May 20, 2017 15:36:58 GMT
Hi guys! I´m Santiago from Argentina and I own this white Land Rover Discovery Tdi. 350.000kms and counting. Still rides strong and it´s a really fun truck to drive especially off-road!!!
I bought it about 4 years ago to a guy who imported it from Germany. I restored her to my specific taste and now we enjoy it travelling with the family. It came equipped with a Webasto heater DBW46 which I´m servicing right at this moment since its a great thing to have in our southern cold days. You don´t see these heaters much around here.
Cheers! San
Santiago 1995 Volvo 850 GLT Wagon 1994 Land Rover Discovery Tdi (Webasto equipped) 1996 Land Rover Defender Tdi (TGV) 1997 Land Rover Defender Tdi 1981 Honda ATC 110 (Three wheeler)
May 20, 2017 15:39:09 GMT
May 20, 2017 19:40:36 GMT
Wow,that looks fresh. Any more info on this? These re definatly getting my interest lately.
Nice, and welcome!
We've got a Discovery V8 owner from Peru on here and me with a Range Rover in the Philippines.
Good to see some more British tin a long way from home!
How do you go on for parts in Argentina?
Pop over the border to Brazil and pick up a TGV 2.8 motor. Make a very nice Disco even better Adrian
Vitesse 6 Saloon Vitesse Mk2 Convertible BMW R1150GS VW Amarok
May 22, 2017 17:18:40 GMT
Wow,that looks fresh. Any more info on this? These re definatly getting my interest lately. Hi there!! What would you like to know? I have this one plus 2 Defenders 300tdi so I know very well these engines and transmissions. If you take good care of them they´ll last a long long time. We have dry climate around here mostly so rust is not a major issue where I live. But they do tend to rust pretty bad. Have to check under the carpets in the front and check the chassis also. Defenders are almost 100% aluminum so they rust much less but again chassis and firewall are there weak points. In Argentina there are plenty of Discoveryies and Defenders. Being Defenders all Diesels (300tdi, Td5 and Puma) and Discos are 95% diesel and just a few came with V8 engines around here. Mostly manuals but we have automatic Discos in both engines tdi and V8. Cheers, San
May 22, 2017 17:25:00 GMT
Nice, and welcome! We've got a Discovery V8 owner from Peru on here and me with a Range Rover in the Philippines. Good to see some more British tin a long way from home! How do you go on for parts in Argentina? I´ve been reading about your Rangie. Beautiful truck. I was looking at a P38 Diesel the other day to buy it, but air con was not working. Air suspension and everything else was ok. Parts around here are not major problem, we have a couple of importers that have good stock for all LR models, at least basic stuff. 300Tdi engine is not a problem around here for parts since we are in the Land of Maxion International (Argentina and Brasil used to made them) and plenty of pickup trucks and vans use this engine all over the country, so as we say "we can get parts even in Drugstores" for these motors. Cheers,
May 22, 2017 17:30:36 GMT
Pop over the border to Brazil and pick up a TGV 2.8 motor. Make a very nice Disco even better Adrian Hi Adrian! I don´t need to go to Brazil, I can get them here since there where made in both countries. As a matter of fact I have one in one of my Defenders. Plus we can get all the internals to convert the original 2.5 300tdi to 2.8 very easy. Many of us in Argentina have gone that way also. Original block with everything from the 2.8. The problem is that a 2.8TGV well tuned ends up in different transmission problems. Clutches broken and even Gearboxes also don´t match up with the new HP and torque figures. Cheers,
I´ve been reading about your Rangie. Beautiful truck. I was looking at a P38 Diesel the other day to buy it, but air con was not working. Air suspension and everything else was ok. Parts around here are not major problem, we have a couple of importers that have good stock for all LR models, at least basic stuff. 300Tdi engine is not a problem around here for parts since we are in the Land of Maxion International (Argentina and Brasil used to made them) and plenty of pickup trucks and vans use this engine all over the country, so as we say "we can get parts even in Drugstores" for these motors. Cheers, Shouldn't worry about air-con, mines not worked for months (or rather I haven't bothered getting the correct o-rings) as even after several years of living in Asia, the novelty of still being able to drive with the windows down virtually all the time still hasn't worn off! Sounds okay on parts. To be fair, Discovery's may be better served here, but P38's are few and far between so little is stocked for them but of course, engine parts for everything LR are an import job.
