LowStandards
So yeah, I err, made a hole... You can see here my issue, the bottom of the inner arch has rotted in the past and a PO has stuck a plate over the top without dealing with the issue This means water has been getting into the seam where the seat base meets the floor, so I cut it out Happy to see a common place for the chassis to rot is sound, so a quick coat of chassis black where I can get to. I still need gas so that's where play stopped. But i've opened an account with BOC so i'll grab one asap... It looks pretty drastic, but the main bulk of the hole is just the cut away seat base, which can be welded back in.
eternaloptimist
These are so strong that they can be bodged up and still feel tight/robust - it's a good feeling to cut away others' bodgery and do the job properly. Nice work.
vulgalour
Club RR Member Number: 146
1962 Rover 100 P4vulgalour
@vulgalour
Club Retro Rides Member 146
Mar 10, 2017 18:30:31 GMT
How's the other side?
LowStandards
Mar 10, 2017 19:45:09 GMT
The other side is spot on, it was only an unchecked hole at the top of the inner arch that has caused me this grief...
vulgalour
@vulgalour
Mar 10, 2017 20:29:32 GMT
That's a relief.
LowStandards
Apr 28, 2017 10:52:57 GMT
Having a bit of a winter lull, but now I have gas so I can weld again So what do I go and do? 😋
vulgalour
@vulgalour
Apr 28, 2017 17:04:31 GMT
Sensible preventative maintenance right there.
1962 Rover 100 P4glenanderson
@glenanderson
Club Retro Rides Member 64
Apr 28, 2017 21:58:46 GMT
Lowering blocks for the back axle?
LowStandards
Apr 28, 2017 22:06:55 GMT
Custom made, up to -3" u-bolts ;p
LowStandards
Tiny little update In an attempt to possibly get her to RRG (I honestly don't hold out much hope, but you've gotta at least try) We all remember this big hole This was caused by a distinct lack of inner arch. I'm not talking a few small holes letting a dribble of rain in, i'm talking... Bad times! Still, it's all cut out now, so I can start letting fresh steels back in. First of many plates installed This one allows me to put the seat base back in, which shouldn't be difficult, covers a huge hole and brings back major mojo...
LowStandards
I boosted my mojo this weekend by purchasing a Lexus GS300
225bhp 305Nm of torques Silky smooth straight 6 5 speed AutoBox
Which will all get ripped out and shoved in the Rover...
Here I am, at half five in the afternoon my time, a fairly 'dead' period for the forum and up pops this in my bookmarks. Lovely, thank you.
LowStandards
Collected the donor last night Actually in really good condition, still with 6 months mot and everything working fine. Tempted to smoke around in her till the tickets up to be honest, then start the conversion.
psycho83
East of England
Rhythm and Booze
would be a shame not to. Get it hot, put some miles on it - let it prove itself before you rip it apart. Collected the donor last night Tempted to smoke around in her till the tickets up to be honest, then start the conversion.
vulgalour
@vulgalour
Jul 19, 2017 12:10:57 GMT
Just don't get attached, because then you'll have to buy another and we all know how that goes.
Jul 19, 2017 17:58:09 GMT
that's gonna boogie very nicely!!
Paul Y
Jul 23, 2017 16:37:32 GMT
I would send that one back if I were you somebody has stolen the turbo.... P.
LowStandards
Jul 23, 2017 18:09:29 GMT
I would send that one back if I were you somebody has stolen the turbo.... P. Shhhh, lazy daily cruiser, not brap brapper
LowStandards
Well the Engine ECU doesn't look that bad really... There is another ECU for the gearbox mind which interacts with this one and various sensors in the diffs etc... In fact, there are 10 ECUs nestled within the GS300, 10! Even the steering wheel has it's own ECU ffs...
Paul Y
Can I suggest binning all of them and investing in a Megasquirt? These people make a plug and play harness eplracing.com/store/product/itmgroupdetail.aspx?groupid=71682&make=LEXUSHave a chat with the guys at EFI source, yes it is all LS motor stuff but they do provide micro and megasquirt boxs that might be way easier than trying to make all the ECU talk together. Or I could be talking plums and it is the easiest thing in the world to make it all work together. Really liked you Standard build so going to enjoy this one. I promise that I will provide no real input other than throw stupid comments from the side lines. Please continue. P
