Mar 10, 2016 20:34:41 GMT
Yeah, I'll have to do some research because avos are just too expensive! Yeah same here! I'm considering chopped springs to be honest! Mine was on cut springs when I got it. It was so low the exhaust clamps dug grooves in the dirt when I moved it out of the garage... EDIT: Pic really doesn't do it justice Yeah! I'm gonna try the 60mm method first, if not, I'll be doing the chop chop, just like i did on my first micra haha
Mar 10, 2016 20:55:39 GMT
Might be able to get some secondhand stuff cheap spax etc on the escort pages .
Might be able to get some secondhand stuff cheap spax etc on the escort pages . I've become a member of a few pages, I'll see what I can sort out!
bigdaz
Mar 11, 2016 11:53:34 GMT
Rally design do coil over conversation kits, much cheaper then off the shelf stuff, got to be worth a look
Mar 11, 2016 15:15:57 GMT
Rally design do coil over conversation kits, much cheaper then off the shelf stuff, got to be worth a look I'll check them out mate, thanks!
Mar 13, 2016 13:33:45 GMT
Afternoon guys! After losing out on the exhaust system i was planning to get, this rs turbo exhaust system came up for sale at a not too bad a price, so i won it today, we collected it today in my dad's ever trusty volvo and here it is!...
ajc91
Mar 14, 2016 19:13:22 GMT
Good luck with the exhaust bud, mine was a b1tch to fit! Ended up having a mate make it from scratch using an old powerflow system.
A.J
Mar 14, 2016 20:23:53 GMT
Good luck with the exhaust bud, mine was a b1tch to fit! Ended up having a mate make it from scratch using an old powerflow system. A.J Yeah! Mines gonna be custom made to fit the back box but at the price i paid, i can afford to hack it up haha
Smiler
Mar 14, 2016 21:09:19 GMT
You seem to have an extra bit?
Mar 14, 2016 22:18:28 GMT
You seem to have an extra bit? Haha the majority of it is "extra" as i only really wanted the back box
Mar 15, 2016 15:52:22 GMT
My hella grill arrived today! it's a bit battered and bruised but I'm happy with it! Can't wait to get it fitted!
Mar 15, 2016 21:31:00 GMT
Totally agree the gaz and avo coilovers are very expensive, but desperately want some!... I have got some german FK 60mm springs and it sits very low on the front! But in the process of trying to buy shorter dampers as my original ones keeps bottoming out and its recommended anything lower that 50mm, you will need shortened struts.
Cheers mate.
pOG
SHATNER'S BASSOON
Mar 15, 2016 22:04:56 GMT
I think this car is excellent. Keep up the good work.
Totally agree the gaz and avo coilovers are very expensive, but desperately want some!... I have got some german FK 60mm springs and it sits very low on the front! But in the process of trying to buy shorter dampers as my original ones keeps bottoming out and its recommended anything lower that 50mm, you will need shortened struts. Cheers mate. I've decided I'm going to get all my parts on, build the zetec engine and get it running sweet, then I'll tackle the lowering situation once my wheels and tyres are on. May i ask which shorter struts you'd suggest?
I think this car is excellent. Keep up the good work. Thanks mate! I really appreciate it!
ajc91
Mar 27, 2016 10:46:22 GMT
dbizzle shot this at Wheels Day: Why have I not seen this before?!
Mar 28, 2016 12:19:00 GMT
dbizzle shot this at Wheels Day: That's awesome!
