As the author of possibly one of the most irrelevant threads on Retro Rides, can I say how much I have enjoyed your build from way back.
The level of detail and effort is fantastic. Thanks for documenting it all so well and in a way I'll be sorry when its finished. 😊
gess
Wow, it's really a crowded engine compartment. you really have had your work cut out for you getting all the pipes, hoses, sensors etc in place. Guess you are exited about starting it up!. nice looking manifold! Hope your paint stick.
Jun 12, 2017 16:33:10 GMT
Excellent work!
Jun 22, 2017 20:09:17 GMT
Hi, I thought it'd be good to post the current progress, because other ways my posts became too big and too picture heavy. So, nothing special lately. I'm doing small and bigger steps forward to the first engine start. I have to say I could made first engine start attempt even right now, but my plan is to get the engine and all its sub systems fully functional and loaded, i.e 100% ready before the first start try. Then, except some possible leaks I'll have to deal only with the engine ECU settings and basic tuning. But let me start with the pictures though, because my desperate English is not the thing I want to praise with :-) So.... I wanted to reinforce the turbo header and to get few additional attachment points for the heavy turbocharger (10kg): I wanted to hide the weld from behind the bracket so it would look much better imho: The good old saying "A picture worth a 1000 words" helps me to save your nerves from my struggle with the language. Here is the oil rad unveiled for the first time. Тhere are 2 kinds of oil rads on the market. The main difference is the fin size. My choice was an oil cooler with the wider fins because I think it'd flow/pass more air, i.e. better cooling effect: I still plan to make some air duct for it, so it could get forced air from under the bumper when diving. Then I had to connect the cyl head outlet coolant passage to the thermostat housing. In the OE system, the heat exchanger rad is connected in series to this link. I'll skip the exchanger and the inside heating at all for the first car release mainly due to the lack of time, funds and the planned summer/good weather only driving. Sometime later I'll add the heating. A reducer connector was made for the purpose: This is a view from inside the car over the gearbox tunnel. There was foreseen a special access for the thermostat housing and the engine cam sensor: Later wen I receive my heat shield blanket, I'll cover all the hoses and wiring in the vicinity of the exhaust manifold and the down pipe. I wanted to finish the turbo air pipe support bracket. I had also to clear the area around the first cyl. spark boot and plug for an easy access: This is an important bracket because it holds the air pipe fixed and so the inlet part of the water intercooler suspended. The BOV and turbo to bonnet clearance: As it was said earlier in the thread , my turbo was cheap Chinese Garret T67/ T04R or sort of copy. Although I paid 250 Euro for it I wanted to do what I can to test its full capabilities and to delay the purchase of a new OE one as much as possible (lack of funds sake of). So, I took it to a local turbo service for balancing. I was surprised when the operator invited me inside the shop to watch the process. The second surprise was when the turbo showed almost zero vibrations up to 60K and lately up to 70K rpms, i.e. it has been balanced in China! It's a very good result for a relatively big frame turbo with cast compressor wheel. Now it remains only to withstand the "real life" in car beating :-) Here is a look from the cold air box. The compr. wheel ID is 66.6mm: The rad cooling taken seriously: Then it was time to begin with the work on the wiring seal in the firewall area. This was a long time delayed task mainly because of the lack of ideas how exactly to do it. So, here is one way. This is the OE seal behind the OE fuse and relay board/box: WP_20170622_002 by Ivo Bla bla, on Flickr WP_20170622_003 by Ivo Bla bla, on Flickr WP_20170622_004 by Ivo Bla bla, on Flickr WP_20170622_005 by Ivo Bla bla, on Flickr Still have to weld it and add some studs for attaching to the firewall , but this will happen sometime later. WP_20170622_008 by Ivo Bla bla, on Flickr WP_20170622_010 by Ivo Bla bla, on Flickr That's all for now. As usually, endless thanks for watching and for the supporting comments. Stay tuned for more... Ivo
Last Edit: Jul 8, 2017 8:08:12 GMT by Deleted
Jun 23, 2017 18:39:35 GMT
I'm really sorry to see that, but it appears my whole build thread and posting work were ruined by Photobucket. I didn't touch or change anything. The pictures are still in my PB library but it seems the links are dead. The same is with another forum where I post the same pics/links. I don't know what to do...
Jun 23, 2017 18:48:07 GMT
Find another picture hosting sevice that is all you can do as PB only give you so much band width for free and you have used it all.
Jun 23, 2017 19:25:19 GMT
As Pete says, you've exceeded the bandwidth limit for Photobucket's free service. It's because so many of us have been viewing them via the forums.
I had exactly the same problem a year or so back. There's not much you can do. You can look for another hosting service, and change all the links. You can pay Photobucket the nominal amount they charge to allow a higher bandwidth; or you can wait a month or two for them to reappear. In the end I just paid the small amount as it was easiest.
jonomisfit
Club RR Member Number: 49
Jun 23, 2017 20:57:10 GMT
As the posts above. I think its $2 per month for the next hosting level up.
Jun 23, 2017 21:04:51 GMT
Or learn to use flickr, which is free, has no bandwidth cap, and has a terabyte of space.
Jun 24, 2017 18:54:47 GMT
Ops, I'm trying to switch to flickr, but have problem with the pics links. Sorry for the blank post
Last Edit: Jun 24, 2017 19:14:00 GMT by Deleted
Jun 24, 2017 21:17:16 GMT
Ops, I'm trying to switch to flickr, but have problem with the pics links. Sorry for the blank post That's why I said learn, not use, haha. How I do it, is in the bottom right when you hover over a picture in slideshow mode, there is an arrow, which when clicked on gives you size options. Click view all sizes, and it'll give you a bunch of file sizes, I find 800x to be about right for forums. Then when you have the size you want, right click the picture and choose copy image location. That link will paste directly in to the image url button in RR. If you sort your pics in to albums you can get them ready to post chronologically quite easily. I tend to use the slide show and middle click with my mouse wheel to open the 'view all sizes' option in a new tab. Then you can get a bunch going quickly without having to hit back all the time. And it's easier to keep track of what you've posted if you close the tab after you copy the image location.
Last Edit: Jun 24, 2017 21:19:17 GMT by varelse
Last Edit: Jul 8, 2017 8:36:57 GMT by Deleted
Excellent!
Good to see you've got flickr working, mostly. I've never had any issues with bandwidth or anything else with flickr.
Jul 20, 2017 21:55:46 GMT
Last Edit: Jul 20, 2017 22:28:32 GMT by Deleted
tristanh
Routinely bewildered
A lot of work went into that plumbing I bet.
I like that Provent, is it a standard item on some car?
Jul 21, 2017 21:39:29 GMT
A lot of work went into that plumbing I bet. I like that Provent, is it a standard item on some car? Hi tristanh, I believe it is offered mostly for retrofitting . I found in Australia and USA it is offered as a kit for some diesel pickups.
Jul 21, 2017 22:34:44 GMT
Incredible work! I think with your skills you should be able to find a job soon.
k1664
Jul 23, 2017 20:13:58 GMT
Impressive attention attention to detail, nothing looks out of place.
Jul 24, 2017 13:14:36 GMT
hi... Have you photos of the steering rack and columm inside the car ? I live in Brazil and bulding a Lada 2105 with VW EA827 engine.
Fabiano - VW Corrado 16V Turbo / Lada 2105 1.8 Turbo
