moglite
Club RR Member Number: 144
Time to step away from the rust and have a play with the air suspension. eBay delivered the UNC and NPT fittings needed. Knocked up some basic brackets too With the drivers side up in the air, now was the time to weld the bracket to the chassis Access for the welding torch was pretty minimal. Temporarily bolted on the air bag The bag has no pressure in it, and the axle is beyond full droop (front spring bolt is out) So it looks about right to me I'll start gathering some suspension links, and then I can weld the brackets to a spare MGB axle I have.
Are you going to use them instead of springs eventually?
moglite
The end of the rust repairs is almost in sight !!!! I believe I've now got strong chassis rails, and the inner sills are all new. So it was time to make up a couple of outriggers in the style of the factory ones. Floorpan was next on the list . Nice big holds for puddle welds. I couldn't work out how to clamp this panel in place, without tight clamping, I don't think spotwelds work with my equipment/skill. A lot of seaming and big puddle welds, and that isn't going anywhere. There is a small section of floorpan still to do, where the handbrake is, but the structural welding is pretty much done Plenty of details stuff to do around the a-pillar, inner front wing, but definitely getting there.
Last Edit: May 1, 2018 16:29:14 GMT by moglite
moglite
Are you going to use them instead of springs eventually? Yeah - a 4-link setup using the front leaf spring mount as a pair of mounting point. The other mounting points will be in the vicinity of the top shock mounts.
moglite
Aug 11, 2018 20:23:28 GMT
Been a few months since an update. The recent heatwave and work kept me out of the garage for a while. A Daimler Double Six is now in the stable, and that takes a bit of my time.. But I'm back in the saddle with the Morris now. Drivers side rear floorpan is all welded up, and cleaned back ready for kurust/primer/seam-sealer/stonechip/top-coat The front floorpan is in the same state It always looks the worst before the paint starts going on, but there is plenty of new metal and loads of welding to replace the previous iffy repairs. The outer sill is also 100% on Lots of plug welds and the odd seam weld keeps that in place. The front wing, still needs work, but I'm going to get the underside tidied first. Then I can put it back on the deck, and start trying to get the doors to fit properly. They never did fit well, as they were replacements, but all this fab hasn't improved things. Thanks for looking
Last Edit: Aug 11, 2018 20:39:37 GMT by moglite
eternaloptimist
Aug 11, 2018 23:24:17 GMT
Bookmarked. Love an estate
Cracking efforts! Subscribed!
1987 Supercharged BMW R1150 Citroen 2cv Hillclimb Monster 1995 Renault Master Mk1 Race Transporter 1994 Mazda MX5 Mk1 / NA Road Going Class Hillclimber 1991 UMM Alter II Crew Cab OM606 SuperTurbo Diesel MegaUMM Overlander 1992 UMM Alter II Station Wagon 1980 UMM Cournil - survivor - resto project 1979 Lomax 224 2014 VW T5.1 Transporter Kombi Highline
Just tuning in to catch up with some Readers Rides threads I hadn’t spotted before. Nice one. The best* thing about doing all this work is knowing it’s all good underneath. It’s surprising how often you see a ‘good’ car which turns out to be completely knackered or bodged underneath.
moglite
Aug 15, 2018 22:01:56 GMT
With the seam sealer drying on the shell, I couldn't make a mess in the garage..... But on the outside workbench is a tatty MGB axle I picked up a while back. The MGB Salisbury axle is a straightforward swap, but crucially for a conversion to 4-link, it isn't a cast casing, so I can weld on whatever brackets I need. This is what I started with - useless brackets everywhere A couple of cutting discs, a grinder disc, and a flap wheel to finish, and an hour or two later we have this Pretty happy with that, the drain and fill bungs are loose. The back lash and bearings all seem pretty good. The drums and backplates just need a clean-up. New cylinders and few other little bits will get the brakes working. But that was a diversion. I need to keep focused on the shell whilst the weather is good. The 4-link can wait until the winter.
