Apr 30, 2017 22:47:54 GMT
So this had me pulling my hair out. Power window was jammed up. In a Spider power windows are ridiculous and at the price of replacement units I was going to switch to manual. But since the motor was fine I though I'd have a go at fixing it. I went to hardware store and bought some cable. I rewound the spool but......it needs to have tension at all times or it springs looose. I'm ashamed to say I had to take it in and out and rewind it about twenty times before I got right, what a lesson in frustration. But in the end I have a working power window.
Apr 30, 2017 22:52:23 GMT
I thought I was finally finished with the car but driving it the clutch pedal was fairly high so I thought I'd adjust that. Well it's at the end so it looks like I'll be installing a clutch disc. They are never done are they?
Thought I was finished then I realized it needed a clutch. So on with it.
Might as well reseal the box while it’s out
Last Edit: Nov 12, 2017 0:17:13 GMT by nmretro
The pedal made an awful noise. I thought it was the return spring but ended up being the cable itself. That return spring was a bear. An old-timer taught me this trick for expanding a spring. (He used washers, I used pennies)
ivangt6
Club RR Member Number: 132
Dads Fiat 124 Spiderivangt6
@ivangt6
Club Retro Rides Member 132
Nov 12, 2017 18:23:25 GMT
Good trick that on the spring. I wish I had invested the time on refreshing the seals on the landrover seals and gaskets while I had it out.
1979 Mini 1000 1972 Triumph GT6 2007 VW Golf GTi 1979 VW T25 Leisuredrive 1988 Range Rover Vogue SE
düdo
wide as house
Nov 12, 2017 19:16:12 GMT
This looks like a good example. There's a few of these around here that come out in the summer. A friend was told by a mechanic re his Fiat - 'they're good for 100k kms' meaning, they fall apart at 101k kms. As you said - the Cali climate has been kind on this.
I guess my son has 36000 kilometers of motoring left. But I kind of think the friend was fed a line since I drove a Fiat 131(essentially same mechanicals) to 130000 miles (209000 kilometers) and although tired it was still running fine when I sold it. It’s about maintenance not the brand.
Nov 24, 2017 17:24:55 GMT
Nov 24, 2017 18:38:41 GMT
success!
JP
