duncanmartin
Out of retro ownership
Club RR Member Number: 70
Nov 28, 2015 22:54:40 GMT
Hi Goldnrust That is a seriously cool bike - glad you posted a thread on it. I always loved the grey 400s, but I never got brave enough to actually learn to ride a motorbike. Probably too late these days - my wife would kill me and I have too many projects and toys I never use anyway! Keep up the updates! Cheers Duncan
Its never to late, when I did mine last year there was a guy doing his test who was 67 it was a present to him self for retiring.
Bought himself a lovely Triumph.
I love these Honda 400s, RCs and CBRs, always fancied one. In my youth I was a 2 stroke fiend, specifically TZR reverse cylinders, such a cool bike. Being 6ft 5 it was a bit of a squeeze but I was 18 and about 10 stone lol. Fast forward 23 years and Id never fit on one ever again!
goldnrust
West Midlands
Minimalist
duncanmartin do it! Bikes are awesome! Admittedly December isn't a great time to learn.... but if nothing else, if you can hack winter riding, then it only gets more fun as the weather improves! swampy442 those 250 2 strokes are really pretty small bikes aren't they! I had an RGV250 VJ21, which I really enjoyed riding, ended up selling my 748 because I would always choose to take the little 250 out instead! Those reverse cylinder TRZs are seriously cool, rather like hens teeth to find nowadays though, wth a price to match My CBR is noticeably roomier to ride than my RGV was, but yeah still wouldn't be very roomy for someone 6ft5! I'm only 5ft7 so it being on the small side isn't an issue for me! So yeah, I should have done an update ages ago really, I'm out of practice with this build thread lark, haha. First up, starting where we left off the last post, having checked that all appeared well in the engine, it was time to put in back in the bike. With the help of a friend, it was light work and it was soon safely back in place. Cause for a small celebration! The new carb rubbers arrived, though they appear to be slightly shorter than the once coming off the bike. They fit nicely on the carbs and on the intake manifold though, so I'm hoping it wont be a problem. It did cross my mind that the ones on the bike might not be original, as the little locating points to stop the clips spinning while you try and do them up, didn't line up with the clips. I guess it's equally likely that the clips could be non original also. As it happens, the carbs and airbox seemed to fit just fine, so original or not, the new carb rubbers are a success Also arriving in the post were a set of shiny new NGK spark plugs in Honda's recommended 8 heat range, rather than the 9s I found in the bike, and some silicone hose and hose caps. As the vacuum ports for balancing the carbs are so hideously awkward to get to on these engines, while the carbs were off I ran a short length of vacuum hose to each port and then labeled the hoses, capped then and grouped them together. This means I've now got a really easy way to get a vacuum reading for each port, making balancing the carbs a doddle. I appreciate it probably doesn't need doing very often, but it's only a little mod and when that time comes it just makes life so much easier! Before I could get on a start the bike up there was the matter of the plug leads. Having spoken to David Silvers, who politely informed me that yes they could get me some NC29 plug leads for £40.... per plug lead Eeek! I decided to buy a cheap second hand coil pack off eBay for £25 and nick the plug caps off it. This way I also get some spare coils I used my original coil packs as they seemed in visually better condition and my plug leads too as they appear to be some fancy aftermarket silicone ones. Getting the bike to start turned into a bit of a game. Firstly I presumed that the fuel pump would prime the carbs while the key was in the start position, so I decided the easiest thing was to just turn the key and keep cranking it till it got fuel and fired up... but it didn't. It took me a minute to realise that it wasn't pumping fuel while I was cranking it over. So I did a bit of online research, got worried about failed points in the pump ,or damaged fuel pump relays etc, before finding a wiring diagram and directly feeding 12v to the pump... it primed the carbs in a matter of seconds. So turns out the fuel pump doesn't prime while cranking, mental note to self for the future there! So now we had plenty of fuel but not a hint of starting. More head scratching and then it dawned on me.... a couple of weeks earlier, my friend who helped me fit the engine and turned off the kill switch and said 'I wonder if you'll remember this when coming to start the bike, hahaha'. Guess what.... One sarcastic text message later and a flick of the kill switch, turn the key and she fired into life beautifully. Woo! Next up, balancing the carbs. With a quick extended fuel line whipped up, I could run the bike with the tank off for as long as I needed. Balancing the carbs was nice and easy, not just because of my easy access vacuum ports but also just that these carbs seemed to come easily and more consistently into balance than any others I've done before This is probably a good sign that they're not too worn and hopefully will stay in balance better than on other bikes/cars I've had. Some work to do there you'll see! I'm fairly sure there had been some air leaks previously, or that I disturbed something when removing the carbs as the bike seemed more out of balance now than it had before I took it all apart. Either way it's all sorted now and nice and smooth With that sorted it was time to get out and do some riding! Shame the weathers not really on our side at the moment, the roads are pretty dirty, still it wasn't raining and it was really nice just to get out and do some miles on the old girl. To celebrate heres some quick post ride pictures from this morning
Last Edit: Feb 27, 2018 22:19:19 GMT by goldnrust
Brilliant thread.
