Thanks for the help so far guys, heres a few more photos of it. Is this the start of a new pistonpopper thread, "12 R/C cars, all without controllers, in a year"? Ha haaaaaaaaaa... georgeb you're a laugh, i'm still recovering from last years effort lol.
looking at the one on ebay its definitely a 27 mhz transmitter... I would be going on ebay and picking up a cheap tx and see if it works, you either need one that takes crystals, or is fixed at 27.095 mHz.
In fact, thinking about it, I might have a set of 27 mHz radio gear in the attic...
MonzaPhil
Think like a man of action, act like a man of thought
Some of the 40 or 50 . . .
This is now a clicky linky!
I think somewhere I still have my steer wheel version of the Acoms Techniplus....Its pretty period to go with the Procat and PB Maxima
^^ Way it was built,no diff Many thanks all for the info; got some research to do - I'll shut up now & 'un-jack' the thread...
hario
S202 C300STD
Jun 21, 2016 11:25:30 GMT
Weird frequency, UK ground based stuff is 27MHz, 35MHz is aircraft only, ground vehicle prohibited, don't know 49..
Any old Tx controller Futaba, Tamya, etc will have removable xtal's, so open it up and the installed xtal (almost certainly soldered in), will have the frequency etched on the side, so just buy a matching Tx one and install in the controller and go. The Futaba, Tamya, etc all have reverse switches on all the channels so ok in that respect.
I wonder if 49MHz is AM though, probably won't work with 27MHz FM controllers..
Looks nice though. Does it take AA's or 7.2v packs? Because upgrading to NiMh will give loads more beans!
*S202 C300TD Wagon* Installed: OM606 & 722.6, Evo6 IC, S600AMG callipers & 345mm rotors. No catz. Leatherish seats.. Rust.. Future: DIY manifolds & turbo compound build. Built IP, & some kind of software. Less rust..
May 23, 2018 22:55:31 GMT
Hola! AquĆ desde Argentina te cuento que tengo un auto como el tuyo y tanto el auto como el control tienen un sticker que dice "band 3 27.095 MHz".
