Sept 8, 2019 20:23:59 GMT
long time no update, shame on me... The Van has been getting hammered with very little attention, honestly I have been using the van's shabyness as an excuse to buy a new welder. ssooo. DC 200amp inverter - mig, tig, arc. it only speaks Polish, my logic was Esab's are yellow and Polish so i have bough an Esab. The Van.... the B pillar was bit rusty so i bought a cut for £15, happy days. unfortunalty to get to it i would be replacing the wheel arch to, £65 but probably worth doing too. upon further inspection... I should of guessed, the surface rust is always the tip of the iceburg. a trail by fire for me and my new Polish mate then... repair withstood the industry standard 'Will it Jack?' test, so wheel off & arch in got bit carried away, the rear panels where black and I was getting fed up of the van looking like a patch work quilt. So i then thought, its more effort to do a worse job, so using the box the wheel arch arrived in. I thought i would just spray the lot first go with a spray gun (volvo engine bay doesn't count)
Last Edit: Sept 8, 2019 20:59:06 GMT by space goat
Sept 8, 2019 20:44:23 GMT
Last Edit: Sept 8, 2019 20:54:52 GMT by space goat
Sept 22, 2019 19:15:58 GMT
so this turned up o the drive way, again its going to stay for some minor MOT work. I quite like it but have always felt alittle bit intimated by them. My initial inspections tells me i have nothing to fear but time will tell.} First Job, new rear disks and pads. Initially i was concerned the bolts that bolt the clipper to the car also keep the calliper halfs together. so gingerly unwinding them proved the Citroen went that stupid. fewww the bass are held in with a long bolt that acts like a pin, turns out this Does hold the half together, thank you Citroen. soooo Leson 1 one can only change the discs or change the pads, not both for completeness, Pic of the drivers side more citroen lessons to come!
Oct 20, 2019 21:03:03 GMT
The MOT man fails the car on tyres and brake pads, track rod, and ball joint needed a boot. There was also an advisory on suspension leaking.... mmmmmm 1)tyres was painless at £30 a corner 2) Fail play, brake pads didn't have much life left. winding back the handbrake with a drift, not my proudest moment 3)Track rod, no problem 4)I enjoy the lack of springs of fury and instant death 5) Whilst digging around under there I think sound the source of the leak, there's a low pressure return that goes from the bottom of the strut via a fax hose to the chase, think they call this a leak off. the problem of was early obvious £10 for the new part, and looks like the leak has gone. Time to book it in for MOTing
Last Edit: Oct 20, 2019 21:05:51 GMT by space goat
Well soon as i get the Citroen through an MOT its the Benz's Turn. Fortunately i did most of the suspension stuff when it was warmer and the days were longer, but I had put the number plate and more importantly the headlights. turns out my attempt at plating the headlamp reflectors didn't produce a very good pattern. I was also growing increasingly tired of trying to find a decent replacement that wasn't a stupid price. Then i saw these and got to thinking they have been sitting book marked in my browser for a long time, and when i noticed the prices have come down allot since then i thought BINGO! note: the projector kit only works with H1 HID bulbs, so i had to upgrade to these too. 1) find a day when Mrs space goat if out so i can work in a warm kitchen the unit includes a shutter active by a solenoid for high & low beam 2) strip out old bulb & refelector 3)assembly, the projector kit mounts straight into the old H4 mounts 4) stand back and admire 5) ehhrr wiring.... Those ahead of the curve will already know h4 bulbs have separate circuits for high and low beam and H1's don't. I didn't. also the Benz and i suspect all other cars possessing H4 lamps don't use these circuit's simultaneously. So when i connected the HID kit to the dip beam, when go to main beam or flash i have no lights. not good. 5.1) use 5 pin relay to with the supply from dip beam circuit to main beam circuit i though this was genius summery: turning high beam on will switch relay to use high beam circuit unfortunately the HID kit really doesn't like being turning on and off quickly so this idea soon when out the window 5.2) hack the car's wiring I was hoping i could fudge a relay but all the wiring diagrams looked bit simple, too simple turns out the switching of the circuits is done by the column switch, i was beginning to loose faith at this point. Then though i should take a look at the plug for the column switch, and Bingo on the first two pins i try i find the dip and main beam! faith is restored, by bridging these the HID kit will have a continue supply flipping between dip and main beam. 5.2.1) remove 5 pin relay (if you haven't tried draw.oi for drawings yet you must give it a go) 5.2.2) crudely hack plug night before MOT winner low beam High MOT passed They do work well, but you only really notice when driving another vehicle with H4's O yeah, and the number plates
luckygti
I need to try harder!
