Aug 19, 2017 13:11:40 GMT
Neighbours 2004 suzuki ignis petrol will start with a jump drive all day with no issues. But still has a dead battery
I used multimeter set to 20 as per you tube and I have zero reading engine running.
Engine running lights on etc car runs fine no stalling
It seems like there is simply zero charge getting to the battery
Any suggestions please
Cheers
Bm
Toyota HiAce Super Custom Ltd (My thing) Isuzu Trooper (her thing) Audi a4 1999 (boys thing) Toyota Yaris Caravan - (festi thing)
Aug 19, 2017 14:58:04 GMT
Hi, Where are you trying to measure the voltage?
Colin
Aug 19, 2017 15:12:44 GMT
Positive and negative lead at battery
fad
Aug 19, 2017 16:22:30 GMT
You set to DC not AC?
If you see zero volts on the battery with engine running, it ain't connected to the alternator and the battery is completely flat (unlikely), or the meter is busted.
Test the meter on something like a bulb when its on to make sure its working.
Last Edit: Aug 19, 2017 16:23:00 GMT by fad
Aug 19, 2017 16:46:50 GMT
Battery is flat not sure if totally flat but not enough to light dash lights up or even click ignition
It's set on 20 v -...
Will check on bulb tomorrow but have used it previously so should be working okay
So if it's not getting charge from alternator what can I check?
Car can run fine once started just won't charge?
Thanks for time and replies so far 😊
fad
Aug 19, 2017 16:59:54 GMT
Set to 20v AC or DC? *edit* just saw the -... After "20v" is that the symbol you have?
Are you measuring with both engine running and engine off?
If nothing when you turn the key, its either totally knackered and inert, or its not connected.
When you jump, is that from the battery terminals?
Is the battery sealed type or can you open it?
Its pointing towards a battery that is knackered or bone dry. If you can open it, look to see if there's any acid left in it (ffs be careful), but you won't be able to fix that anyway. You MIGHT get away with topping up with de-ionised water but if it really is zero volts on the terminals the battery is toast.
Last Edit: Aug 19, 2017 17:01:42 GMT by fad
Aug 19, 2017 17:11:46 GMT
Set to 20v AC or DC? *edit* just saw the -... After "20v" is that the symbol you have? Are you measuring with both engine running and engine off? If nothing when you turn the key, its either totally knackered and inert, or its not connected. When you jump, is that from the battery terminals? Is the battery sealed type or can you open it? Its pointing towards a battery that is knackered or bone dry. If you can open it, look to see if there's any acid left in it (ffs be careful), but you won't be able to fix that anyway. You MIGHT get away with topping up with de-ionised water but if it really is zero volts on the terminals the battery is toast. Yes that's the one I'm using the 20v-.. Nothing when engine off and nothing when engine running. I stick the pointy leads into the battery terminals. Yes jumps from the battery terminals Not sure about battery. But neighbour says less than a year old. My concern is that I thought I would get some reading with engine running at battery terminals? Cheers
Aug 19, 2017 17:34:27 GMT
Check that your multimeter is working properly first, and that you have it on the correct setting, by using it on a domestic battery (an AA or AAA for example from a known good battery from a remote control) and see that it shows 1.5v.
fad
Aug 19, 2017 17:34:31 GMT
You should get a reading for sure. I'm wondering if the battery earth is connected or your meter is working.
Set the meter to Ohms (horseshoe symbol) and touch the pointy probes together. It should read zero, if it doesn't, check your connection for the leads then test again. Once it reads zero... Test voltage on a bulb that's on, or a battery,or something.
Measure voltage again but put the red lead of the meter onto the positive post. But the black negative lead to something clean and metal under the bonnet that is connected to the chassis. What do you read there?
OR
Put one pointy wand in the negative battery terminal, and the other on the engine somewhere nice and metallic. Should read zero. If it doesn't, move the engine probe to a few more metal places under the bonnet. If you don't get zero, then the earth is not good / connected.
Its really, really strange symptoms though.
Last Edit: Aug 19, 2017 17:35:53 GMT by fad
Aug 19, 2017 17:54:53 GMT
Many thanks will give it another go tomorrow.
Silly question but could it be something like a fuse link wire similar to the old ford's?
Aug 19, 2017 18:01:32 GMT
Checked leads and on all settings under the horse shoe it reads 1 😯
Aug 19, 2017 18:15:10 GMT
Think multi meter is U/s as tried a house hold battery on every setting and nothing
fad
Aug 19, 2017 18:16:08 GMT
You have a busted lead or it is connected wrong.
Can you take a pic of how you have the leads? Suspect you have it configured for current.
Last Edit: Aug 19, 2017 18:17:06 GMT by fad
Aug 19, 2017 18:52:38 GMT
fad
Aug 19, 2017 19:20:39 GMT
Fuse might have gone inside the meter. Or one of your leads is kaput.
Aug 19, 2017 19:23:47 GMT
Will get another as tried it on the Honda and still nothing
Fad thanks for all your help tonight appreciate it.
Cheers
Michael
fad
Aug 19, 2017 19:42:38 GMT
To be fair that type of meter is not fantastic. But works OK for what you are doing with it.
All a moot point, it is pointing to a duff battery. Have a look in the battery at the fluid levels and top them up with deionised water.
Aug 20, 2017 15:01:23 GMT
Update. Car is now mine
Battery is sealed unit but will still top it up and see how it get on. I can pop a known good battery on from my other car.
Will not be doing much on it next few days as getting Volvo mot then leeds festival Thursday!
Seem to be up and down the A1 loads at minute just back from Morpeth!
Cheers and will keep post updated with end result 😊
fad
Aug 20, 2017 15:02:52 GMT
Back from Morpeth?? That's about 10 miles from me lol
Aug 20, 2017 16:11:35 GMT
Born and bred in Morpeth. Left a good many years ago . . Ten miles either Alnwick or Gosforth lol. Actually mentioning Alnwick spent loads of time with my grandparents in Felton thex had the pub there.
