Apr 23, 2017 12:46:01 GMT
Yours looks in excellent condition-what colour is it?
Get it running properly and they are a great drive. My Royale has a 3.0 injection engine and 4 speed auto box fitted from a later Monza-so pops along very well. Paintwork is a little iffy-but very little rust The Senator had a worn camshaft when I bought it-just changed it and its going for an mot in the week.
Will have to start a thread for the Senator.
Steve
Vauxhall Royale 3.0i Opel Senator 3.0i Ford Sierra 2.0GLXi
Apr 23, 2017 15:03:03 GMT
Its silver but in certain light looks a little mauve . Body work is in great condition no rust at all even inner wings are spotless chassis is in great nick too.bad points sunroof has been sealed shut and roof lining sagging and stained. Brakes are needing a lot of attention ,radiator leaking at gearbox is running very hot after a short journey . Hopeful I can get it on the road for summer tho
fad
AS said (and back on topic) it sounds like an air leak somewhere. Check the free stuff, timing, pull the plugs make sure they are good, check that there are no open vac ports that should be sealed or have something attached, check that the carb is bolted down right and sealed, and set correctly (no idea on these if there's an idle mix adjustment etc) likewise the exhaust, make sure it's good and tight and not leaking. Check your tappets / rockers / whatever is on these. Compression. All the easy stuff that will teach you lots n lots about engines. Essentially, a damn good service and going over. Then when you have done that report back
Last Edit: Apr 25, 2017 9:14:16 GMT by fad
Update car running great ,points where bad and very dirty fuel causing car to back fire, going for m.o.t next week after a full rebuild of all the running gear.
Excellent news!
Let us know how the MOT goes!
Steve
Jun 11, 2017 11:20:31 GMT
Jun 11, 2017 11:23:46 GMT
MOTD no advisory's
Jun 11, 2017 12:23:31 GMT
That looks to be a VERY tidy example! Congrats on the MOT, Any plans to attend the VBOA Rally in Market Harborough 7th - 8th July?
Jun 11, 2017 13:11:44 GMT
Thanks vintage75. No plans as yet, may attend a few local shows this summer then further afield next year all going well.
