Time to sort the steering.. The problem I had was the Quadzilla steering column didn't fit the mount on the frame, and the gauge pods I made would not bolt on! But I still needed the bottom of the column as it does the steering bit! So I needed the Honda top half and the Quadzilla bottom half, of course they are not the same diameter and one would not slide into the other! A little bit of lathe work later had the solution to joining the coulnms together and keep them straight.. A close up. To make sure nothing would move lot's of holes were drilled so I could plug weld through to the adaptor thingy.. My Murex Mig welded won't go all the way up to "Spinal Tap", so I turned it up a notch to 6 and zapped the parts together.. Cleaned up.. The good news is the column ended up exactly the right length, straight and the top and bottom halfs lined up, so it was bolted back in.. To celebrate the light and gauges were also bolted on. MadTrax looks kinda strange with no wheels, tank or seat on! Now onto something fun, or not.. Wiring!!! I had already removed anything not needed from the Honda CX loom, but I also needed to splice in some of the Quadzilla loom! With the Quadzilla loom trimmed back to what I actually need things didn't look that scary! To finish off thus update, a couple of videos.. Part 18 covers the above stuff, and in part 19 I get to start MadTrax for the first time
My YouTube Channel www.youtube.com/user/UkWheelHorseBlokeQuote - D'you know, it's people like you, doing totally brilliant and pointless stuff like this that gives me a little hope for humanity
Feb 25, 2018 11:27:05 GMT
Morning all, it's that update time again.. Although the wiring was operational enough to get the engine running, for some reason I just could not get the two warning lights on temp guage to work... These three! The one place where the lights/temp guage connect wiring wise is the voltage regulator which should (or so I thought) power the lights etc.. Now I will admit to to getting the power leads to the battery around the wrong way once, that coupled with finding out the regulator should be rubber mounted to the frame (so it doesn't earth through the frame) rather than bolted directly to the frame as I had done once! So... Everything pointed to a fried regulator being the problem, a replacement with correct mounting bracket with the rubber bits was ordered.. The result??? No Change! The problem is this black wire from the regulator, there should be power in it but it was missing! Time for a coffee and a bit of research on the internet to find out exactly what the blasted black wire does.. As it turned out it's the wire the regulator uses to keep a check on the voltage and should be connected to a live.. At the front-ish of the loom is this connector that has been taped up as I thought it wasn't needed... Yes it's the other end of the black wire and it should of been connected to a live feed form the ignition switch! "Bangs head and has one of those Doooohhhhhh moments"! With that black wire connected to a live this was the result I know that in the grand scheme of things a couple of warning lights isn't a big deal, but it was really bugging me as to why they were not working!
Feb 25, 2018 11:31:34 GMT
With the wiring (mostly) sorted I couldn't tidy the loom up without knowing where all the wires would run to... All of which means I had to find somewhere to mount the battery! The only place for it to go was just infront of the rear R/S wheel (no pics as it's hard to hold a battery in place and take photo's at the same time), no ideal but it just would not fit anywhere else! I had already built a battery box, but hope to mount it??? This TB mount looks a good start Lot's of chopping and welding later it looked like this. Checking the battery box fits.. TB/Batt mount bolted back on to MadTrax Battery plonked in place.. It feels nice and strong with no movement and will hold the battery in place no problem
Feb 25, 2018 11:51:56 GMT
Now, back to the wiring... This isn't what's left of the loom, it's all the bit's I didn't need mostly chopped from wires that were too long! As I went along all the crimp connectors were removed and the joints soldered up before being wrapped in tape.. At least I know the loom won't pull apart now Battery end of things. This bit of the loom was a massive mess with lots of crimp connectors! It looks way better now The front end splits nicely into two, it will split nicely into three when the headlamp is wired in. Speaking of the headlamp, these "not yet connected" wires go to the Quadzilla switch gear and are the very wires that give life to the lighting circuit. And the horn A day was spent turning this mess.... Into this non mess...... A day well spent Having already mounted the voltage regulator the wrong way ie bolted directly to the frame, I needed to find a good way of rubber mounting it.. Which is where the random bit of Quadzilla comes into play as it has a few holes already with rubber isolating mounts in it... Just not quite in the right places..... Soooooo.... Chop of the unwanted bits. Slice 4mm from the middle. Weld the two halfs back together. That should be strong enough Drill a hole. Bash the bend flat. Drill a second hole then test fit. Cut and grind the bracket to shape. Bolt the regulator back on to the bracket. Bolt the whole thing back on to MadTrax, plug the wires in.... Job done Whilst looking through the Quadzilla wiring loom for plugs and sockets I could use to wire in the front diff, I noticed something that would be a good and sensible upgrade to MadTrax's wiring.. A small bracket later. Which fits under the seat.. Or will do when the seat is on And I have a modern fuse box installed. The next fun job will be working out how to fit a modern headlamp bulb in the back of this old army type lamp!
