Stu
Jun 17, 2018 15:18:50 GMT
Next it was time to tackle the CV boot... whopper torque wrench laughs at hub nut's attempts to defeat my usual breaker bar! Deja-vu... this time though I jacked the car high enough on this side to avoid any gearbox oil loss, perhaps I did learn something last time. ... about three hours of swearing and sweating later... New genuine Volvo kit this time, as advised by UB :thumb: Seems very well made and comprehensive, should do for about £55, though! :shock: Lots of greasy fun to get to tightening the final clip :thumb: Re-fitted driveshaft, tightened everything up and called it a day there for the weekend (last weekend) as I was knackered!
Stu
Jun 17, 2018 15:19:23 GMT
I resumed the fun yesterday to finish off the front brake job, not many pics but I removed and rebuilt the caliper with new seals, rubber mounts, bleed nipple and flexi hose. Then re-fitted with new discs and pads, flushed and bled the fluid to end up here. This side was the one with the flexi I was concerned about, I think it was original as it was difficult to remove, much more so than the other side but budged in the end with patience, WD40, heat and the right spanners. Bleed nipple was tricky too but came out ok so I could replace it once the caliper was cleaned up. Refitted wheel, topped up fluid and a short drive to bed the pads in and test for leaks, funny noises etc. All seems fine so left it there for now, will do the rears when I get time but they are working ok for the MOT with no binding and the handbrake seems fine.
Stu
Quick July update - daily service continues, ticked over 169k miles and passed MOT with no advisories last week, so got a well deserved wash yesterday. Latest niggles to address are inner tailgate trim flapping around due to brittle clips snapping off and a squeaky noise on startup that sounds like a slipping alternator belt. I still have the parts to replace the rear brakes when I get time too.
I’ve now owned this car over two years - that’s gone quick!
Stu
Aug 20, 2018 15:28:35 GMT
Not too much to update over the last month on the Volvo. It's been doing usual Volvo stuff, like being left at Manchester airport amongst lots of cars designed in wind tunnels and slightly more aerodynamic... That was for a trip to Stockholm, actually where I saw this fine example of automotive design and engineering to drool over. Apologies for the red thing behind. What else, oh yeah - dog transport as usual (this is NOT dogging before anyone says that, again...!) In terms of maintenance / stuff needing fixing: 1. Tailgate inside trim doesn't want to go back on and needs new clips as they are really brittle. 2. Squeak from aux belt (now fixed, see next post) 3. AC doesn't work, never has but wish it did.I checked the service history and found a receipt from 2001 to diagnose why it didn't work (when the car was only 6 years old!). This suggests it hasn't worked for 17 years due to an evaporator leak and 'noisy compressor'. Hmm... might be a big job...
Stu
Aug 20, 2018 15:29:19 GMT
The aux belt was squeaking when the engine was cold in that way that cars used to in the 70s/80s a lot more than they seem to now, and your Dad would say, 'he wants to tighten that fan belt' when you were walking to school in winter. Anyway, I had a look into it and found varying info online about belt routing lengths so called the local motor factor with my engine number and reg to order a belt. They agreed with my online research that I needed a 1623mm 6 rib belt so I ordered and collected that. The old belt and tensioner looked like this... and required some ingenuity to release without a special tool. Following the belt routing I had, the new belt was about 100mm too short so I checked the old one to see it was 1745mm actually. I also checked the pulleys and tensioner and auxiliary bits and pieces (PAS, AC pump etc.) for squeaks or bearing noise. All ok aside from the tensioner which has a very noisy pulley with a lot of play in the bearings. I later read that Volvo changed the belt routing and issued the longer belt to the earlier cars to get the belt to wrap around the alternator pulley further. Volvo nerd fact. I ordered the correct length belt and new tensioner from the same motor factor and part-ex'd the wrong belt against it. I then devised a method to release and lock the old tensioner again using a angle bracket into the 3/4 drive hole (no clearance for a decent 3/4 drive socket wrench), a large pair of stilsons and a 3mm allen key in the locking hole. Old belt was cracked and worn, new one is new. Fitted new tensioner and belt, all runs smooth and no squeaks I'm now debating whether to buy a new AC evaporator and fit that, then attempt an AC re-charge, or take the compressor somewhere to get a quote to re-furb it, or get a second hand compressor? Not sure on the best approach as I'm wondering whether the pipework and other AC bits will still be in serviceable order if it hasn't been used in 17 years...?
