logicaluk
Why did they use the black surround for the rear lights? Where they thinking of using a different larger rear light and need to cover up the design? It certainly is one of the Stratos' strange features The Strato's prototype (Very different to the original Bertone design study) I don't think neon coral pink ever looked so good on a car.
Last Edit: Jun 28, 2017 7:48:49 GMT by logicaluk
Darkspeed
Club RR Member Number: 39
Jun 29, 2017 17:05:33 GMT
Went for an OEM type detail on the bolts for the rear lamps Will have to look what I did on the front lamps.
Darkspeed
There has not been much in the way of posting due to the PB debacle - and not wanting to rush to do eveything with Flickr to find that falls on it's face in a few months. Many thanks to HoTWire for the interim efforts to sort out the PB issue. I have not been sitting on my hands at all - I have continued with the G21 chassis and I am today looking at the sump mods required to clear the windage tray on the V8 for the G27. Back in April had to decide - Welder or Wheels - Well W Won picking them up Tuesday not Weds... Woo Hoo now Back to Welding Windage.
Last Edit: Jul 8, 2017 14:34:59 GMT by Darkspeed
Darkspeed
Ginetta G27 4.5L Rover V8 rebuild works continued today First up I finished the windage tray drilling the straps to loose a little weight and improve the aesthetic. DSC01027 It was then onto the sump to make sure that there was clearance for the windage tray - its all pretty close. First off the front of the sump was made deeper. DSC01021 DSC01020 The centre of the sump was modified to clear the windage DSC01026 That will do nicely - just a coat of satin black paint required DSC01025
Darkspeed
Doing a dry test assemble of the G27 "power unit" this morning to do the final checks before the final assembly and sealing up until the car is ready for it. The engine is a little bit special for a Rover V8 - small journal cross bolted 4.5 (not 4.6) - First off it was fitting the ARP head studs. DSC01028Pistons have valve cutouts for the high lift 248M cam and the block faces have been decked for the pistions to be just proud of the block face. Pistons are Omega and the rods are spot peened - they have also all been matched for weight and balanced end to end. DSC01029 The rocker gear is also pretty rare being steel adjustable rockers that sit on 7/8" shafts (a limited number of these were manufactured for homologation purposes - the standard shafts are 3/4" with alloy non adjustable rockers. The rocker posts are also steel on this set up known as the Group A racing rockers. DSC01037 DSC01041 The adjustable rockers are a requirement when using the solid lifters that I will be using in this engine. DSC01038 DSC01039 DSC01040 Benefit with the solid lifters is that you can run more aggressive profiles and higher rpm - this engine is safe to 7500rpm which is nothing for modern engines but for this ancient tech it's pretty racy. Dressed with the rest of the induction parts and thats my view - the bonnet sits just above the oil filler caps DSC01033 I have found an issue doing this dry build that I need to resolve. We have fitted the wrong type of crossbolt here that is preventing the cover from sitting correctly that is preventing the bolts lining up. DSC01035 Pretty happy with that but lots of work to do.
That is pretty damn nice!
Darkspeed
That is pretty damn nice! I think I will have to import a pair of Offenhauser 215 cover for it though as I love the Rover when it has a bit more of a retro look - DJE did some nice covers for them at one stage as well but I have never seen a pair come up for sale and the Offy covers are similarly rare over here.
Plenty of rover to chevy adaptors floating around for rocker covers. Look up whengparts. Co.uk
Darkspeed
Jul 10, 2017 16:57:06 GMT
Plenty of rover to chevy adaptors floating around for rocker covers. Look up whengparts. Co.uk Would probably go that way if the cover I wanted was only a Ford or Chevy part but as they are avaialable for the Buick I will just keep an eye out or order from Summit etc. but it's way down the list of priorities at present - just a "would like to have" Couple of days off at the moment but no Strato's work to speak of as the weather is a bit damp. Things have been progressing with the G21, currently waiting on a delivery of material so I can progress with fabricating the front wishbones. G21 jobs ticked off the list - Torque reaction arm for the MX5 diff complete with chassis mount - drilled mounts for subframe - Steering rack mounts - Sprayed everything in cold galv - Calculated the coilover requirements. Once it's a rolling chassis work on this project can slow considerably and maybe we can get one of the others rolling. A counterbore has been ordered so that I can sink the bolt that's in the way on the V8 a bit further into the block to miss the front cover. Busy day ahead tomorrow.
