randomeddy
Enter your message here...
Aug 12, 2017 17:54:40 GMT
The only way we can get the temperature gauge to register in the AE86 is to earth the body of the temp' sender.
There are two earths on the engine, one on the block and one on the head. We cleaned them both and made sure they were sound. We just thought it would earth through the thread of the sender but not having it.
We have had to run a separate wire to make the gauge register. (Botched it for the minute, car is not on the road yet so no matter).
Any ideas?
Last Edit: Aug 12, 2017 17:55:33 GMT by randomeddy
Have you been mis-sold TDi.
Aug 12, 2017 19:41:02 GMT
That's sounds really odd. I'd take the sensor out and clean the threads up. Have you tried a meter on the sensor and the head to see if you have continuity?
bortaf
Aug 12, 2017 20:28:44 GMT
Is the head earth on a manifold or the rocker cover ? i used to have issues on old fords when the head earth was on the rocker but not when on the manifold with the temp sender, i allways put it down to the thick rocker gasket preventing a good earth although you'd think the bolt passing into the head would be ok but no allways ?
R.I.P photobucket
randomeddy
That's sounds really odd. I'd take the sensor out and clean the threads up. Have you tried a meter on the sensor and the head to see if you have continuity? Cleaned the thread thinking it might have had something on to stop a leak etc. Put a new sender in just to be sure.
randomeddy
Head earth is on the lifting eye. That is bolted straight into the head where the sender is screwed into. It took some head scratching to get the gauge to actually register. I earthed the connector to make sure the gauge actually worked and it went up to the top. It has always registered cold but would not go up to show the actual temperature. It has the digital dash fitted so we were dreading it being faulty.
Aug 15, 2017 21:24:18 GMT
Is it single or two wire? Sounds like a duff temp sensor or not the correct calibration resistance to the dashboard ... ?
randomeddy
Aug 24, 2017 20:51:38 GMT
Is it single or two wire? Sounds like a duff temp sensor or not the correct calibration resistance to the dashboard ... ? Tried a new one,still not working. It has a single wire to it. Interesting comment on it not being exactly the right one.
Aug 24, 2017 21:27:28 GMT
I could be wrong but I think a digi dash corolla has different engine sensors than an analogue setup.
randomeddy
Yes, I knew that one about earthing it to check the actual gauge was 'alive'.