Stu
Nov 18, 2018 16:48:40 GMT
Overdue updates: Mid-October - got back from being away for a few weeks on holiday and found... a). Volvo battery dead b). I'd remembered to order and pickup tailgate trim clips before I went on hols, chuck them in the house and forget about them c). Volvo was filthy I started with the battery since the car wouldn't start and I needed it to work properly. I put the battery on charge but found even after charging, one start would deplete it and though the alternator appeared to be working ok, the charge to it was fluctuating and not holding. I checked the fluid in the battery and it looks ok, maybe a little low, couldn't tell if any of the plates were warped inside easily though the filler holes. Old battery: I checked the spec of the battery and looked up prices for a new one, then remembered my old BMW that lives in the garage unused has a great Bosch 70Ah whopper battery with the same connections that looked like it would squeeze into the Volvo battery tray. I could use that for now if it fits and test the alternator, I keep that battery topped up though the car is rarely used. It did indeed squeeze in, start the car quickly, and with the multimeter hooked up I tested the voltage with headlights, heated screen etc. on and off and it maintained around this figure. I like a larger capacity battery where I can squeeze one in, hence buying this one for my E30 years ago even though it was oversized. Happy with that, I moved on to replacing the clips on the tailgate interior trim that's been flapping around for months. These are the part numbers for the four upper and four lower clips you need. No pics of them fitted, but it was easy and for the first time in ages the tailgate shuts and opens without a scraping noise of the trim trying to detach itself. I gave the car a decent wash to celebrate and remembered it has a slow puncture rear right so pumped that up and noted to get it fixed soon. Late-October... 1. Oil changed at 169,700 miles and service light reset. 2. I adjusted the front right suspension strut to sort a camber problem and also had the alignment setup. A bit too much toe in was wearing the outer front tyre edges. Handling and steering feel much better now. 3. I had no numberplate lights! Both bulbs out so I suspected fuse or wiring but it turned out to actually be both bulbs that had gone, replaced and cleaned up lenses and all working again. Good news as we had a long drive planned in Nov again...
Stu
Nov 18, 2018 16:51:18 GMT
November... We had booked the same cottage for my birthday week in November as last year, on the Isle of Skye, around 420 miles each way hence the Volvo preparations. When the day came to set off, we packed the boot the night before as much as possible, packed this guy on the back seat that morning (he usually travels in the boot) and set off... The motorway run up to Glasgow went well (early Sunday morn when we travelled) and the mighty Volvo averaged 69mph according to the trip computer, not bad at all. Once we got up the A9 around Stirling and Perth the average speed dropped and the need to stop for food and drink regularly increased as we got more tired but the scenery was lovely the further north we went... We arrived at the cottage just before 6pm (we left home around 8am!), tired but happy. The Volvo showed 420 miles and an average of 31mpg, pretty good for a 23 year old 5 cyl petrol turbo now passed 170k! Whilst staying on Skye we did some exploring to Portree one day, which was lovely. Sunrises looking north from the cottage windows were quite nice. Otto liked them too... The roads on the north east of the island weren't too busy by the 'Old Man of Storr'.... Uig ferry port Uig happened to be home to the Skye brewery too - who make some lovely ales... We had a great week up there, then drove back over two days with a stop off in Stirling to break the journey up. Relentlessly grim weather coming back so not many photos but I did like this weird misty stuff in the highlands. Reminded me of driving in the Rockies in Canada! We got home eventually, the Volvo showing around 1100 miles more than when we left and now closing in on 171k. Ran perfectly, heated seats on for most of those miles - great car!