Feb 25, 2018 12:08:43 GMT
As ever, great stuff...
As ever, great stuff... Thanks George. With the 4 wheel drive bit wired in, the time had come to think about lights starting with the er.. headlamp.. Not having the correct bulb holder (which would of been for a really old style bulb anyway) I had this problem to overcome! I had an idea on how to solve the er..gap problem but not the materials until Nigel found me this old pully.. Thank mate No photo's of all the lathe stages (plenty of that in the next video) but the pulley ending up looking like this. The shallow slots were done with a milling bit in my pillar drill. Not ideal as the bed does try to move sideways! The bulb pokes through like this. Then the whole thing drops into the back of the lamp bowl. The little black slot through the bowl is a handy bolt hole, as is the one the other side. Now something to hold the bulb to the holder. Starting with this.. Thanks again Nigel It was turned into this.. Which of course fits here.. I found some nice small bolts to use but I didn't have a tap to cut a thread..... So I made one Best test it.. Yep it works... Lots of drilling, thread cutting and countersinking and bolt shortening later.. Tad-Daaa A lot of work for something that won't be seen
Mar 17, 2018 18:11:22 GMT
Evening all, more of an update for you starting with a video.... Lot's of timelapse bits Back to the headlamp but only very quickly.. When it came to wire the lamp in I found there wasn't enough space around the outside of the bulb holder to run the wires,so three holes were dilled and then slotted to feed the wires through. Time to turn to the other end of MadTrax.. Starting with a cardboard template.. Which fits about here. I'm sure you will of guessed by now it's for a rear light.. Even though I've no plans to put MadTrax on the road it needs a rear light to balance out the front light.. Not having any rear lights that will fit I need to make my own, starting with this Honda Silverwing light lens. Trimmed to shape including the lens inside. Hard to hold in position and take a picture! I have an idea on how I want the rear light to look, template time.. Rubbing dirty fingers on paper to make some marks and then cutting out didn't work too well.. Template number 2 involved cutting lots of bits of cardboard but it looks much better and is much more usable as an actual template Turning this into steel is going to be fun The transfer box gear stick needed a tweak so it wasn't in the way of any knees, so it was moved in by an inch, lengthened and a new hip and groovy knob was put on the end It needs a little tidy up but it looks good
Mar 17, 2018 18:36:00 GMT
Back to the rear light and I needed some sheet steel to make it from. This will do.. Yes it came from our old tumble drier and still has some fluff on it to prove it A grinder with a 1mm disc was used to cut the long slices, a sharpened screwdriver (yes it was a very old one of which I have many) was used to chop the ends out. Lot's of time spent with a file later and the lens almost fits. Time to bend the edges round, wanting a nice curve some bar stock was used for beating around. Taa Daa. A lens check. "Let there be light" And held in postion.. More to come later, food is needed.
Mar 17, 2018 20:42:40 GMT
Simply awesome
spiny
Wiki Admin
I am abivalent towards car electrics ...
