May 24, 2017 16:25:26 GMT
Hi all,
maybe a silly or even damgerous idea, but my vertical compressor does not have the power to run air tools properly. I can't afford to buy another compressor, and I was wondering if I could make it more useable by creating a second tank using a propane bottle.
Its a pressure vessel so should be Ok, immediate problem I can see is the lack of a drain for condensation.
Sorry if this has been posted before.
Any thoughts? TIA
May 24, 2017 17:02:02 GMT
cannot think of any reasons not to use one, bar checking what pressure they are rated for.
I would add a drain point, either drill and tap the bottom or mount it upside down and have a drain on the fitting going in.
v8ian
May 24, 2017 17:41:43 GMT
I used one for years, never had any problem with it except for the smell of gas for a while, I would be tempted to unscrew the valve off the top, fill it with water, put the valve back invert the bottle, then you can safely drill for a drain cock, plus whe water should help with getting rid of the smell.
93fxdl
Enter your message here...
May 24, 2017 18:14:15 GMT
I also have used propane bottles as expansion air tanks. Make certain the tank is empty before removing the valve, fit a valve to the tank so you can use the tank on its own and you don't get an uncontrolled release of air when disconnecting from the compressor Ttfn Glenn
Jun 11, 2017 10:44:04 GMT
I did as v8ian above said. I have a lovely silent running ex mod compressor and it started leaking, it's mounted in my garage attic, so I bypassed it and used a propane cylinder adding a drain valve. I unscrewed the top and filled it with water to get the gas out. Works a treat and have a bigger capacity.
uk87
Kinda New
Jun 25, 2017 20:00:51 GMT
Do you have any more details about your ex mod compressor? I'm guessing it's not actually silent but how quiet is it?
Jun 25, 2017 21:56:06 GMT
Yes, it's like this ( but a different make/ colour) it's very quiet.......it's basically 3 fridge compressors, so if you want to know how loud it is get yourself 3 fridges and have a listen.......it's like that 😂 Slightly off topic, I made a friend one out of an old gas bottle and a fridge compressor, and regulator/ cut out off the bay, it works a treat and almost free.