Stu
Dec 27, 2018 14:30:14 GMT
Update from earlier in December... Firstly, collecting a 6 ft tree... 'tis the season... Earlier in the week I had ordered a new expansion tank cap (green one) as my old one appeared to be letting a bit of coolant pressure out and staining the top of the tank. As I'd been slowly loosing a little coolant over the last month, I thought this may sort it. I also remembered that I'd meant to change the spark plugs, so asked the Volvo parts dept. to add a set of those to my order too, may improve economy a little as they haven't been changed in my ownership? I called at the dealer and my low coolant light came on, checked and the level had dropped but it was now apparent that the cap wasn't the only issue as there was a dribble of coolant from the bottom drivers side of the radiator. The opposite side to the bottom hose so not likely to be that. I asked the Volvo parts bod to price up a radiator (£288+vat and has to come from Sweden) for reference and said I'd investigate further. Anyway, I fitted the new plugs (seems to idle lower and run smoother on a quick test run around the block, so fingers crossed for an extra 1 mpg!). And then checked where the radiator was leaking, looks to be where the plastic end tank joins the main section aluminium part. It has an oil cooler in this end of the radiator too, but no sign of leaks there or cross contamination. I dried it off, ran the car and confirmed it gets slightly damp as the car warms up, very little coolant loss but certainly needs sorting ASAP. I topped the coolant up with the proper green Volvo stuff and now need to investigate whether a decent aftermarket radiator will do as over £300 for a genuine one seems steep even though the part (and car) will likely outlast me :
Stu
Dec 27, 2018 14:31:02 GMT
Festive update! As above, the radiator had developed a leak so after checking the options I decided to go for a Nissens replacement item. It was correctly specified for a manual car as it has the oil cooler in one end, but not the auto transmission cooler at the other end as for the auto cars. I ordered it from a seller on eBay for approx. £90 inc. next day delivery so it was here before Christmas, and included new clips for the oil cooler connections. On boxing day I set to in the driveway to swap the radiator. Firstly getting the car quite high (radiator comes out underneath) and draining the coolant. Part way through pic, old rad out and new one going in. You have to leave the AC radiator in place, but take the intercooler out attached to the coolant radiator and swap it, and all it's fixings, over to the new part. Bit fiddly but not too bad. The worst bit was the captive nuts each side of the radiator shearing (I thought they probably would) and needing to be removed, bolts sawn off, and replaced with new ones. Added a few hours to the job, bent a drill bit and wore out a hacksaw blade... Spot the shiny part before it got buried under the fan housing, intercooler pipes and all the rest of it... I used new o-rings in the oil cooler line connections as I had those ready, new clips to secure them plus a jubilee on top for good measure as previously. All went back together ok, took about 6L of coolant and bled fine with no leaks and the heater working properly last night. I checked it this morn, added the last 1/2L of coolant and went for a short trip to the shops, all seems fine so I'll keep an eye out for leaks and hopefully that's it done.
Dec 27, 2018 17:11:28 GMT
I like these old buses. They made a huge impression on me when they arrived in Touring cars competition. Great to see yours getting so well kept.
Dec 27, 2018 19:25:45 GMT
Another great job and on Boxing day as well (commitment). I'd love another 850, miss my 850R it was extremely capable and a proper sleeper.
Dec 28, 2018 11:43:47 GMT
Hi Stu, I’m pretty sure it was you that I bought an oak green mk2 golf from a good few years back now (actually thinking on, I think you bought it back off me!).
Either ways, just enjoyed reading through this, I’ve a lot of respect for these old swedes. I was renovating a house a couple of years back and ended up buying a poverty spec 2.0 to use as a van, for £156 off eBay (which should give some indication as to its state). Well I cannot tell you the abuse that that poor vehicle sustained and it’s only complaint was to throw off an HT lead - the original 23 year old part. Two years on and with pretty much zero maintenance it’s still going - I gave it to my stepdad.
I can imagine a well sorted T5 to be pretty much all the car you’d ever need and yours looks very well sorted now.
Stu
Dec 29, 2018 14:42:34 GMT
Cheers, All Hi Stu, I’m pretty sure it was you that I bought an oak green mk2 golf from a good few years back now (actually thinking on, I think you bought it back off me!). Either ways, just enjoyed reading through this, I’ve a lot of respect for these old swedes. I was renovating a house a couple of years back and ended up buying a poverty spec 2.0 to use as a van, for £156 off eBay (which should give some indication as to its state). Well I cannot tell you the abuse that that poor vehicle sustained and it’s only complaint was to throw off an HT lead - the original 23 year old part. Two years on and with pretty much zero maintenance it’s still going - I gave it to my stepdad. I can imagine a well sorted T5 to be pretty much all the car you’d ever need and yours looks very well sorted now. Ah ha - nice to hear from you, Mr Twincam! I do indeed remember you, and that Golf (H897VAA) which I owned twice as you say Yes, the Volvo 850 is a great old thing and the T5 feels a bit like a bigger, more comfortable (and probably quite a bit faster) Mk2 Golf GTI, actually. Nice direct steering, old fashioned basic feeling but comfortable on long trips, loads of space, and you can park it anywhere. So unfashionable, it's almost fashionable, haha! Hope you're keeping well, what are you driving now? Cheers Stu