Club RR Member Number: 167
love the rear light, and the fuse box holder
ric
Just spent a lot of the day reading this thread from the start. Great stuff 😎
DEVON T25
Thanks Mikey, happy you like it love the rear light, and the fuse box holder Thanks Spiny, the rear light has been a lot of work but worth it. Just spent a lot of the day reading this thread from the start. Great stuff 😎 Hi Ric, I guess you had quite a few hours to spare as it's a long read, or were you just trying to escape all the Easter nonsense? Thanks for reading right through the thread anyway In case anyone is wondering, no I've not been eating since the last update, life just has a nasty habit of getting in the way at the moment! It was at this point my hands were not too happy about beating and shaping metal, so I thought I do something less hand straining on the lathe.. This UJ was part of the drive system when I thought lot's of UJ's were a good idea! The problem is I had also welded a splined bit inside one end, and the said splined bit fit's the splined shaft that comes out the bike gearbox! It's a shame to chop a UJ up, but when needs must.. Here's what's left of the UJ on the lathe having just broken through one end so I can get to the splined bit. The hidden splines.. Knocked out with a hammer and drift. All that work for this little bit of steel slid on the gearbox shaft! Time to think about mounting this large lump of 90'd drive! This 10mm thick steel plate should be strong enough Lot's of lathe and drill action later... (all the action coming up in the next video). Bolted on..
It was at this point I started to have a few of those "Groundhog day" sort of moments! Having worked out how to make a shaft that fit's over the gearbox splines, has a bearing at the other end and also has a sproket in the middle, I proceeded to make a mess of things 3 times! Attempt 1... Having just checked the bearing fit I forgot to tighten the tailstock back up for the final cut! The result was some nice deep gouges! (not seen in this pic as I trimmed some more off to check which tools cut best) Attempt 2... Counted twice what I should of done and took too much metal off making the bearing a loose fit! Attempt 3!!! All was going well until I broke a small drill bit off about 1/2 inch in!! No way of getting it out! Attempt 4... It may need a bit of work at this point! And attempt 4 in it's finished (and correctly sized) state. Phew... I hate having to redo stuff! Not a perfect finish inside, but the measurements are right. The splined bit pressure fitted, a nice tight fit.. It will be welded on then the welds and overhang will be tidied up on the lathe. And finally with the bearing, I still need to buy the sprockets but as they will need boring out to fit the shaft I could get on and make this part..
Plenty more lathe work to go, I needed to make something that would fit over this stepped shaft on the TB input side of things. The reason being I need to fit a sprocket to the shaft but there isn't a keyway for location, only splines at the outer end. Lot of time was spent with some 40mm bar to create this. Outer splines presure fitted to the sleave one end, it will be welded also. Stepped inside to fit the shaft. It would of been nice to cut a taper inside to match taper on the shaft, but don't have the tools to do it.. Splined sleeve bolted on the TB shaft, the sleeve walls are not thick enough to cut a keyway so the sprocket will have to be welded on. That will do for this update, I do have more to post but I seem to be missing a few photo's.. I must remind myself to take some more pic's tomorrow..
As ever...
May 20, 2018 10:48:21 GMT
As ever... Thanks George Hi Guys n Girls, quite a big update for you.. Back to the 90'd drive thingy from the Honda Silverwing that I'm using to turn the drive around.. On the bike the rear wheel would of bolted to this bit. But I need to put the drive from the gearbox into the 90'd drive from this way... But how to bolt a sprocket to it? Starting with a slab of 10mm thick steel and a photo that won't turn the right way! To bolt the splined bit flush on the plate I had to cut a wide groove in one face. That looks good. To fit a sprocket to all this a shaft is needed.. This will do. It fits in the circular plate like this, the tapers will be filled with weld. The other side will get welded on and the welds turned down to look good on the lathe.. The shaft has been made over sized as I don't know the measurements until I get the sprockets and try to fit the whole thing in place. This is quite a big "whole thing" to fit! Nows a good point to drop in the next video..
