mospin
got a vw passat estate for breaking ive been using it for a few months but now time for change as it has to many things falling off .
its in green 2.0ltr petrol estate engine has 164,000miles and still strong.
its a 1996 n reg
engine is the AGG model will take 150 has fsh too gear box is CRU new clutch 5 months ago £20 pas pipes and bottle £35 manifold £10 coolant hoses £10 maf £20 rad £30 a/c stuff full lot £100 will split speedo cluster £25 carpet £30
loads off stuff still here not listed just ask
Last Edit: Jan 18, 2016 13:47:11 GMT by mospin
mospin
b4
Yes i want it ilive in South africa wots yor price in rands for the car
Jan 14, 2016 12:31:51 GMT
Can you confirm what engine code it is please?, I need some breather pipes from the front of the engine and if it's an AGG, I'm after wiring loom between the ECU and the engine
The lurker formerly known as Cappuccinocruiser.. or wedgedout..
mospin
Jan 14, 2016 22:51:38 GMT
it is the agg model if you on about the breather pipe that plumbs in the front centre under the spark plugs just left off the dizzy the thats been repaired with a replacement metal connector as it was all broken .
Jan 15, 2016 10:38:30 GMT
Yeah that was the one. I'll plum for the replacement items new then The engine to ECU wiring?, and if possible the engine ancillary loom?, and perhaps the ECU, Immo, transponder and ring?, depending what you'd want for the lot? I'm doing a conversion into a vw T3
mospin
Jan 15, 2016 17:41:20 GMT
Unfortunately I couldn't find a replacement pipe for it and mine was split on the hose were it connects in the slot and theres a split pin that holds a slot washer that was also damaged so what I did was cut the hose where the split was then use a metal connection pipe off a s14a breather pipe pushed it in the pipe and the other end had a new o ring in the housing then the clip that holds it all together better than I expected lol.
send me a pm exactly what your after and we can go from there
Jan 16, 2016 21:39:57 GMT
Hi, can you tell me what the G/box code is please
mospin
Jan 16, 2016 22:34:51 GMT
where will I find the code .? btw it had a new clutch last year
mospin
Jan 17, 2016 13:53:15 GMT
upside down but thats the info stamp for the car transmission code is on there
Jan 18, 2016 12:50:30 GMT
CRU gearbox code looking at that sticker. 4.2 Final Drive
mospin
Jan 18, 2016 13:32:55 GMT
okay guessing thats what your after ?
Jan 18, 2016 14:04:21 GMT
Not me, but they're a nice gearbox for the MK3 16v boys, the final drive is sought after
mospin
Jan 18, 2016 14:07:49 GMT
okay any idea what its worth? take it that's a rare ish box
Jan 18, 2016 14:36:02 GMT
Last one I had I sold for £150.00 to a friend, who'd been quoted £200 from specialist VW breakers, however that was about 4 years ago.
My local breaker, when he's got them in, charges £80 a box, but you need to pull it yourself. I like him, his prices are still in the early 1990's
mospin
Jan 18, 2016 14:44:31 GMT
crikey thats a big jump in price . if theres any interest in the box il see what I get offered but no interest as yet but thanks for the info may stick it up on gumtree too.
mospin
Jan 20, 2016 16:22:07 GMT
bumps all parts being removed Saturday if anyone wants the shell thats £60 rolling could make a idea sleeper turbo?
Jan 25, 2016 11:36:44 GMT
How did you get on removing the parts we discussed mate?
mospin
Jan 25, 2016 12:13:44 GMT
sent you a pm . been a bit hectic lately
