Got the click push fit fuel filter on 1999 explorer one side clicked off no issues second won't
Don't have a removal tool made one following instructions on you tube
Any ideas before I buy something I will only use once?
Toyota HiAce Super Custom Ltd (My thing) Isuzu Trooper (her thing) Audi a4 1999 (boys thing) Toyota Yaris Caravan - (festi thing)
if its the pen top trick on you tube try pushing the pipe on more then try removing it it may be in a "halfway" position neither on or off if you get my gist
bortaf
May 17, 2017 12:18:42 GMT
lube the locking bit, some GT85 or similar will help it slide off that bit easyer, i allways clean with brake cleaner then lube before attemping it
R.I.P photobucket
May 17, 2017 17:33:10 GMT
Tried the pen top trick as per you tube but no joy not tried to lube it up yet will give that a go when it stops raining!
May 20, 2017 11:48:29 GMT
Due to loss of patience and technical ability clip on one side no longer an issue . . That side being replaced with a small length of hose and clips 😔
