From memory the bikes in Mad Max were picked up in Sydney then riden by the actors down to the Melbourne area for filming camping along the way, apparently they had a letter from the producer to carry explaining they were actors not a real gang for when they got stopped... Good work, I remember seeing a GT550 with a chair on it round Sheffield The "get out of jail free card" as Jim the goose says to the couple in the bubble top trike in the film, it's a nod to that. Loving this mate, really am. It's one of my goals to build something similar one day and live out my toe utter fantasy lol
I got one of these out of the back of someones garage many years ago... No idea how long it had been off the road but it was happy to spring back to life with just fresh fuel and a borrowed battery. From memory, it never got more than new plugs and a basic service and ran fine for the couple of years I used it. Top marks for the changes, I tried something similar with a GS400 and was well happy with the result. Keep up the good work!
dubscum
thats what i do
although the paint was good on the side panels, i 've painted them black to match the airbox behind the carb, I want to the seat unit and tank to be the same colour but different from the rest of the bike. Make the seat and tank stand out, cafe racer style. spray booth. sprayed the front indicators too. give you an idea. need to tweak the seat to sit level with the tank can you guess what it is yet ? my most lavish purchase for the gt. Hagon Z1000 rear shocks. 1, they look like the mad max bike, GT air shock were very worn, but mostly because there longer which will lift the rear, give the bike a better stance, clear the light from the rear tyre, down side the fittings are smaller, FFS. think i'll end up cutting them off and welding some thinner thread on total £580
Last Edit: Jan 6, 2016 20:16:45 GMT by dubscum
whip it, into shape ........ go forward
mylittletony
Club RR Member Number: 84
Looking good, really like the mad max bikes. You might be able to swap the bushes and sleeves over between your shocks.
dubscum
thats what i do
That's a much better idea. Thanks, my GT shocks are spent but I'm sure I could get some new ones and swap them. Cheers!
dubscum
thats what i do
Sept 17, 2016 19:27:07 GMT
well after not touching it for 8 months ......
dubscum
thats what i do
Sept 17, 2016 19:52:55 GMT
Swapped the bushes in the shocks which lifted the rear by and ince and lowered the front by an ince on the forks. Then welded some bits in the fit the seat and cowling Did it a bit of a faf but wanted to still get the battery out and get to the other bits
dubscum
thats what i do
Sept 17, 2016 19:59:11 GMT
Then I needed to make a seat base. Glued it all together clapped it and hammered it with the sander Cut the original seat foam down and glued to on, that way I can use the original seat vinyl and it will hide me rubbishness
dubscum
thats what i do
Sept 17, 2016 20:05:54 GMT
Made a bracket for the rear light of of some angle iron shelfing. Welding it on and primed it. I know the bars is not level. Do'h. Garage built and eyeing it in
dubscum
thats what i do
Sept 17, 2016 20:14:17 GMT
Then I cut the old loom and added some connectors for the lights Ordered a new indicator relay Then picked out a live and neutral out the og wires going to the clocks to light up the new speedo when I turn the lights on The tank and seat unit and tank have gone off for paint
dubscum
thats what i do
Sept 17, 2016 20:22:19 GMT
I thought one of the calipers were toast, but it turns of one the brake pipes it's well blocked. Ordered another one ..... The bike eBay built Then me mate came round in his buggy so we went to the pub
dubscum
thats what i do
Sept 20, 2016 17:08:47 GMT
Plod's gonna love this
dubscum
thats what i do
Oct 19, 2016 19:27:50 GMT
My mate is building a z650. And he's kindly donated the indicators. So I haven't e matching fri t and back. The rear lenses are very dull, and the fronts need shortening. During quiet time, we have been spraying bits up Filler cap I love it.
Can't wait to see this done. When there in the cafe and get the call for the Knightrider in Mad Max there is a green truck that sets off when the Goose does. I see this painted similar
dubscum
thats what i do
Quality I feel like I cut my motoring teeth on 80's films. Mad max being one of my favourites. Been busy with the rattle can Frame Mug guard holder (having the mud guard sprayed but might leave it off) The light looks so much better satin black (rather then chrome) Exhaust cut and welded. Sprayed wood burner black Ready for wrapping and fitting Need to cut weld and spray the front indicators stalks. Tidy wiring next
Sinky
Run Baby Run......Please!
Great work mate.
2001 Volvo XC70 wagon
2003 Piaggio X9 Evo
dubscum
thats what i do
Oct 21, 2016 20:26:14 GMT
dubscum
thats what i do
Oct 22, 2016 16:04:47 GMT
Covered the wooden seat base I made, with the original foam and seat cover. Cut it down glued and stapled it It's a little loose but think it will be one when fitted
Oct 23, 2016 10:24:58 GMT
Yo dubscum , looked at the piccies I have thought of a little project it can add to your toolkit , and is relevant to this , it requires a pair of pliers the big ones not diamalloyds and a file easily acquired from the stores ,narf narf
dubscum
thats what i do
Oct 23, 2016 17:22:08 GMT
