benjy_b
Yorkshire and The Humber
Jun 17, 2017 15:02:54 GMT
Has anyone got any general tips on engine swaps?
Specifically Front engine, rear wheels drive.
How would you go about positioning the engine and making the engine mounts?
Is the engine supposed to be fitted at a certain angle?
Should the Gearbox & prop be fitted at a certain angle to the diff?
2005 Subaru Forester 2.5XT 1999 BMW E36 318i Touring with OM605 Mercedes Engine 1996 Lada Riva with Honda S2000 Engine
Jun 17, 2017 16:14:11 GMT
Hi, Second question first, the angle depends on the engine and axle, some are level some have a shallow angle usually about 5 degrees down at the back. First question now, have it hanging on the hook or block up in the right position so nothing touches the bodywork then fabricate mounts to suit, usually CAD (Cardboard Aided Design). For longer universal joint life the propshaft flanges need to be parallel but offset either up, down or to one side so the joints work, if they are dead in line they can 'freeze' and have quite a short life. If they are at different angles this also can shorten their life and cause vibrations as well, although that can be mitigated sometimes.
Colin
Last Edit: Jun 17, 2017 16:16:41 GMT by colnerov
Jun 17, 2017 18:09:16 GMT
Jun 18, 2017 12:49:18 GMT
Bookmarked! General thoughts (from lots of looking into a swap, but no practical experience) Google to see what has already been fitted into your car, you might find a how-to guide. Pick an engine & box that will physically fit the engine bay and transmission tunnel to save yourself a lot of work, and possible legal / BIVA problems. Cheapest option is to buy a donor vehicle with good mechanicals, then you know you have all the bits you need. Ebay / scrap what's left and you should end up with a cheap engine. Fit the engine at the same angle it was in the original car (mine is tilted about 7 degrees from the factory, other cars from the same maker have engines vertical) Electrics - Google to see what you need to wire up to get it running. Beware factory immobilisers PATS etc. Or fit a stand-alone Megajolt type system (cost ). Use a standard propshaft if possible (shortening a prop is not cheap!) Fuel system. Changing from carbs to an injection engine will need a new fuel pump, extra piping, etc. Speedo drive (will the new system work with your clocks? cable or electronic speedo drive?) Exhaust. You might be able to join the engine to your existing system, or it might be a pig of a job. If you say what car / engine are you thinking of, folk here can advise the details
benjy_b
Jun 18, 2017 23:13:15 GMT
I'm wanting to fit the Honda F20 engine that's currently in my Corolla into my Lada. I don't think that particular swap has been done before, but the Lada is a similar size to other cars that have received the swap (KE Corolla, Datsun 510, E30, AE86, MX5)
fad
Jun 19, 2017 20:23:42 GMT
Remember to synchronise UJs too!!!!! Really important if you don't want a juddery wobbly ride. Any engine will fit in any car with enough work. I tend to cheat and find the more or less "bolt on" options. You'd be amazed at what fits to what (and what doesn't fit on what!). Porsche flat 6 into a full bodied bug? Not a hope in hell (and no I don't care what anyone thinks they have been told down the pub / at a show). Audi V8 into a Lupo? Been done
Last Edit: Jun 19, 2017 20:27:45 GMT by fad