May 20, 2018 10:57:12 GMT
As I didn't have the sprockets at the time, and most of the jobs left to do involve having the 90'd drive in place, I was scratching around for something to do on MadTrax, so I decided to sort this little problem out! The problem being it should fit here (the tape is only to keep the dust etc out), but I don't have a key for it! But I do have this tank from a Honda CX trike with a locking cap... I feel a bit of tank slicing coming up It would of been a shame to scrap the fantasic art work... So I now have some more wall decoration The filler hole section was cut from the CX tank, cleaned up and tried for size on MadTrax's tank. To mark where I would need to cut on MT's tank I needed to cut out a small section so the new bit would sit flat.. And here is the very same hole after being part welded back in! Yes my brain wasn't functioning to well that day and I cut too much out! The correct size hole marked and cut out.. A test fit, only a few little tweaks needed.. While I was getting on with the welding Rob was cleaning all the paint off the locking cap thingy. Quite a few layers of paint! Ta-Daa As you can see with the flap open it needs a little bit of filler work.. Not much though I gave it a quick coat of paint to help show up where I may of missed any welding... Here's one of the holes The new cap looks the part, I can't decide if it needs painting of just a coat of matt clear coat.. Time will tell
May 20, 2018 11:35:26 GMT
Still no sprockets, so I thought I'd continue with the rear light.. Starting with this not quite flat steel sheet. By not quite flat I mean the sheet has had a big cross pattern pressed into it which I though would be good for the back of the light box.. Marked out ready for cutting. Lot's of chopping, welding and weld dressing later I had this. The cut out at the base is so the box can fit over the anit roll bar tube. These are the bulb holders I will be using.. This ally plate is the right thickness to hold the er.. holders nice and tight, so five holes and a bit of cleaning up later. To mount the bulb holder plate to the inside of the light box but leave enough space behind for wiring etc I made one of these.. Captive nuts welded on the back. A quick bulb test fit. Curved panel made to fit the anti roll bar hole.. But before it was welded on the bulb holder plate was plug welded in.. Checking the bulb holder still fit.. They do A view inside Lot's of welding and weld dressing to do.. That looks better Best check it still fit's MadTrax!! It does Some of the welds down the sides needed a few extra blobs of weld to tidy them up.. That will do for now, need some lunch..
May 20, 2018 16:02:18 GMT
Right, let's get some more of this update done. The front edges needed a bead of weld to fuse metal together.. To make life easier I clamped on a flat brass bar to weld against as welds will not stick to the brass. As you will of noticed on the above photo the longest which is also the top panel is a little on the wonky side.. A big thank you to Rob for the square which came in handy for showing how wonky wonky is.. As the metal is too stretched to hammer flat some extra straight strength needs to be added.. Starting with a strip of double skinned steel. Most of one skin was cut away leaving only a small rolled edge sort of thing. A quick trip to the sheet metal folder which I should use more than I do! Plug welded inside.. The bit of black box section is only to make sure everything clamps down flat.. Can you spot a slight problem here? Yep, the box is such a good tight fit it won't come back out again! The next step was to make some mounts for the rear light, but a parcel turned up containing these sprockets The rear light is going to have to wait, getting the drive train finally finished needs to come first.. Soooooo, the first sprocket on the lathe being bored out to a larger ID.. Video time again
May 20, 2018 16:21:43 GMT
I have been mostly spending a lot of time at the lathe turning down this, boring out that, and trueing up the other. Not that many photo's but this was quite interesting to make out of two parts and a bit of welding. It's not quite finished in the photo, only a bit of tidying to do.. A bored out sprocket is a nice tight fit on the shaft. Now the fun part, making the 90'd drive thingy fit in not much space.. It's in there somewhere! This view might help to see what's going on. Or not! The plan was to fit this sprocket to the shaft that comes from the Honda gearbox.. And put this bearing at the end to hold things steady.. The trouble is, not enough space, the drive shaft to the front takes up a fair bit of space too! Soooo... The plan now is to mount this bigger bearing a lot closer to the gearbox case and fit the sprocket on the end only much more forward than it was.. Of course I don't have a bearing holder for the bigger bearing! So a bit of thick steel slicing.. Cut's well for a £10 power saw An almost flat plate. Flat and mostly bored out.. Some more turning later and half of the bearing holder was just the right size, a nice tight fit that will need gentle press pressure to push it in.