I´ve been reading about your Rangie. Beautiful truck. I was looking at a P38 Diesel the other day to buy it, but air con was not working. Air suspension and everything else was ok. Parts around here are not major problem, we have a couple of importers that have good stock for all LR models, at least basic stuff. 300Tdi engine is not a problem around here for parts since we are in the Land of Maxion International (Argentina and Brasil used to made them) and plenty of pickup trucks and vans use this engine all over the country, so as we say "we can get parts even in Drugstores" for these motors. Cheers, Shouldn't worry about air-con, mines not worked for months (or rather I haven't bothered getting the correct o-rings) as even after several years of living in Asia, the novelty of still being able to drive with the windows down virtually all the time still hasn't worn off! Sounds okay on parts. To be fair, Discovery's may be better served here, but P38's are few and far between so little is stocked for them but of course, engine parts for everything LR are an import job. Ohh no, It´s not negotiable. Air con must be working and as I could read they are tuff to fix. I don´t know really... Cheers, San
Last Edit: May 23, 2017 2:02:24 GMT by defeyago
Air-con isn't too bad and I don't think there's much special about the actual mechanics of it. On the '38 your problems start if it's the evaporator (dash out) or the blend motors start to play up, which needs the skills of a gynaecologist! I've replaced condenser and dryer fairly easily, just managed to get the wrong sized o-rings, but it did work happily until the gas disappeared!
10 minutes with a specialist here would have it sorted. I'll get around to it one day.
Anyway, back to your Discovery. Keep the pics coming.
Last Edit: May 23, 2017 2:23:02 GMT by georgeb
Last Edit: May 23, 2017 4:56:39 GMT by defeyago
This is the felt ring. Orange side towards the flame/glowplug. Thanks Jan! (TurboDieselWeasel) Cheers
Last Edit: May 23, 2017 5:05:23 GMT by defeyago
May 24, 2017 11:55:42 GMT
Wow,that looks fresh. Any more info on this? These re definatly getting my interest lately. Hi there!! What would you like to know? I have this one plus 2 Defenders 300tdi so I know very well these engines and transmissions. If you take good care of them they´ll last a long long time. We have dry climate around here mostly so rust is not a major issue where I live. But they do tend to rust pretty bad. Have to check under the carpets in the front and check the chassis also. Defenders are almost 100% aluminum so they rust much less but again chassis and firewall are there weak points. In Argentina there are plenty of Discoveryies and Defenders. Being Defenders all Diesels (300tdi, Td5 and Puma) and Discos are 95% diesel and just a few came with V8 engines around here. Mostly manuals but we have automatic Discos in both engines tdi and V8. Cheers, San I love Land Rovers,I've had a few. My last one was a 200 tdi defender 110 hard top. I've also had Range Rover. Keep posting up,there's lots of love for Landies here.🙂
Pop over the border to Brazil and pick up a TGV 2.8 motor. Make a very nice Disco even better Adrian Hi Adrian! I don´t need to go to Brazil, I can get them here since there where made in both countries. As a matter of fact I have one in one of my Defenders. Plus we can get all the internals to convert the original 2.5 300tdi to 2.8 very easy. Many of us in Argentina have gone that way also. Original block with everything from the 2.8. The problem is that a 2.8TGV well tuned ends up in different transmission problems. Clutches broken and even Gearboxes also don´t match up with the new HP and torque figures. Cheers, You lucky b_gger Adrian
Last Edit: May 27, 2017 7:06:28 GMT by ahebron