jamesd1972
Club RR Member Number: 40
Jul 10, 2017 20:12:42 GMT
Ah proper job, I suspect I wouldn't be alone in reaching for the grinder.... Thanks for the updates, am just about managing to work out which car is having what done to it ! James
Darkspeed
Jul 10, 2017 21:37:00 GMT
Ah proper job, I suspect I wouldn't be alone in reaching for the grinder.... Thanks for the updates, am just about managing to work out which car is having what done to it ! James - well I may well be taking the grinder to the counterbore - does that count When the thread was started I had not anticipated so many diversions but it happens. Best way to look at it is that every car is having almost everything done to it as they are all ground up nut and bolt strip and rebuilds.
Darkspeed
Tuesday I picked up the new tools DSC01049 "Big Blue" is going into retirement after years of sterling service and will go off to a mate of mine. The replacement is "Lil' Yella" ! DSC01051 A quick test following the instructions on the box - Good enough DSC01054 In the other box is "Lil Yella's" more complicated sibling a 200Amp AC/DC TIG - DSC01052 This type of welding is a bit new so I have loads of youtube vids to watch and bits of scrap to cut and clean and by all accounts loads of Tungstens to sharpen and resharpen. Back to school with this kit.
Considering your results so far, I'm sure you'll work it out in short order.
eurogranada
Nice stuff!
Great thread!
Darkspeed
Jul 13, 2017 15:20:56 GMT
First quick blasts on alloy without the pedal in "Easy AC" mode. As the alloy heats up you need get a move as the weld pool starts moving pretty quickly (Bit daft starting out with quite thin material) Figured I would try and weld with just basic settings before using the pedal and all the clever pulse and frequency and special button touch torch modes. As I now have Puresheild as well as Argosheild I am going to order up an alloy welding kit of liner and wire as I have two torches for "Lil Yella" on is a short 2.5m I figured it worth a try.
duncanmartin
Out of retro ownership
Club RR Member Number: 70
Jul 13, 2017 19:10:05 GMT
In the other box is "Lil Yella's" more complicated sibling a 200Amp AC/DC TIG - DSC01052 I have welder envy. I'm sure you'll be laying perfect beads in no time at all... Cheers Duncan
Darkspeed
Jul 13, 2017 20:08:12 GMT
Because I find MIG relatively easy to use to produce some good results I am feeling that I am progressing better with welding Aluminium with the TIG than I am Steel, which is supposed to be easy. I suspect however that I am as poor with both but far more pleased when I manage to get 3 Alloy beads out of 50 looking half decent ! I fired up the foot pedal for a play today and that makes things so much more controlable. The concern now is the rate at which I am getting through a £50 bottle of gas!
Long old road to go with this and I suspect that those fuel tanks will be a way off. Maybe start another thread with input from other MIG TIG users.
Jul 14, 2017 11:22:39 GMT
2 / 2.5 / 3mm alloy will be "a doddle" though? or does it not correlate to steel that way either ?
kcchan
Jul 14, 2017 12:24:32 GMT
Ali conducts heat a lot quicker than steel does so I think the foot pedal would be key especially if you're doing long runs; the whole work piece is hot so you can back off the amps.
I'm only a hobbyist welder too with AC TIG in my arsenal but I'm no pro that's for sure.
I've only started following this thread and its great. Good fabrication skills.
Darkspeed
Jul 14, 2017 17:12:53 GMT
2 / 2.5 / 3mm alloy will be "a doddle" though? or does it not correlate to steel that way either ? I will let you know when I find out - what I can say is that laying beads on a piece of 3mm Alloy that is cleaned and wiped and prep'd as advised in all the tutorials is much "easier" than butt welding two bits of scrap 1.0mm alloy just cut with snips and no prep'. Will be doing a fair bit of practice over the weekend. As well as work on the Lathe to produce some bushes and giving the new tube beader a few jobs to do as well.