moglite
Aug 16, 2018 10:07:33 GMT
Nice parcel from DPD - my 4-link kit from McGill Motorsport I couldn't be bothered with rubber bushes - 1/2" joints all around. I figure with a 1622cc motor even with twin carbs - that will be plenty strong enough for a cruiser, and the existing leaf springs use 1/2 bolts as a sanity check. Outside links will replace the leaf springs. Inner triangular links for bracing. If only I'd finished the bodywork....this is the fun stuff
Aug 19, 2018 10:36:28 GMT
I guess as the upper links are effectively form an A arm, it serves the purpose of lateral location too? (no panhard or other required)
moglite
Aug 19, 2018 15:23:34 GMT
I guess as the upper links are effectively form an A arm, it serves the purpose of lateral location too? (no panhard or other required) That is the theory - with no pahard needed. I'm loosely following the design of an MGB 4-link conversion
moglite
Aug 19, 2018 17:39:02 GMT
Some good progress this weekend. The drivers side inner floor pans are all painted This area gave me some trouble, and involved quite a time consuming rework. it is under the rear seat, but is quite visible when the seats are folded, so it has to be presentable, which it is now After putting the stonechip on - it looked like this - arrrgghhh - ugly. That will not do Nothing for it, but to gouge it all out, and get to the root of the problem.... what did I find .... a badly welded in patch. Some of my earliest work...cough... My penance was filler work in an awkward corner - duly paid. Whilst the filler layers were drying I hot-footed it over to the work bench to fit up the 4-link bars. Plug welds and seam welds for belt and braces. They ground back nicely with a flap disc A quick coat of etch primer, to stop them going rusty, and fit them up Only done one end so far, as I will have to cut them to length - just don't know what length yet ;-)
79cord
Aug 20, 2018 12:17:34 GMT
Nice, but some rubber bushes are normally a necessity for a 4-link to allow the axle to twist in relation to the body, their geometry isn't great.. Even with bushes many cars with diagonally located arms would pull at their mountings until the floor-pan cracked with fatigue.
Last Edit: Aug 20, 2018 12:22:59 GMT by 79cord
Pid363!
Madness is all in the mind!
Aug 20, 2018 13:06:06 GMT
Great work as allways but as above you surely got to have some sort of rubber or poly bush at one end other wise the ride would shake you to death!
Stupid is as stupid does!
v8ian
Aug 20, 2018 17:43:55 GMT
It will be firm, and transfer shed loads of noise it its Rose joints each end, but will make the handling so much crisper
Pid363!
Aug 20, 2018 18:46:22 GMT
It will be firm, and transfer shed loads of noise it its Rose joints each end, but will make the handling so much crisper It would take more than a few rose joints to make the handling of an A60 crisp!!!!!!
moglite
Aug 20, 2018 20:50:28 GMT
Interesting, and rather frustrating as I thought I had the 4-link sussed I'm struggling to see how a bush will allow more twist than a heim joint that is designed for that very purpose. But I can see the noise aspect, I'm not sure it will make that much difference compare to the rusty leaf springs I'm used to, but lets play it out. Getting a bit of rubber in there - will certainly give the welds an easier time. One of the reasons I went for heim's at both ends, was I couldn't fine these in a 1/2" size I've found these in 1/2" That would be a simple matter to turn the other end of the link into this That seems to mirror what the Escort rally boys use Does that seem like a plan ?
Aug 20, 2018 23:06:12 GMT
I'm struggling to see how a bush will allow more twist than a heim joint that is designed for that very purpose. i can see as a result of the top and bottom arms being unequal length and not working in paralell (in same arc) to each other, is going to result in some funky caster changes during body roll, which will be specific to each side of the vehicle as it happens If one side is in droop the other in bump, the different length arms will try to rotate the axle (caster) but only at one end of the axle. but it won't be able to rotate as the trailing arms are fixed length and rose jointed, and the arms on the other end of the axle will prevent it rotating. so it will pull or push chassis mountings/ axle mountings. not so much a lack of articulation, but a lack of reciprocation Effectively the arms need to get marginally longer or shorter depending on where the axle is at, and rubber bushing would allow that
Last Edit: Aug 20, 2018 23:37:42 GMT by darrenh
I'm struggling to see how a bush will allow more twist than a heim joint that is designed for that very purpose. i can see as a result of the top and bottom arms being unequal length and not working in paralell (in same arc) to each other, is going to result in some funky caster changes during body roll, which will be specific to each side of the vehicle as it happens If one side is in droop the other in bump, the different length arms will try to rotate the axle (caster) but only at one end of the axle. but it won't be able to rotate as the trailing arms are fixed length and rose jointed, and the arms on the other end of the axle will prevent it rotating. so it will pull or push chassis mountings/ axle mountings. not so much a lack of articulation, but a lack of reciprocation Effectively the arms need to get marginally longer or shorter depending on where the axle is at, and rubber bushing would allow that What he says ^^^ It’s not about articulation, it’s about fixed lengths. If you replicated it in meccano it would make a solid parallelogram, and you’d get no movement at all. There was a big conversation about it on another forum a few years back, and one of the contributors linked to some really good animated illustrations; I’ll see if I can find them.