I've alot of love for JDM 400's, I've owned a few, I loved my NC21 and variable valve Bandit 400.
duncanmartin
It's not happening. My wife would kill me (and the only reason why I'm allowed my 924 is so I don't think about motorbikes)! Besides, I'm in the middle of building a recumbent tricycle (and working out gear ratios - it'll hopefully be capable of 30mph on the flat if the engine can produce enough Watts !). Your CBR is super cool though - glad you've got it running properly, and I love the little mod that allows you to balance the carbs. Simple mods that allow you to maintain it properly are really neat. Cheers Duncan
Clement
ambitious but rubbish
Awesome bike you have there! And lovely 166, too.
I recently switched to a small 125cc and it's true that it tends to make every journey stupidly enjoyable, I can't imagine what a nimble 400cc would be like.
Oh and beautiful pictures, thanks for sharing them!
goldnrust
West Midlands
Minimalist
Cheers guys shhhh Clement, we can't talk about how awesome the 3.0 busso v6 is, or how much I love my 166, or how it's made me enjoy driving again in a way I haven't since I sold my Lancia.... because it's too new for retrorides. 125s can be plenty of fun, but yeah it's nice to have some more power for the higher speed stuff. Power is far from everything on a bike, in my opinion, thats why most of my bikes have been between 40-60hp, that's plenty to have fun with, and to get up to go speeds without much effort, but equally it's little enough power than you can enjoy working the bike relatively hard on public roads without needing to do horrendous speeds.
Last Edit: Dec 6, 2015 13:27:23 GMT by goldnrust
Clement
Then I won't say I'm intrigued by 166s because they look cumbersome but seem to be a good steer! 125cc's are plenty enough for city shenanigans, especially since mine is very light, but I do miss some power on the open road. Lots of tuning options available mind you, not that I'm considering building a spare engine on the cheap I don't think we got any grey imports in France for the CBR400 era, it's a shame. France is boring for petrolheads.
goldnrust
West Midlands
Minimalist
Were none of the early 90s 400/250s imported officially to France? The CBR400 was never officially brought to the UK but my VFR400 was a proper UK bike, as was my RGV250. We can probably talk 166s if we talk quietly and no-one notices.... They started production before 200, even if mine is an 2002, shhhhh! 166s are very thin on the ground here in the UK, it took me 6 weeks to find one with the engine/gearbox combo I wanted that hadn't just been run into the ground. I think they suffer from being cheap to buy, but not cheap to run.... When this one turned up, I jumped on it, and once the DVLA had dealt with removing the private plate, a friend and I did the 400 mile run trip to collect it from the east coast. Despite being a big old car, it hides it's size well, I think because it's lines are quite elegant, it doesn't feel 'chunky' or blobby. It's only really when I go to park it in a carpark that i remember just how long it actually is! The handling and driving feel is very definitely Alfa, it has a certain quality that my 147, 155 and GTV all had, it's hard to put a finger on exactly what it is, but it's just something about the way the controls feel and the driving position. Yet at the same time it's definitely more a luxury cruiser than the other Alfas I've had which have always had a nod to sporty-ness. The miles just fly by, the 200 min drive home seemed effortless. She handles well for a car of her size, but again due to the size and nature of the car it's more about it being enjoyable to drive briskly at sortta 3/4 speed on a nice wide A road, rather than really thrashing it. If you really push on hard, the limits of 220hp through the front tyres of a 1500kg car star to show up! As does the relatively soft suspension, thought I'd say it's not as softly sprung as many big cars like this. I wanted the auto, because I think for a car of this size, especially with a nice big capacity petrol engine, it suits the style, effortless power! This is the first auto I've owned, though I've driven a few on hire. A few years ago I would have probably been quite rude to anyone who said they wanted an auto, haha, but I'm really liking it. I haven't missed having a manual at all, and the tip-tronic type sports mode on the