Dec 30, 2019 15:23:15 GMT
Great little fleet you have there. I'm a sucker for a T25, mines held up pretty well since I had all of the welding done, but i cheated and got someone else to do it for me!! Lovely Volvo too. The roofrack has definitely inspired me to try and do something similar. Good work!
Feb 18, 2020 17:23:50 GMT
work has been unstable recently so projects have been on hiatus. They final announced going into administration just before Christmas with 150+ redundancies on the day, I was one of the unfortunates to be kept on to keep the lights on infill stock runs down. Fortunately I have managed to find work just down the road (not easy in north wales) So let the impulse commence. I got a roomer that a W123 230e estate was for sale in the area, I'm not really into the Petrol and auto boxes so a quick scan on eBay returned an NA OM606 with 5 speed manual. Plan A: sell the saloon, to help fund the OM606 estate build. Plan B, if the estate is a dog: slam the 606 into the saloon. We'll unfortunately the estate turned out to be bit of a dog. so OM606 saloon is a Go! a quick check of the 5 speed box turned out it was a fragile example. so back on eBay. and yet again eBay provides! 717.401 g-wagon 5 speed gearbox, also means i can ditch the dual mass flywheel, we will see how this goes... g wagon box is on the left G-wagon box is a fair bit heavier and bigger, so looks like ill be having to get the prop shortened. eehhhrrr so this is where i need you're help. i don't want to go crazy with the build, I'm Thinking send the pump away and get 7mm elements put in. also std om606 manafold but I'm not sure about turbo options? think they came with t25 or t3's, but if anyone has any advice, I don't want to go bananas.
Last Edit: Feb 18, 2020 20:26:12 GMT by space goat
Feb 20, 2020 19:15:35 GMT
The Sprinter single mass conversion showed up. looks like it will work, but did run int an issue. the input shaft on the g-wagon shaft needs to go through the flywheel and into the pilot bearing in the crank, and the bore in the in the sprinter flywheel was too small. Not a big issue but not one i can easily take care of in my shed. There tends to be a long wait and much nagging to get small jobs done in machine shops around here, but a quick google returned a shop just up the road. www.facebook.com/machineworkscaernarfon/I show up un-announced had a short hat about the job and head for breakfast with mrs space goat. driving home i get a call saying the job is done! Had a better chat when i came to collect. He was a home gammer until everyone nagged him to build engines for them (including dealerships) If you need head work or a 300hp n/a XE engine give him a shout
Feb 20, 2020 19:22:59 GMT
Making a start, I'm pretty sure I'm going to need to get the prop shaft shortened, can anyone recommend someone who can do this?
Feb 23, 2020 21:16:18 GMT
the OM606 sat perfectly in the car on the W124 engine mounts but i was unable to shut to bonnet, the w124 hydraulic mounts are quite tall but the w123 mounts are allot thinner, but will need bit of modification to the car. So a rare brake in the weather gave me a chance to crack the welder out. so it looks like i can use the existing engine mount on the drivers side but will need to extend the passenger side. hot glue it in It's not particularly precise but i hoping the screw in the bumper is centred, with that assumption in mind i think its sitting very nicely. bonnet will also shut now too. I was abit concerned that the rad wouldn't fit but shouldn't be a problem, will need an electric fan ddaaamm that engine looks good in there.
Last Edit: Feb 23, 2020 21:49:27 GMT by space goat
Feb 23, 2020 21:23:20 GMT
sump clearance is quite tight but i don't think it will be an issue I don't have a pic, but the gearbox bolted up the the existing mounts, hopefully there won't be a need to modify gear linkage. but the prop might need to be trimmed down, It looks mainly close enough to give it a go but I'm looking around to see if the prop from a 240D auto will fit.
