amazing quality work as usual! You make most of the jobs you do look rather simple especially looking at how quick you get things done. If i do bodywork related jobs, it always takes ages. And you always have a clean workshop (maybe because of Sid?) always like to follow your posts. There are not many people around who have this high standard of quality. Most of them would have used tons of filler.
Peter
Aug 24, 2017 21:58:07 GMT
That's a visible repair that works well for being visible and looks very 'right' against the old bits. None of it is seen once the van is back together - well unless you lie on your back underneath the van that is
Aug 24, 2017 22:11:28 GMT
amazing quality work as usual! You make most of the jobs you do look rather simple especially looking at how quick you get things done. If i do bodywork related jobs, it always takes ages. And you always have a clean workshop (maybe because of Sid?) always like to follow your posts. There are not many people around who have this high standard of quality. Most of them would have used tons of filler. Peter Thanks - I am slightly OCD / religious with keeping the workshop tidy - I always find 5 - 10 mins every day to gather up the tools and put them away then have a good sweep up - leave stuff out and its just asking to get lost / buried and then you loose a heap of time looking for something that is under your nose - and what's the point of working in piles of dust & rubbish - pretty pointless in my book and when you are utilising the same workshop for painting its critical that you reduce any workshop dust to a absolute minimum - Chris
Last Edit: Aug 24, 2017 22:35:27 GMT by Deleted
Aug 24, 2017 22:30:00 GMT
Only a few hours today on this - there is a modern in the workshop that's absorbing my time in the main - still managed to get the timber in the nearside rear floor corner where rot had set into the timber Removed all the weak / rotten wood Rebated & mortised a new side member - proper jiggle to get it in but eventfully got there - let in a repair section to the inner wheelarch - utilised the expanding timber glue for the joints with impact driven screws Managed to tie the new side member to tie into the wheelarch timber has per the original - made the side member over length and then trimmed it once installed Then made a new closing section for the floor area and sanded over to level the minor deviations between the old & the new New coachbolt fitted to secure the floor to the chassis out rigger and the side framing reinstalled to the new repair area Sanded over the floor planking to bring the planks (which had cupped) level with the new rear cross member
Last Edit: Aug 24, 2017 22:31:48 GMT by Deleted
Aug 24, 2017 22:37:43 GMT
If you would be kind enough to get me a bottle please. PM details & I can Paypal you? Not in a massive hurry but do have a weld job soonish that it would be perfect for. I work in High Wycombe & live in Langley (outside slough) if you are passing in the near future? You are closer to me than I thought - I quite often come down the M4 heading over to Kings Langley (Watford) where my one of my fellow Jowett fleet owners resides - the Kent rep normally calls on me at the end of the month - once I have it I will PM you - Chris Thanks Chris, appreciated.
Aug 25, 2017 20:56:52 GMT
Last Edit: Aug 25, 2017 20:57:54 GMT by Deleted
Aug 26, 2017 19:50:27 GMT
The Jowett Factory closed in 1954 so has you can appreciate parts are a bit of an issue - However the Jowett Car Club runs it's own spares / parts department - all staffed voluntary - what is no longer available is remade / manufactured by a select group of suppliers - focus tends to be on the parts that keep the vehicles on the road so mechanical rather than cosmetic - having manufactured from 1910 - 1954 a vast range of models it's quite an undertaking to keep stock but the guys at Jowett Car Spares do a admirable job. Individual Jowett owners also squirrel parts - sometimes coming with a vehicle that they have purchased and sometimes purchasing a job lot of parts from a previous Jowett owner. Tim whom owns the van has been working his way through his parts stash and occasionally a small parcel will turn up with a few bits for the restoration - latest couple of deliveries have yielded these All 'New Old Stock' - a pair of door window locking catches along with a radiator cowl badge - all has rare as hens teeth
Last Edit: Aug 26, 2017 19:54:08 GMT by Deleted
Aug 27, 2017 11:55:18 GMT
Did they build a new shed/barn around it? It all looks quite new in the photo... but seemed to be a bit of a job to remove
Great work, as always!
Aug 27, 2017 15:36:27 GMT
wow, beautiful work on different materials and variety of fastening methods!
JP
New MOT is good news for Prozac my little van that can, however, the comments from the inspector was worth more to me. It is an old car, but he said it was a good one. Going out shopping with it is always fun as it draws attention and gets comments from random people, old and young. Tonight I got home after 6pm as I had a meeting in Croydon this afternoon. Note through the door to say a parcel had been delivered next door. So I took some stuff around to Mickey and fetched my parcel...... large. Inside was a massive smile inducing V8 hubcap from the GrumpyNortherner. This is one of his restorations...... take a look and be amazed at attention to detail and finish. forum.retro-rides.org/thread/196779/jowett-jupiter-sports-restoration-wheelsThank you very much Chris. I removed a painting from the wall, and hung it up indoors...... not sure everyone would, but hey, I pay the mortgage. Also inside, neatly wrapped and packed was this license plate. As Herb in Winfield Kansas likes to say.... Made out like a Bandit !!! I love the real patina on plates, used works for me. Check out this thread to see what car it came from, one of Chris' restorations. forum.retro-rides.org/thread/196036/1947-jowett-bradford-utility-restorationSo Karma again pointing her finger at me. Thanks Chris, made my day for sure.
Last Edit: Oct 10, 2017 7:35:53 GMT by Deleted
vulgalour
Club RR Member Number: 146
Oct 10, 2017 11:58:45 GMT
That's coming on a treat.
Oct 10, 2017 21:09:12 GMT
Last Edit: Oct 10, 2017 21:18:45 GMT by Deleted
Lovely work as always.
I'm intrigued to see how they weatherproofed the doors to keep the elements out of the interior? Presumably there was a gutter running across above the doors at least?
Oct 11, 2017 10:11:46 GMT
Lovely work as always. I'm intrigued to see how they weatherproofed the doors to keep the elements out of the interior? Presumably there was a gutter running across above the doors at least? Thanks & correct there is a 'J' shaped alloy roof gutter that runs across the rear and down each side of the roof - the door seals are nothing special though just a piece of rubber hose with a vinyl cloth wrapped around it that is tacked on to the inner frame - like most vans / vehicles of this era there is little finesse to draught proofing / sound proofing - there's not even a heater fitted to it !
Oct 11, 2017 10:46:35 GMT
Amazing work as always.
That van certainly has its fair share of work too.
Oct 11, 2017 20:03:54 GMT
Last Edit: Oct 11, 2017 20:09:54 GMT by Deleted
vulgalour
Oct 11, 2017 20:14:14 GMT
Those rear doors needed an awful lot of work!
Oct 11, 2017 20:18:32 GMT
Those rear doors needed an awful lot of work! Try explaining to a client that it's taken four days to fit a pair of doors to a realistic tolerance / standard !!
Last Edit: Oct 11, 2017 20:19:27 GMT by Deleted
vulgalour
Oct 11, 2017 20:38:40 GMT
Oof! Rather you than me on that one. You've got photographs you can show them at least.
