Apr 22, 2017 10:49:58 GMT
Hi guys, I'm getting a local fabricator to modify the exhaust on my 03 Jaguar XJ8. They're going to remove one of the middle boxes and replace it with an X pipe. I'm just not sure which box to remove. Here is the current system: The car has a 4.2 litre V8. Does anyone know what differences in the note there would be depending on which box I delete?
Apr 22, 2017 10:56:04 GMT
Depends what they are... I'd remove the big one though.
Apr 22, 2017 10:56:56 GMT
The big one's the front, by the way!
Apr 22, 2017 10:58:06 GMT
Depends what they are... I'd remove the big one though. Sorry; depends what what are? I'm thinking big one, too.
Apr 22, 2017 11:01:54 GMT
Sorry; depends what what are? I'm thinking big one, too. The boxes, they will either be a resonator or a silencer, the resonator changes the tone and frequency of the sound, the silencer is self explanatory.
Apr 22, 2017 11:26:11 GMT
I've fired up an xj8 with both lambdas removed, it sounded epic.
I'd imagine the front box has a crossover in it if there isn't an external one which may explain its size.
Have it made with slip joints where they remove the boxes and you can always put the box back in if you don't like it.
93fxdl
Enter your message here...
Apr 22, 2017 12:37:57 GMT
How about fitting a couple of motorized cut outs? The you can go from bezerk to sedate, just with the push of a button Ttfn Glenn
How about fitting a couple of motorized cut outs? The you can go from bezerk to sedate, just with the push of a button Ttfn Glenn It's got to be on a budget so I can't afford any trickery! As cool as it would be....
Sorry; depends what what are? I'm thinking big one, too. The boxes, they will either be a resonator or a silencer, the resonator changes the tone and frequency of the sound, the silencer is self explanatory. So if I changed the resonator there wouldn't be an increase in volume at all? That'd be no good... hmmm. I need to work out which is which then!
I've fired up an xj8 with both lambdas removed, it sounded epic. I'd imagine the front box has a crossover in it if there isn't an external one which may explain its size. Have it made with slip joints where they remove the boxes and you can always put the box back in if you don't like it. Which box would you delete?
that's totally up to you tbh!
you'll still have the rear silencers too!
93fxdl
How about fitting a couple of motorized cut outs? The you can go from bezerk to sedate, just with the push of a button Ttfn Glenn It's got to be on a budget so I can't afford any trickery! As cool as it would be.... Diy exhaust cutout, made from scrapyard throttle body Ttfn Glenn
