Aug 15, 2017 22:54:35 GMT
Can any one help me to identify this duel circuit brake master cylinder?
The part number is :66291 02 60/40 44AK and this is the cast number on the side of the master cylinder :GC64679597044
Any and all help appreciated.
Last Edit: Aug 15, 2017 23:01:36 GMT by peteh1969
Aug 22, 2017 17:57:37 GMT
Don't know what it's off, but I need something like that.
Aug 22, 2017 19:14:35 GMT
I was told that it was originaly bought to go in an Escort but it's a North South mount that I need to go in my Corsair I have checked with Noerthwest Classic and they say the part number is not Girling and I would like to ID it propely so I can get a service kit?
Aug 23, 2017 18:04:08 GMT
I might be a Vauxhall man but is it not a drum brake Cortina master cylinder of some sort?
colnerov
Aug 23, 2017 19:00:43 GMT
Hi, Because of the shape of the reservoir and its attachment I would say it's Girling, the pushrod indicates it's non servo operation. The fact the high pressure outlet ports are on the left say's that it's for fitment in the left hand side of the engine bay, so they don't foul the inner wing. So weighing those up I would say it's for use with a remote linkage across the engine bay of a front wheel drive car of smallish size, something like a Fiesta or Mk3 escort.
Colin
Last Edit: Aug 23, 2017 19:01:40 GMT by colnerov
Aug 23, 2017 19:28:46 GMT
Well Colin I understand what you’re saying and agree but all of the info I have found with duel circuit fitted Corsairs the rear section feed the rear drum brakes and the front section feed the servo and then the front discs and the diagrams I have shows the pipe work connecting to the master cylinder from the left looking from the front of the car and the bends are tight but possible and the duel circuit system was fitted to export Corsairs in the colonies only (it was the 1960's)
colnerov
Aug 23, 2017 20:02:12 GMT
Hi, Pete, you're clearly more clued up on export Corsair's than me, lol. Having read the thread properly and your second post in particular, those dual circuit M/C's are fitted to some Series Land Rovers (but they're east/west flange so no good for you and are also Capri fitment as well) so as long as you know what bore size it is you should be able to get a service kit from either a LR or Ford supplier.
Hope this helps.
Colin
Aug 23, 2017 20:10:45 GMT
Well It's a 3/4" bore MC same as my single circit MC I will check with those suppliers.
Thank you Colin.
Aug 23, 2017 20:45:41 GMT
Could you not send it to somewhere like www.pastparts.co.uk/ and get it sleeved in stainless and rebuilt? Sorry if I have misread what you want to do.
Aug 23, 2017 20:55:37 GMT
The MC dose not need sleaving and all I want to do is to dis mantle it and clean it but I want to get a seal kit before I strip it incase something get damaged or broken during the dis assembly. A seal kit will be cheap compaired to having a sleve fitted.
Aug 27, 2017 15:20:30 GMT
The MC dose not need sleaving and all I want to do is to dis mantle it and clean it but I want to get a seal kit before I strip it incase something get damaged or broken during the dis assembly. A seal kit will be cheap compaired to having a sleve fitted. They do a lot of mc's so still worth a try for a seal kit and identification.
