foldy
Dec 15, 2015 20:04:17 GMT
this is an option for sure... tho atm funds and facili``1``•#$#31$46$'#2''ties wont allow it, perhaps a new year thought! currently oscillating betw1@#$#een a 40 or 60mm drop atm, may depend on which bit of decent ki11t appears first !? Definately think about spending a little more on a set of FK coilovers. Well worth the extra dosh. If you look at my corsa (decent pics in the for sale thread), That's as low as they go (before the helper springs catch on the front tyres anyway), take them out and it'll drop more and I'm pretty sure you could remove the adjustable rear platform off to lower the rear a tad more.
Dec 15, 2015 22:25:52 GMT
Turn the pump screw 1/4 turn in ,fit a boost gauge and a bleed valve..
redirect the air filter if you have the stacked inlet and don't bother with a front mount the gains arn't worth it if you still want more run water meth.....
60mm drop and a set of 15" steels sorted........
OH and if fitted with the standard f13 box I doubt you'll see 100mph...
If you serous about tuning I'll guide you through it I'm running a three door 15 isuzu and she's a snorter!!!
Last Edit: Dec 15, 2015 22:46:46 GMT by usedabused
Dec 15, 2015 23:42:00 GMT
this is an option for sure... tho atm funds and facili``1``•#$#31$46$'#2''ties wont allow it, perhaps a new year thought! currently oscillating betw1@#$#een a 40 or 60mm drop atm, may depend on which bit of decent ki11t appears first !? Definately think about spending a little more on a set of FK coilovers. Well worth the extra dosh. If you look at my corsa (decent pics in the for sale thread), That's as low as they go (before the helper springs catch on the front tyres anyway), take them out and it'll drop more and I'm pretty sure you could remove the adjustable rear platform off to lower the rear a tad more.they sound like the ideal business :-) they do look the right kit for sure, think its save for new and hunt for second hand time! that looks pretty decent mate, and tbh i wouldnt wanna go any lower than that. I'm guessing thats a 60mm drop? i had a battered track corsa on coilovers in the past.... it was scrapped with the coilovers still on!
Dec 15, 2015 23:46:41 GMT
Turn the pump screw 1/4 turn in ,fit a boost gauge and a bleed valve.. redirect the air filter if you have the stacked inlet and don't bother with a front mount the gains arn't worth it if you still want more run water meth..... 60mm drop and a set of 15" steels sorted........ OH and if fitted with the standard f13 box I doubt you'll see 100mph... If you serous about tuning I'll guide you through it I'm running a three door 15 isuzu and she's a snorter!!! that mate sounds up my street, i wanna get the max out of the existing motor (ideally without knackerin it! :-P) 60mm i think is the drop I'm looking at tbh, tho i rather like the tigra alloys! will be doing the motor in the new year mate and for sure guide would be majorly appreciated! haha sweet, your motor got a thread on here? hehe it was an indicated speed... tho they were officially good for 103mph when new (aparently)!
foldy
Dec 16, 2015 14:50:28 GMT
!? Definately think about spending a little more on a set of FK coilovers. Well worth the extra dosh. If you look at my corsa (decent pics in the for sale thread), That's as low as they go (before the helper springs catch on the front tyres anyway), take them out and it'll drop more and I'm pretty sure you could remove the adjustable rear platform off to lower the rear a tad more.they sound like the ideal business :-) they do look the right kit for sure, think its save for new and hunt for second hand time! that looks pretty decent mate, and tbh i wouldnt wanna go any lower than that. I'm guessing thats a 60mm drop? i had a battered track corsa on coilovers in the past.... it was scrapped with the coilovers still on! It probably works out to be more like -100 mm, it'll drop yours further (this goes for any kit you buy) being a 'normal' model they start off higher.
Dec 16, 2015 17:33:01 GMT
No build thread I give up on them as I start them and forget to update ,
I'll get some photo's for ya...
Dec 16, 2015 21:46:06 GMT
they do look the right kit for sure, think its save for new and hunt for second hand time! that looks pretty decent mate, and tbh i wouldnt wanna go any lower than that. I'm guessing thats a 60mm drop? i had a battered track corsa on coilovers in the past.... it was scrapped with the coilovers still on! It probably works out to be more like -100 mm, it'll drop yours further (this goes for any kit you buy) being a 'normal' model they start off higher. oh right, thats handy to know! keeping eyes peeled on kits atm! got a young kid so up at night with him, and web surfin... dangerous business!
Dec 16, 2015 21:54:23 GMT
No build thread I give up on them as I start them and forget to update , I'll get some photo's for ya... haha fair enough, tbf thats what i'd be like.. tho the corsa had it weldathon b4 i joined the forum! yeah man, post em up!
wodge
Dec 16, 2015 23:49:48 GMT
I got pulled for an alleged 103 in a standard non intercooled y17dt corsa c - 63 Bhp in a heavier car. So I would have thought a b with the 1.5 would hit a ton easy.
Awesome engines these Isuzu lumps I had a bet with a mate as to how long it would last with nothing done to it at all. 4 years and 110k miles later - same oil, filter, fuel filter and everything else the body has given up to tin worm before the motor.
Dec 17, 2015 19:05:59 GMT
Its the gear ratio that determines top speed not the engine,
The f13 box runs out of puff at around 90 plus mph... a 17td may not of had the f13 box....
Anyway its not about top speed its everything in-between that counts........
wodge
Dec 17, 2015 21:41:32 GMT
Tbh I think it probably did have the f13 box it was redlined in top at an indicated 105 but it was on 15" Astra sport steels and balloony 195/50 tyres so probably had 5% taller gearing than stock.
the gearing does hold it for sure top end, i got indicated 97 then 100 on two runs tho totally agree its the grunt in the middle that its about, i think the 1.5 (for its size) can shift surprisingly through lower speeds, if you squeeze it hard enough
Dec 18, 2015 12:04:45 GMT
to be pedantic its fluid drag that limits top speed, not car weight or gearbox. of course if you are hitting the governor before you reach the aero limited top speed, longer gearing would increase it slightly.
soooo, to get the old girl a bit lower have picked up a set of these 40mm drop, and as coilovers are out of budget these seemed alright at £25!
Last Edit: Jan 3, 2016 17:52:54 GMT by s1105117
Mar 30, 2016 22:23:48 GMT
well the travellers tried to nick her.... one door ruined, but the ancient immobiliser appears to have scared them off. they never checked the boot fortunately, had a decent tool bag and trolley jack in there and I live in a "good" neighbourhood alas now not sure what the plan for my faithful old hack is now... i think the sills need a patch or two with the MOT in a few weeks.... and I cant weld
Mar 30, 2016 23:01:24 GMT
Good time to talk to your insurers I would have thought, little claim to smooth the passing of your MOT no?
foldy
Shame some scumbags tried to steal it, makes your blood boil. Does the door still open and close as it should?
Last Edit: Apr 2, 2016 8:33:41 GMT by foldy