box still means I can feel like I'm 'driving' if I want to be. Overall it just adds to how relaxing a car it is to drive. If this was a small light car, and I wanted to go out and drive it hard I'm sure I'd want a manual, but for this big cruiser I feel auto is definitely the right choice. What it does have is a 'special' feeling, that unexplainable something about it that make's every journey, even just a pop to the corner shop, feel like an occasion. The Lancia was the same, and to a lesser extent my Rx7, all for different reasons but it's still that same sensation of just making the most mundane driving interesting. On the downside, the electrics are very Italian. Theres a lot of wires in there, and lots of opportunity for the 13 year old connectors to have got damp at some stage and corroded causing lovely intermittent faults. I've so far fixed the seat memory controls and the remote central locking just by cleaning the fluff out of switches and getting a bit of electrical contact cleaner on the connectors. Oh and the fuel economy.... it's on a par/slightly worse than my rotaries. Commuting through central Birmingham the other day the trip read 13 mpg. :/ Meh, I just try not to look at the trip and just fill it when it says empty! haha.
Last Edit: Feb 27, 2018 22:20:48 GMT by goldnrust
Clement
That colour combination is to die for I've always thought it looked smart and understated, I see what you mean with it more being about nice flowing roads. Isn't it horrible to try to explain to people that fuel consumption is only an issue if you care about it? That said, my MSX gets about 110mpg... Not bad, not bad. I've looked on leboncoin and I can only find two CBR400RRs! One with British papers, the other one Dutch. Proper rare stuff here.
adam73bgt
Club RR Member Number: 58
I've been lurking here, but awesome bike Also nice 166
goldnrust
West Midlands
Minimalist
Clement Cheers man, yeah I was really pleased to get a nice colour combo. Again I never thought I'd never be someone who liked cream leather, but it just works great as a two tone with the black 110 MPG! Those were the days! I used to get similar out of my Honda 125 also, was lovely brimming the tank on less than £10 and doing nearly 200 miles! haha. To be fair the CBR400 does ~60mpg so thats not bad either! Cheers adam73bgt As loudandproud205 said to duncanmartin further up the thread, it's never too late to get out on two wheels Also once you've got the bikes and the gear, which admittedly isn't super cheap, then the running costs are pretty low. One of the reasons I've now got the 166 and plan to have some bikes projects is that I reckon I can tax, insure, store and work on 3 bikes for the same cost and space that my mx5 took up.
That colour combination is to die for I've always thought it looked smart and understated, I see what you mean with it more being about nice flowing roads. Isn't it horrible to try to explain to people that fuel consumption is only an issue if you care about it? That said, my MSX gets about 110mpg... Not bad, not bad. I've looked on leboncoin and I can only find two CBR400RRs! One with British papers, the other one Dutch. Proper rare stuff here. You've got a Grom? no fair. Honda Australia didn't deem them viable, so there's a company importing them instead. Too bad the price they're asking is getting into 500cc territory.
muffy
goldnrust
West Midlands
Minimalist
That's interesting muffy, what bike have the coil on plug set-up to get the coil packs from? My worry would be that the plugs in the 400 would be a different depth into the head than the 600 or 1000s, especially as the 400s use a different cam arrangement (with the gear driven cams)
jonw
Can open a Mouse with a File
One of the reasons I've now got the 166 and plan to have some bikes projects is that I reckon I can tax, insure, store and work on 3 bikes for the same cost and space that my mx5 took up. I thought that! One motorbike is cheaper and takes up less space.... with with the extra space and money you can have another motorbike.... and another.... Why is this costing me more than the car and the garage is full? Great 400 and thread. Got to ride one a few years back and brilliant fun. Thought about one a few times, but no money, space etc.... Jon. (5 motorbikes)
Suzuki SV650R The good Triumph T20 The Bad BMW G650GS The Ugly Matchless G12CSR The Smokey Toyota Hybrid One pint or Two?
