A NEW set of VELOCE 3.6 Alloys in 18" 9.5J & 8J Staggered with NEW tyres
Fully refurbished with new tyres
The front wheels is 18" x 8J with ET52 offset, 5 x 130mm PCD and 71.6mm centrebore.
The rear wheels is 18" x 9.5J with ET47 offset, 5 x 130mm PCD and 71.6mm centrebore.
Fully Sand blasted and Painted in stunning silver metallic.
Tyres
The front wheels - 225/40/18's - new valves and balanced
The rear wheels - 265/35/18's - new valves and balanced
Statement taken off Veloce website
veloce 3.6
The timeless elegance of a truly Classic wheel, this Iconic design will enhance any model of Porsche from SC through to 997 and is easily identifiable with its clean flawless lines.
Manufactured by Low Pressure casting its Strength and Integrity cannot be questioned perfect for Fast Road or Track use, or simply driving with style.
The Veloce 3.6 wheel has been designed to fit all models of Porsche fitted with ABS as a DIRECT fitment 944 S2, 968, 928,964-965,993, Boxster, Cayman, 996 and 997. It can also be fitted to SC, 3.2 and Turbo 1.
