Turns out my wifes new jimny has a few issues.
It drove fine on test, when picked up however it has a missfire around 2500 and is flashing the check engine light.
A little reading suggests this is normaly the crank sensor.
Tried to plug the diagnostics in but there is no power to the plug. All fuses in fuse box look ok.
Had a look for the crank sensor but I'm confused. It has a senser underneath at the front of the sump but there is no wiring to it.
I'm at a bit of a loss now, I have no manual.
Its a 1999 1.3 16v.
Any ideas?
Its a 1999 1.3 16v.
Any ideas?
