Just looking to see what sort of value people would think my vrt'd mk2 is worth
Quite fancying a 205 gti but would like to see what this is worth first..
Specs are
1989 8v gti in tornado red (sunroof model- no leaks!)
189k on shell, roughly 114k on engine
Obd 1 vr6 engine from mk3 golf
Corrado vr6 from cross member and radiator
Gt35 copy turbo
2.5" stainless exhaust from turbo back with long life back box
38mm waste gate with screamer pipe
Audi S4 330cc injectors
Short runner intake manifold
Toyo sport intercooler
Ramair air filter
New sump and rocker cover gaskets
Schimmel performance oil filter housing
Ecu mapped by Vince at stealth racing 272bhp/273fb/lb @ 7psi boost, standard compression ratio
Turbosmart boost guage
Innovate wideband guage
Mk3 fuel tank with new tank straps and a walbro in tank 255 pump
CG Motorsport 4 paddle clutch
Hydraulic clutch conversion
Every brake line on the car was replaced 4 months ago
G60 280mm front brakes with ferodo ds2500 pads and brembo max discs(fitted 2 months ago)
8v rear brakes with new brembo discs and pads(fitted 2 months ago)
BC racing coilovers fitted with adjustable dampening rate
Momo 280mm steering wheel
New drive shafts and cv joints fitted 4 months ago
New track rod ends fitted 2 months ago
Jbl subwoofer and vibe amp'd components in front doors
Sparco bucket seats welded onto custom mk2 runners (standard interior will be included)
Azev A 15x7 alloy wheels with toyo TR1s fitted (loads of tread left)
Zender rear spoiler fitted
Front bumper has holes drilled to allow more air into rad/intercooler
Front bumper has quick release pins so bumper can be removed without having to remove cross member bolts
Car is completely solid, no rust underneath at all!
Bad points:
Body work has a few scratches/chips and dents (tried to show most in photos)
Rev counter doesn't work due to vr6 conversion
Small chip on windscreen
Grill doesn't sit right due to front panel being cut for intercooler
Inlet manifold rubs slightly on the bonnet (solid engine mounts would solve this)
Can come on g60 steels instead of azev if buyer prefers...
Specs are
Gt35 copy turbo
Ramair air filter
Bad points:
