not harmful, it just messes with your guts a bit) And lastly, PATIENCE! The longer you leave a brew to mature, the better it is. If you try something that is undrinkable, don't tip the rest of the batch away, let it mature out. Time can hide lots of sins!
Last Edit: Sept 20, 2017 9:17:26 GMT by fad
Sept 20, 2017 11:04:27 GMT
Great writeup, thank you very much for the fun read!
I´m not too much into berry wines, but I think I will give it a try. When I don´t like it, it can always take the trip through the still...
But tbh I was more interested in the ginger and caramel apple stuff :-)
fad
Sept 20, 2017 12:13:03 GMT
No problem. I shall put that here:
Caramel Apple
For a 1 gal batch:
Ingredients: 250g brown sugar 250g honey 4-5 litres apple juice, make sure it is JUST juice, no preservatives etc. From concentrate is "ok" but real pressed apple is ALWAYS better. Wine yeast
1. Stick the sugar and 1/2 cup apple juice to a pan. Caramelise on medium heat for around 15 mins. NOTE: If you want this to be a clear cider, substitute the half cup juice for water. Alternatively, add pectin at step (available from Wilkos) 2. Once sugar is caramelised, add to fermenter. The darker the caramel mixture, the stronger the flavour. This is totally up to you and your tastes, experiment a bit. FFS, if you are using a plastic fermenter, then LET IT COOL FOR A BIT OR ADD JUICE FIRST! 3. Pour half of your juice into the fermenter, add the caramel, and shake, rattle n roll! Get it really whizzed up to aerate the mixture 4. Add the rest of your juice, slosh it around in there. 5. Throw in the yeast and some nutrient (if you have it) 6. Ferment till dry, and yeast clears (you;ll see it all drop to the bottom and form a sediment, and it will stop bubbling). 7. Stick the honey in a pan and caramelise to taste. 8. Siphon half of your cider into a sterile demijohn or whatever, and add the honey mixture. 9. MIX. It will take AGES to get it mixe properly, but you'll get there. Then add the remaining cider. 10. Bottle and pasteurise as per the last recipe with the pan of water etc.
You MUST MUST MUST pasturise this one, otherwise it WILL make apple champagne or bottle bombs. Keep it in the fridge too. If you like, leave it a week before pasturising so that you have a sparkling cider.
It will come out sweet, smooth, very strong, and very drinkable.
Last Edit: Sept 21, 2017 7:07:00 GMT by fad
