Alright everyone,
After many years of regret for selling my mk1 caddy I'm looking for another one to fill that caddy shape hole. Ideally if it could be based in the North West England, reasonable condition not afraid of it being too battered as long as rust is too a minimum. Not fussed about engines would prefer the original little DIESEL and a not if poss.
Can anyone help?
Thanks
Last Edit: Aug 17, 2017 19:54:35 GMT by langsam
Aug 16, 2017 16:37:41 GMT
Realised I'm asking way too much for one on my door step so willing to look further for the right one.
Aug 16, 2017 17:59:57 GMT
check done deal they keep coming up
Aug 17, 2017 19:53:52 GMT
Cheers will keep a look out.
Aug 21, 2017 11:22:26 GMT
Trying to flog mine: MK1 Caddy 1.9 MTDI £5,500 Rhôs-on-Sea Seeing if there is any interest on here really. For sale is my MK1 caddy. Will come with 12 months MOT at point of sale. Meganne steel wheels with nearly new toyo proxes t1-r's all round plated rear axle dropping 110mm. Blue speedliner sprayed into the rear. Seats are recaros from an accord Type R, Dash was made to suit me application which is a carbon panel with some temp gauges and the GPS speedo from a boat. Engine is an AGR from a mk4 golf, with a 300dti bosch manual pump mounted to it. Standard turbo and injectors, boost is set at 27PSI currently. Engine has PD180 head studs and a G60 head gasket to hold the boost pressure. 3" down pipe with no silencers straight to a 1.5"x5" oval side exit poop shoot. unless rolling onto the throttle the truck does do "do you smoke?" style clouds. EGR has been blocked off. Corsa B radiator head has been skimmed and all valves faced and reground. My dyno says around 160hp? Although it doesnt matter as the truck is more than a handful. Stainless rear bumpers and side bars. Alloy FMIC Standard but new brakes. all new wheel bearings although not shown in the pictures its now got porsche 944 door handles (scripted ones) I've had this truck a long time so I'm struggling to think of EVERYTHING ive done to it, so ask away. Ive done a few bits since. I should really update the add. And I'm based in north wales. Doesnt get much more north west really.
Aug 22, 2017 18:15:03 GMT
tastey indeed
Captainbland08 that is one nice caddy but unfortunately out of my price range and I don't wanna make a offer and offend anyone. Ill have to keep searching.
zipgun
Aug 24, 2017 19:59:04 GMT
I've only got a tailgate left ... had it as a spare in case i was ever it up the chuff !