Cheers, All Hi Stu, I’m pretty sure it was you that I bought an oak green mk2 golf from a good few years back now (actually thinking on, I think you bought it back off me!). Either ways, just enjoyed reading through this, I’ve a lot of respect for these old swedes. I was renovating a house a couple of years back and ended up buying a poverty spec 2.0 to use as a van, for £156 off eBay (which should give some indication as to its state). Well I cannot tell you the abuse that that poor vehicle sustained and it’s only complaint was to throw off an HT lead - the original 23 year old part. Two years on and with pretty much zero maintenance it’s still going - I gave it to my stepdad. I can imagine a well sorted T5 to be pretty much all the car you’d ever need and yours looks very well sorted now. Ah ha - nice to hear from you, Mr Twincam! I do indeed remember you, and that Golf (H897VAA) which I owned twice as you say Yes, the Volvo 850 is a great old thing and the T5 feels a bit like a bigger, more comfortable (and probably quite a bit faster) Mk2 Golf GTI, actually. Nice direct steering, old fashioned basic feeling but comfortable on long trips, loads of space, and you can park it anywhere. So unfashionable, it's almost fashionable, haha! Hope you're keeping well, what are you driving now? Cheers Stu I’m good thanks and the same to you! I’ve had absolutely all kinds in the intervening years. Until very recently I had a company car so I always had some form of chod to mess about with. Off the top of my head that’s included Alfa GTV V6, GF8 Impreza WRX, Pug 306 GTI-6, Prelude, W202 C250 Turbodiesel, AE82 Corolla GT, Mk1 MR2 (owned that twice)... I decided I should get a sensible car after losing the company car so got an E39 530d Touring Auto which I liked but my commute is stop start all the way for an hour and it was doing 25mpg and had a dodgy injector so in my infinite wisdom I bought something “a bit newer and cheaper to run”... An Alfa 147 Ducati Corse (it’s just a runout model diesel with +20bhp and an LSD) which rewarded me by lunching it’s clutch 4 weeks after purchase 😑. I’m actually sat up in bed now with back ache because I replaced the front disks & pads earlier and had to go nuclear on some very well seized caliper carrier bolts. Why do we do it, eh?
Stu
I’m good thanks and the same to you! I’ve had absolutely all kinds in the intervening years. Until very recently I had a company car so I always had some form of chod to mess about with. Off the top of my head that’s included Alfa GTV V6, GF8 Impreza WRX, Pug 306 GTI-6, Prelude, W202 C250 Turbodiesel, AE82 Corolla GT, Mk1 MR2 (owned that twice)... I decided I should get a sensible car after losing the company car so got an E39 530d Touring Auto which I liked but my commute is stop start all the way for an hour and it was doing 25mpg and had a dodgy injector so in my infinite wisdom I bought something “a bit newer and cheaper to run”... An Alfa 147 Ducati Corse (it’s just a runout model diesel with +20bhp and an LSD) which rewarded me by lunching it’s clutch 4 weeks after purchase 😑. I’m actually sat up in bed now with back ache because I replaced the front disks & pads earlier and had to go nuclear on some very well seized caliper carrier bolts. Why do we do it, eh? Haha - sounds like you're as bad as me for punishing yourself with old and obscure vehicles! Keep up the good work, all the best!
Stu
Feb 22, 2019 11:56:06 GMT
Nothing too exciting to report on the Volvo, daily commuting is going well, I keep feeding it petrol and now cover around 500 miles/month at 21mpg average commuting, plus a bit of weekend mileage. Oh, I fitted new tyres in Dec, same spec Uniroyal Rainsports to match the rears which are still fine (T5s consume front tyres and petrol quite rapidly). Aside from that, when it was particularly cold weather I noticed what appeared to be exhaust fumes entering the cabin. I checked all the usual bits and pieces looking for petrol leaks, exhaust leaks, PCV blockages etc. and found nothing wrong, but one thing that may be the culprit as it only happened in heavy commuter traffic. The fact the car, like many of these, has never had a cabin filter fitted. The fresh air intake for the heater is here in the scuttle panel. I believe the absence of filters has led to the deterioration of many A/C evaporators too as that lives down there with the heater blower behind the dash and gets a bit damp if this gets full of leaves. I wonder if that's what happened to mine? Anyway, as I didn't have anywhere to fit a filter I did some reading on what's needed and found a helpful chap on the Volvo forum was breaking a C70 which did have a filter fitted so had a different part to house it that would fit mine. He posted it to me for a modest fee. Here it is with a new cabin filter... I swapped the part over and fitted the filter. No fume problems since (yes, I did reconnect the strut brace afterwards...) Closing in on 173k miles now.
Last Edit: Feb 22, 2019 11:56:49 GMT by Stu
Stu
Apr 20, 2019 14:25:43 GMT
Update: All change! I have bought a replacement daly driver, so the Volvo will be for sale soon. I'll put an ad in the for sale section if anyone is after a turbocharged Swedish wardrobe transporter?
Don't tempt me, I'd love another but already have too many cars and projects still waiting attention.
Stu
Apr 21, 2019 15:59:59 GMT
Don't tempt me, I'd love another but already have too many cars and projects still waiting attention. I know the feeling! Added new photos from today to my for sale ad, here: For Sale ad
Stu
Apr 22, 2019 10:41:46 GMT
The car sold this morning, sad to see it go!