Prop shaft is off to be shortened, it might be some time before its back so i though it might be a good time to tidy the engine bay. but whilst the engine and box are in position though i would have a crack at the gear linkage. Was Now Wasn't a straight swap but did squeeze in, selects all the gears ok but will need tweeking. no biggy (famous last words)
I have been kind of gambling that my clutch combination will work, likely i have a collection of clutch forks and release bearings. with help form a crowbar i can test if the clutch would reales properly. I finally settled for: Sprinter solid mass fly wheel. Sprinter pressure plate 308 friction plate G-wagon fork and release bearing w124 slave cylinder.
being between Jobs has left me abit short this month so no performance parts this month unfortunately. So I'll focus on some body work instead. whilst I'm tackling the engine bay, I may swell slap some new wings on it. currently
When trying to remove the passenger wing, every time i juggled it i could here the sound of rusty metle grinding together then hitting the floor. Wasn't surprised to see the hole, but instead the sill was full shredded paper, but no singes of filler or bodgeriei. Clearly a mouse had been hibernating in the sill . unfortuantly for the mouse, the car or I are not a charity so after evicting the curse word though i would should evict it for good. The engine bay is full of patches of surfice rust so i thought I would give the rust -to-metal converting gell a go though i would see how it would do on something abit more far gone Other then the bird S**T like crud around the edge i thought i did alright Joking aside, this study is amazing. first it goes a green/gold colour, then just turned to a bright clean steel
Spent the evening cleaning the in preparation for painting. I don't know how people get there kicks form cleaning engine bays. its worse then cleaning an oven, a massive greasy awquard oven that's spent its life in student accommodation once cleaned and gone over with panel wipe though i should spot cover the areas of exposed metal, there was quite allot.
urbanaw
Club RR Member Number: 17
There is something about the w123s, one of cars I will need to own one day for sure.
so this is where i need you're help. i don't want to go crazy with the build, I'm Thinking send the pump away and get 7mm elements put in. also std om606 manafold but I'm not sure about turbo options? think they came with t25 or t3's, but if anyone has any advice, I don't want to go bananas. What pump do you have on there presently? The stock ECU controlled mechanical one? For what it will cost to send the pump away to Diesel Pump UK or to DieselMeken and get built with larger elements and modified to be used with a turbo (it'll also need an Alda to supply fuel on boost and perhaps some modification to the rack?) you may want to look at getting a turbo engine, the OM606.692 as you won't be able to use it to it's full potential with the NA motor - and would it be worth the cost to do otherwise..? The OM606.692 is pretty reasonable (I'd expect around 800 for a decent one with all the ancillaries) in the scheme of things for what your build will cost and I wouldn't be put off one that is even up around 150k. If you sold your NA motor then it would also probably be the cheapest way to get the turbo and manifold as well. If you do stick with the NA motor then I'd probably just get a stock pump, manifold and turbo off of a turbo motor and be happy with the 140-170bhp that it gives you, if not you'd need 6mm elements to match a stock turbo. Putting a tuned OM606 on a manual box you'll also need to sort out the jerking from a larger element pump or it'll be pretty un-drivable, you can get whats essentially an oiling kit from DPUK - the anti jerk kit. Budget for this on a manual box with a larger element fuel pump. In my estate which I am soon to take the engine out of to put in my MegaUMM Overlander project I have a purely mechanical pump (no electronic controls) from Dieselmeken with 8mm elements in it, it has a Borg Warner 200SX quick spool hybrid turbo with 0.63 A/R housing and billet compressor wheel and a Turbo smart external waste gate. It's making 400bhp presently, all it needs is the Bosch 044 pump I have in its glovebox wiring in and it'll make 450 - 500bhp. It's currently on a modified AMG box which has been drilled (the flare mod), a home brew paddle shift system and is mechanically man enough for the job, but this I will be swapping to an AX15 manual box and Dana 300 in my overlander - because of this I have the Anti-Jerk system ready to bolt on when I take it out of the estate - it'd be undriveable without the jerk system. If it was my money I'd be selling the NA motor, getting a stock turbo motor for not much more with the turbo, manifold and pump on already and running it like that with its controller. Then in the future I'd be swapping to a purely mechanical pump with 8mm elements and the same turbo setup I've got on mine.
1987 Supercharged BMW R1150 Citroen 2cv Hillclimb Monster 1995 Renault Master Mk1 Race Transporter 1994 Mazda MX5 Mk1 / NA Road Going Class Hillclimber 1991 UMM Alter II Crew Cab OM606 SuperTurbo Diesel MegaUMM Overlander 1992 UMM Alter II Station Wagon 1980 UMM Cournil - survivor - resto project 1979 Lomax 224 2014 VW T5.1 Transporter Kombi Highline
ps. I absolutely love what you're up to though!
+100 Retro Rides points for OM606 use.
You probs know this - but Rob Moss at Chevronics is a bit of a whizz for BX parts if you get stuck on anything.
