heathrobinson
Broken everything
Club RR Member Number: 111
Square headlights, where from?heathrobinson
@heathrobinson
Club Retro Rides Member 111
Aug 14, 2017 16:08:09 GMT
Hi all. My Winnibago has 6x4 rectangular headlights, which are frankly awful. I've searched high and low, but I can't find any that are right hand drive. Anyone have any suggestions? Ta!
Rob M
Club RR Member Number: 41
Aug 14, 2017 18:08:51 GMT
Hi all. My Winnibago has 6x4 rectangular headlights, which are frankly awful. I've searched high and low, but I can't find any that are right hand drive. Anyone have any suggestions? Ta! You can try what I have just done ( last night) when looking for headlights for my Firebird. I was advised to go on the Rock Auto US site where they were very very cheap, I found some but postage to the UK was going to be £34.00 so......... I looked at the makes available, in this case Phillips, and noted the serial number for them. I then went onto flea bay, typed in Phillips and the serial number and BINGO, Ive bought a pair for £20 with free delivery. The link I'm adding was for my particular search but it should help you type in the correct key words to do a search for yours. Needles to say, my headlights are generic to other cars like Toyota and are for RHD. Hope that helps.
Last Edit: Aug 14, 2017 18:09:25 GMT by Rob M
Aug 17, 2017 21:18:33 GMT
Hi, Hilllman Hunter are 6x4 (and much improved by swapping to 7x5 from a Mk1 Escort or similar ) I get most of my Hillman spares from Speedy Spares, you might find they have Hunter lights in stock...
logicaluk
Aug 26, 2017 20:00:39 GMT
funnily enough i was having this conversation with a mate last night, triumph acclaim head lamps are a direct fit.
Dan
i had a set from the states for my hearse, they don't have a traditional beam pattern but as there are 4 i have the nearside set higher than the offside, not to mention H4 bulbs which help a lot. Rockauto are ok, but do expect a thrashing on the import duties. I prefer ebay as you can often avoid import duties through that avenue.
'88 Cadillac Brougham hearse (white) '91 Carlton GSi 24v '72 Dodge dual cab pick up '99 Mercedes S55 AMG
heathrobinson
Broken everything
@heathrobinson
Aug 27, 2017 11:33:07 GMT
The Acclaim headlights are a good shout, and it also seems to be a tractor size, so I'm going to bung my nose into Sparex when I'm next passing their warehouse.