Ingredients of this post Spam Drunken Rambling of author Bad spelling Drunken ramblings of inner voices Occasional pointless comments Vile beef trimming they won't even use in stock cubes
muffy
That's interesting muffy, what bike have the coil on plug set-up to get the coil packs from? My worry would be that the plugs in the 400 would be a different depth into the head than the 600 or 1000s, especially as the 400s use a different cam arrangement (with the gear driven cams) I have a set off a 2012 fireblade. The depths of the spark plug tubes are generally similar. Not a bad thing if they stick out the top a bit more. Ben
goldnrust
West Midlands
Minimalist
Jan 24, 2016 23:30:18 GMT
Well the little CBR has continued to behave itself, and the few times I've managed to get out and enjoy it over the past month have all been worth getting cld and wet for. The poor thing is now definitely in need of a wash... ... but I've not got round to that, as I've been distracted. What do we have here?! It's a 1972 Suzuki T500, freshly imported from Minnesota and purchased via everyone favourite auction site from a pleasant bloke in Warwickshire. It's going to need quite of lot of work before it's ready to see a road again, and I'm really looking forward to getting stick into a good project again. For those not up on their 70's Japanese motorcycles... Suzuki's T500 was one of the first successful large capacity 2 strokes. It's 500cc parallel twin puts out 47hp @7000 rpm, so far from a screaming race engine, but a good reliable runner. Launched in the late 60s, it was considered quite a sporting bike, but by the end of it's production run in '75 the market had moved on, the T500 was old technology. The T500s brakes and suspension were now outclassed by all the competition and Suzuki themselves down tuned the bike to make their new GT550 seem more the sporting model. Now, as a classic bike the fact that they were a little old fashioned is of little importance. From what I can gather they are relatively well thought of in classic racing circles due to the rugged reliable nature of the engine, which is easily tuned, and the links to the TR500 and TR750 race bikes. I have been on the look out for a while now for a bike project, I wanted something older. The oldest bike I've ridden was my 1989 RGV250, and I wanted a new experience. I also wanted something to get stuck into, I wanted to do a certain amount of restoration, but also have room to do some modifications and make it my own by pulling in a few aspects of different bike cultures (all very retro-rides as a concept I think!) I had been looking at Suzuki GT250s, and Honda CB350s. The draw of 2 strokes was winning though, and spotting this going for sensible money I got slightly swept up on a wave of excitement about a 500cc 2 stroke.... The plan is to end up with a bike that's fun to ride, taking on certain elements of the popular cafe racer / flat tracker styles, mixed with a few slightly more modern touches and my own particular spin on things. I want the bike to work well 2 up, to be the sort of bike that I can go out for an afternoon adventure with my wife and just enjoy riding about on. Equally, as the largest and potentially most powerful 2 stroke I've owned, I'd like the engine to wake up when I work it, come on the pipe hard and scare me slightly, haha. I only picked the bike up yesterday, so Ive not done much so far beside sit on it and make 'brummm' noises, and begin the process of stripping the bike down and assessing what's good and what's bad about the bike. On the whole I'm pleasantly surprised with the condition. The wheels are in especially good condition considering the bikes age. The frame seems solid, the engine kicks over freely with atlas some compression, the inside of the tank is reasonable, etc. There are a number of missing parts, but mostly only the sort of parts that will end up being taken of and changed by me anyway! On the downside, the electrical system is looking very dodgy, but I plan to upgrade to electronic ignition, so that was going to get a serious overhaul anyway. The handle bars are quite bent... .. but those big high rise american looking bars wouldn't have been my taste anyway, I think I'll end up with something a bit lower rise. I've got the Rentals from my old GasGas in the back of the garage somewhere, must try them out! I think every consumable part, every rubber part, all the cables, etc will need replacing really. So it's going to be a sizeable project, not something that'll get done next week or anything. But I'm looking forward to working my way through it all and then hopefully sometime in the summer, maybe in time for the gathering, getting out and riding it!
Last Edit: Feb 27, 2018 22:35:34 GMT by goldnrust
Jan 24, 2016 23:50:53 GMT
Not a bike guy really but I enjoy your threads, so I'm going to bookmark this and look forward to the transformation!
