Hopefully someone wants a cracking little runabout. This has been a great car for me and my girlfriend but now its not used so needs to go.
The great -
Frugal but peppy 1 litre, amazing on fuel.
Only 62(ish) thousand miles on the clock which is low for this year - Forgot to check exact millage and its at my parents, I'll find out and update.
serviced in the last year - fresh oil, filter and plugs.
Brand new front pads that will only have done a couple of hundred miles if that.
I swapped out the suspension which gave a 40mm initial drop - matiz struts/springs up front, brand new Alto springs in back. Gives an 'as stock' ride.
CD player with USB and AUX port.
Sunroof - doesn't leak what so ever.
Will have 12 months MOT - it will fly through
The not great (but not bad)
Couple of dings as to be expected but really not many. Worst of which is passenger wing mirror but it is not broken, just dented.
I have filled and painted a big scrape on the passenger door. Not the greatest job, but not terrible. I don't think you'd notice if you weren't looking.
Not much else to say other than she's a good cheap car ready to use.
The great -
