Jan 18, 2020 10:02:22 GMT
Might be worth disconnecting the lights on the run and adding them back in 1 at a time. If theres a fault occured on one it may be pulling down the circuit. If it trips on the first one I'd bypass it to check it isn't it that has a fault. Have you tried swapping the circuit to the mcb next to it that works, and see if that one trips? Tried that by wiring up one lamp directly to the board and it still trips. However, I am using two separate wires (not double insulated) on this test, would that make any difference? They are not touching each other.
jonomisfit
Club RR Member Number: 49
Jan 18, 2020 12:04:22 GMT
Is it worth trying the direct wire with a couple of different fittings, just in case the one used happens to have a fault?
cabling outer sheath is more about mechanical protection rather than electrical insulation. Unless the voltage is above domestic levels.
Last Edit: Jan 18, 2020 12:06:20 GMT by jonomisfit
Jan 18, 2020 12:24:02 GMT
OK, riddle me this :-)
Wire in MCB 3rd from left trips RCCB. Put wire in MCB 8th from left, which is on a different RCCB, and it works fine. Lights in workshop, storage and seating area are on MCB 4th from left and work fine.
At least I can carry on with the lighting but I have no idea what the issue is.
Jan 18, 2020 12:42:18 GMT
As johnthesparky said its important the neutral goes in the corresponding neutral bar so all the left hand MCB use the left hand neutral bar and all the right hand MCB use the right hand neutral bar, no neutrals in the very right hand neutral bar though
jonomisfit
Jan 18, 2020 13:01:07 GMT
As above. Very much sounds like the neutral is on the wrong half of the split if it pulls the RCD and swapping fixes.
Its important for rcds that current out = current in.
And also why it's a mare when someone nicks a neutral with a nail in plastered walls as they often cause sporadic RCD trips based on humidity and cause low level current bleeds. Not enough to pull a fuse /mcb but enough to unbalance an rcd.
Hope that's you sorted
Jan 18, 2020 14:49:29 GMT
Neutral bars, right, didn't know that. I will go and have a look now and report back.
Jan 18, 2020 18:23:30 GMT
Yipeee!, problem solved, neutral wire in wrong block. Another day, another lesson learned. Thanks guys.
Last Edit: Jan 18, 2020 18:23:55 GMT by nalesutol
johnthesparky
Club RR Member Number: 6
Jan 25, 2020 18:06:11 GMT
Sorry didn’t get back to this, glad it’s sorted
Next time the cover is off, if you look at the rails into the bottom of the MCBs you should see where the split is (I’d guess it’s 5 + 5, so the 5 from the right on the right RCD and 5 from left on left one) then need to keep the neutrals related to those breakers in the correct neutral bar
Jan 25, 2020 18:50:45 GMT
Sorry didn’t get back to this, glad it’s sorted Next time the cover is off, if you look at the rails into the bottom of the MCBs you should see where the split is (I’d guess it’s 5 + 5, so the 5 from the right on the right RCD and 5 from left on left one) then need to keep the neutrals related to those breakers in the correct neutral bar Cheers :-) That's one of the problems of being a cheapskate, I didn't fancy paying £40/hr for something as simple as wiring up the lighting circuits. At least I had RR to fall back on. Sometimes the interweb is actually useful, but now back to watching cats do daft things :-)
Jan 26, 2020 16:31:50 GMT
Everyone, well, most people, would love an extra 3"
Jan 26, 2020 18:57:17 GMT
Is that a new version of Jengo.....which stick do you pull out first??
Jan 26, 2020 19:12:32 GMT
Is that a new version of Jengo.....which stick do you pull out first?? :-) At least I feel safe working under the car.
Jan 27, 2020 11:11:42 GMT
Very true! But it does highlight those very nice....but wide/heavy front wheels/tyres, do you have some demon light narrow ones ready for your runs up the quarter mile?
Jan 27, 2020 11:42:50 GMT
Very true! But it does highlight those very nice....but wide/heavy front wheels/tyres, do you have some demon light narrow ones ready for your runs up the quarter mile? These wheels are from a Sierra Cosworth I stripped a few years ago and are only there to hold the car up. I have yet to finalise my wheel/tyre choice, but tyres will probably be 205/14 or 15 fronts and 285 or 335/15 rears. I will not be fitting stupid looking skinny fronts, unless I am running something.01 sec 1/4s :-) Also, I don't like spoked wheels on older cars, especially Elans, so they will be sold as soon as the proper wheels (they will be in a slot mag style) are purchased. Wolfrace slot mags were fitted in its previous incarnation.
Last Edit: Jan 27, 2020 12:03:29 GMT by nalesutol
Jan 27, 2020 12:28:34 GMT
I like slot mags as well....
Jan 27, 2020 17:20:51 GMT
I like slot mags as well.... I remember Muscle Sprout!, in its various incarnations :-)
Jan 27, 2020 18:36:35 GMT
Finally decided on paint! :-) I will be talking to paint supplier tomorrow to sort out details including quantities. The colour? Wait and see :-)
Jan 27, 2020 20:38:01 GMT
Finally decided on paint! :-) I will be talking to paint supplier tomorrow to sort out details including quantities. The colour? Wait and see :-) Carbon fibre paint infused with helium.
Finally decided on paint! :-) I will be talking to paint supplier tomorrow to sort out details including quantities. The colour? Wait and see :-) You tease ! 😊
slater
Club RR Member Number: 78
Jan 29, 2020 17:06:23 GMT
what no carbon wheels?
