ChrisT
Club RR Member Number: 225
Been a project I've had kicking around for a couple of years, thought I'd dig it out and get it finished. Old Rover V8 block I've had left over from a long dead project, used for storing gas bottles in for a while.... Took it down the workshop along with 4 of the pistons..... Degreased, jet washed and in the blast cabinet..... Unlike most other V8 tables that are available I'm not mounting the pistons to the top of the block, they don't look right to me there. Instead I've cut down some steel rings...... Which I've welded in part way down the bores..... So the pistons can be mounted like this (more upright when properly bolted down into position)..... Found some glass that's about the right size for the top....
Last Edit: Nov 13, 2015 17:33:29 GMT by ChrisT
ChrisT
Acid etch primer and a bit of anthracite paint on it..... Will be polishing the decks.
Last Edit: Oct 6, 2015 22:16:56 GMT by ChrisT
that looks good
'90 Audi B3 Coupe 2.3 Auto [gone] '92 Audi S4 Avant 2.2 AAN Turbo Auto [gone] '93 Audi 80 Avant 1.9TDi [gone] '96 Audi A4 Avant 2.6 Quattro [gone] '97 VW T4 1.9td LWB [gone] '03 Skoda Octavia 1.9TDi [gone] '05 VW T5 Shuttle LWB 1.9TDi '15 VW Caddy Maxi Kombi 1.6TDi
Looking good. I was lazy when I built mine and bolted the pistons to the top face, but then I was living in a 10th floor apartment at the time so think getting the welder out might have been frowned upon :lol:
Excellent! And I agree that the pistons should be mounted internally.
Inspiration for me to do my four-cylinder table...
MR TIKI
TIKI,style from a different angle!
yep,that's cool! looks like it would double as a wine or beer cooler and there's space on the end for a bottle opener too...... something like this perhaps?
Last Edit: Oct 8, 2015 20:36:36 GMT by MR TIKI
Boldly driving faster than a tin worm can wiggle.
can you get a wine bottle in?
ChrisT
Cheers for the comments, yes a wine bottle will fit in the spare cylinders, putting a bit of tube in where the crank was to stop them dropping in too far, glass will need to be lifted to get the bottle out though.
MK2VR6
Mk2 Golf GTi 90 Spec
Inspired idea re the pistons. Best I've seen yet
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Excellent!
Nothing more to add really.
ChrisT
Again, thanks for the comments. Table is quite low with the pistons sat inside the bores, had to try and think of a way of raising it, so I got these...... Not sure yet, it's not quite how I pictured it, if they were a bit bigger, say 3" instead of 2" I think it would look better but that's the size pool balls are.
Hi, you could try cricket or baseballs or the other four pistons.
Colin
ChrisT
Oct 10, 2015 12:19:31 GMT
Cricket/baseballs aren't as cool as pool balls, plus I don't think they're as easy to work with as ones made of resin. Pistons would be good but I only kept 4 of them, although thinking about it I've got some from an XE somewhere in the shed.....
Oct 13, 2015 14:56:47 GMT
Try American pool balls, they're a lot bigger than the usual UK stuff
Oct 13, 2015 15:21:26 GMT
Looking awesome! Why not make some more piston legs? Get it even higher then!
MiataMark
Club RR Member Number: 29
Oct 13, 2015 15:51:35 GMT
A while ago I spent sometime at MX5parts waiting while they fitted a new hood, I did some work at thsi table. I prefer your V8 version though.
ChrisT
Oct 13, 2015 20:24:50 GMT
^^^Nice, but not V8 cool Try American pool balls, they're a lot bigger than the usual UK stuff Never even realized they were bigger, thanks, but it seems they're only about 57mm so not much bigger - Russian billiard balls at 68mm would be good but not quite so easy to get hold of and no 8 ball of course. I'm going to get it all together as it is and see how high it sits, maybe have a re-think if it's not high enough.......
Last Edit: Oct 13, 2015 20:25:40 GMT by ChrisT
ChrisT
Oct 13, 2015 20:29:12 GMT
Looking awesome! Why not make some more piston legs? Get it even higher then! Only got some pistons left over from another engine which are quite thin, and no conrods either, so probably won't lift it much higher than the balls - a combination of the 2 maybe.......
ChrisT Where are you located? I've got a load of big block Chevy pistons out of a 502ci motor sat in my shed. They are HUGE haha
ChrisT
Oct 14, 2015 19:48:53 GMT
ChrisT Where are you located? I've got a load of big block Chevy pistons out of a 502ci motor sat in my shed. They are HUGE haha Thanks for the offer, I'm over in Lincoln, not too far away. Had a go at polishing one of the piston CROWNs this afternoon, hasn't turned out too bad for half an hours work, a bit of Autosol should finish it off nicely...... Struggled to get a good picture of the shine, RHS is after a little work with emery paper, LHS is polished.
Last Edit: Oct 14, 2015 21:38:50 GMT by ChrisT
