**The car does not come on the compomotive wheels as shown in the pictures**
Got my mk1 golf cabriolet up for sale sadly I just couldn't ever really warm as much as I have to my mk2 fiesta so that's still getting all of the attention.
The car itself has done 84k miles which is quite low I do have quite a bit of paperwork for this and you can check on the MOT history online. It is MOTd till the 14th of August aswell.
I've owned the car 3 months now with the plan on getting ready for the summer months however spending money on my fiesta is taking priority. When I got it it wasn't running properly however since I've owned it I've replaced -
Brand new Weber carb (replace the standard pierburg)
New plugs and leads
New distributor cap rotor arm
New ignition amplifier
New ignition coil
New battery
Since changing all this it seems to be running a lot better! As can be seen in the pictures it does need some bodywork most panels have a little damage (Mark, scratch or dent). The boot has been replaced for a dark blue one as the boot was rotten and the door has been changed for a black as that also had some dog damage in the bottom of it (I do still have the door for anyone who wants it) it has an aftermarket immobiliser fitted increasing the security element. The inner lights aren't currently fitted at the moment as when I got the car they weren't fitted properly and haven't actually got the proper fitting kit (the inner light and debadged grill we be included) it's had an aftermarket exhaust fitted and a brand new hella petrol cap. The roof is in great condition as it is a fairly new mohair hood - it does need a clean but I have some of the auto glym hood cleaner included.
Interior wise it's pretty much standard bar a headunit. It's quite tidy the is a rip in the driver seat bolster and the tilting handle cable had broken the seat can be still be tilted though. It doesn't have any front doorcards fitted at the moment as they were damaged (passenger might be save able drivers isn't)
I've tried to give as much information as possible if anyone does have any questions don't hesitate to get in contact - I do only have a couple of pictures at the moment I will get some more put up ASAP. (The photos were taken before the new passenger side door was fitted). The car is located in saffron walden Essex and I'm after £1000.
cheers
New plugs and leads
New ignition coil
New battery
cheers
