Rear arb makes a huge difference to stability and just needs a couple of brackets making to adapt the movano rear bar as it has a very similar set up to the Talbot . Front bar is fairly simple too but I re drilled the Lower arm inboard pickup brackets to get rid of the positive camber pulled the shim stack out of the front tie rods to get s bit more caster as mine has a hydraulic steering rack and a bit more caster helps it self centre . .
I get 24mpg at a steady 75mph as any faster is on the edge of running in boost due to the non aerodynamic shape and wind noise is a bit intrusive at higher speed .
