Oct 13, 2015 23:20:07 GMT
Hi, For the last couple of months, my laptop has been hanging for minutes at a time when using RR forum. spec : Laptop running Windows7 (2009), browser Maxton. T'internet access is with 3G "pebble" - no fancy broadband or dialup here No recent hardware of software changes (automatic updates are disabled) The same setup has been working fine since I got it about 5 years ago until the problems started about 3 months ago. The problem is limited to this forum (the other sites I use - forums, newsgroups, etc - all work without hanging) Has anyone else noticed problems, or is it just me Thanks
Oct 15, 2015 16:22:55 GMT
I've not had this personally. I've not changed anything really on the forum for a while, in fact I've removed things that could be slowing it down if anything. I do have a similar problem with adverts on Skype on my own laptop, where occasionally and advert will load and cause my laptop to hang, it is rather annoying. I suspect it is an advert being trafficed into the site, which I don't actually have any control over, although I'm tempted to take over control of ads so I can control a bit better the stuff that gets loaded along side the forum.
Oct 15, 2015 22:02:23 GMT
Makes sense ~ thanks. Odd that it only affects this site for me, most of the forums I look at also have adverts on them. I guess I notice it more as my 3g is painfully slow at the best of times Cheers
sowen
Club RR Member Number: 24
Oct 16, 2015 20:27:26 GMT
I get something similar, using chrome on windows XP and also a painfully slow 3 dongle connection. I have to have this forum tab on top for it to load slowly, most other sites will load when the tabs are hidden.
Oct 20, 2015 19:28:35 GMT
This site has been loading slowly for me for the last couple of days .. because of the rubiconproject.com running slowly which I guess is the ad network that Proboards use... YAY for Ads slowing sites down :/
Oct 20, 2015 19:55:24 GMT
Been slow today !
hamps
www.medwayrscentre.co.uk
Oct 20, 2015 20:20:50 GMT
Nightmare today!, I'm on my MacBook Pro and RR is the only site doing it, takes at least two minutes after choosing a thread to look at driving me nuts.
Oct 20, 2015 22:58:49 GMT
same here, but waiting around 30-40secs for page to open.
hamps
Seems fine this morning
Oct 21, 2015 10:12:24 GMT
It's still not right
luckyseven
Club RR Member Number: 45
Oct 21, 2015 11:02:41 GMT
I'm having the problem where I select an RR page and it'll take at least two minutes for it to display... sometimes it doesn't come up until I navigate away from it... then suddenly it pops up just as the computer moves to the next page. Then I have to use the "back" arrow on the browser to access the RR page I wanted in the first place
It's definitely only RR that's doing it and I've changed nothing on the computer. Extremely annoying
Frankenhealey
Club RR Member Number: 15
Oct 21, 2015 13:46:50 GMT
I'm having the problem where I select an RR page and it'll take at least two minutes for it to display... sometimes it doesn't come up until I navigate away from it... then suddenly it pops up just as the computer moves to the next page. Then I have to use the "back" arrow on the browser to access the RR page I wanted in the first place It's definitely only RR that's doing it and I've changed nothing on the computer. Extremely annoying ^^^^ What he/they said
luckyseven
Oct 21, 2015 17:47:49 GMT
Hmmmm, weird. Having found it all worked fine on *spits* Internet Explorer, I forgot all about it and logged back in with my usual Firefox. And it magically all works normally now.
Is cos Back to the Future day? Must be it; disturbances int he space/time continuum.
Oct 21, 2015 19:30:39 GMT
Still freezing - with message "downloading - 1 item remaining rubiconproject.com"
Oct 25, 2015 11:07:37 GMT
todays issue for info waiting for ... //ads.proboards.com/passback-726x90.html the problem is not getting any better, help/advice is always welcome
Oct 25, 2015 17:24:41 GMT
Yeah I get the rubiconproject some times... What should happen is all the ad stuff should load AFTER everything else... I don't think I'm doing anything odd with script order, so it is likely out of my hands and with Proboards... I'll see what they have to say.
Update time : The freezing is still causing problems (see earlier post for la[top spec) but using a different browser (Firefox) on the same laptop all seems fine, so it looks like my problem only affects my normal browser (Maxthon) Keep smiling folks!
