Innovation Motorsports LM-1 Digial Air Fuel ratio meter and data logger.
£30 collected from Bognor Regis area
£40 posted to UK mainland.
email volvo@wocketfast.com
Essential for car tuning, maintenance and performance monitoring.
Test and working, these are expensive bits of kit, but well worth the money. Ideal for tuning turbo cars where you are raising the boost as you can monitor if you are starting to run too lean and avoid detonation occurring. Even modern cars.
Essential for tuning any car with a carburetor, basically you cant without one of these.
A serious bargain, but I do not need it any more and just discovered it when clearing out.
Comes with
Comes with
- LM-1 data logger
- Cigarette lighter socket power
- Wideband O2 sensor (Bosch) with very long lead which can be inserted into the exhaust for a zero tools solution.
- Weld on fitting for sensor to install into your exhaust should you want a more permanent solution
- Serial cable
- PC Software
